Hood Blister, Have some issues !!!
Old Apr 16, 2006 | 07:47 AM
Tony90RS's Avatar
Car: 90 RS
Engine: LO3
Getting ready to paint my hood blister, I've decided to go black for now if I don't like it I'll repaint them red. The question is shiny black , semi gloss, or flat black. Also for those of you who have installed a set can you give me any "Tips". I'm sure water will get under them do I need to seal them with something? Any advice would be appreciated.
Old Apr 16, 2006 | 09:06 AM
2kflhr's Avatar
Car: '68 396 SS/RS, '02 SS
IMO... Gloss Black
I would not seal them. Just use the correct speed nuts that have a neoprene seal that seats against the underside of the hood and prevents water from entering the engine compartment.
IMO, Red, if not Red, Gloss black
Use the correct speed nuts with the neoprene seals.
Old Apr 16, 2006 | 09:18 AM
srdynamics1's Avatar
Car: 91RS_92Z28
Engine: 5.0_5.7
Transmission: WCT5_WCT5
Axle/Gears: 3.08_3.42
Make sure to paint the bare metal of the holes you are going to drill
Old Apr 16, 2006 | 10:45 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Gloss black
Old Apr 16, 2006 | 12:14 PM
Cam-aro's Avatar
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
Originally Posted by 2kflhr
IMO... Gloss Black
Prevents water from getting in engine compartment? The blisters are fake, how can water come through? Or are you like... opening the blister area underneath? *confused*
Old Apr 16, 2006 | 01:05 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
is that the right hood it doesn't look like it in the pic?
Old Apr 16, 2006 | 07:36 PM
JB22's Avatar
Those are the blisters that hawks sells that bolt onto a stock hood. (not the original style blisters)
and just to throw some input in, gloss black or body color. cant go wrong, both will look great.
Old Apr 16, 2006 | 10:50 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
i say flat black!
Old Apr 17, 2006 | 11:57 PM
jimmyj2000's Avatar
Car: 88 Formula 350
Engine: l98
Axle/Gears: 3.23 9-Bolt
I have some of those ones from Hawks also. I just got done drilling the holes and pre-fitting them onto the hood. What I did is get some cardboard and pressed the bolts down through it, then took a razor blade and cut around the blisters to make a nice template (I then marked them with LH and RH because the bolts they shoved in there were not symmetrical). I then took my hood off and turned it upside down. You may know this, but just in case, underneath the insulation you can see the frame is the same as the Z-28/IROC hoods so you have a nice little guide for placement. Drill the holes a little bit oversized so you can make adjustments. I am not completely done so I have not figured out how I am going to seal them yet, so I can't help you there. But one thing I can tell you is to strip that primer off, it is junk. I washed my car after I bolted them up, and that primer started flaking off with just the water hose. Good thing I didn't paint them first. Hope that helps.
Old May 26, 2009 | 10:58 PM
frankwi's Avatar
Car: 90 Camaro RS
Re: Hood Blister, Have some issues !!!
jimmyj2000...I am about to undertake this exact project. I have laid awake at night wondering how I was going to do all the measuring so as to not screw up a perfectly good hood. Your idea sounds great, I now look forward to tackling this task. Thanks for sharing !
I love this site...
Old May 28, 2009 | 11:05 AM
Louis_84's Avatar
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
i like flat black
Old May 28, 2009 | 01:22 PM
NT-Z's Avatar
Car: Had 2 iroc-z's . An '87 & '88.
Engine: HAD 5.0 & 5.7 tpi
Axle/Gears: stock
It all depends on what style your going 4. I'd do it a gloss black. And if your drilling holes in the hood for the blisters, apply some touch up paint around the drill holes to prevent rust.
Old May 28, 2009 | 06:07 PM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
I just put mine on and i went body color, IMO it looks better, get the right measurements for the job it will pay of.
Old May 30, 2009 | 08:59 AM
TPI-RS's Avatar
Car: 1991 RS Hardtop
Axle/Gears: 3:23
If you haven't installed them yet, check out this thread. I put up a quick 'how i did mine' in here and it might be helpful for you. Let me know if you have any questions.
https://www.thirdgen.org/forums/body...-blisters.html
Old Jun 9, 2009 | 11:08 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Post more pics please, i'd like to see these hawks.
Old Sep 25, 2020 | 11:57 AM
Alderfer's Avatar
Car: '89 GMC Jimmy GT
Engine: 5.7L TBI
Thanks for the primer info. Planning to add a set of these to my Jimmy.
Old Oct 25, 2020 | 02:10 PM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
when you get that done I'd love to see it, I'm doing the same on my s10
jaridjohn
Jul 8, 2024 03:49 PM
Street Lethal
Apr 30, 2019 12:14 PM
deracer
Apr 11, 2016 12:04 AM
sailtexas186548
Exterior Parts for Sale
Feb 29, 2016 08:40 AM
Wife'sCar
Aug 22, 2015 01:46 PM
