91-92 Z28 Spoiler questions on ebay
Car: 1992 Camaro RS (Z28 Clone) Z03
Engine: 305 TBI
Axle/Gears: Eaton POSI/ 3.73
Ok i have seen theses 91-92 z28 look a like spoilers on ebay for sale. I have been wanting to install one on my car soon. Unfortuntaly I have been unsuccessful in finding an original one so I want to go aftermarket. So is this spoiler and exact dupicate of the 91-92 z28 spoilers? Has anyone bought one from these guys? What is the qualitly of one?
I can't seem to post the links but if you go to ebay and search 92 camaro spoiler they will show up.
Car: '91 Z28
Engine: L98 H/C/I - 400whp
Axle/Gears: Moser 12-Bolt(4:30 w/spool)
I bought one from Ebay for my '91 RS. The spoiler came primer'd with all the mounting pieces(screws, etc.). You will have to remove your factory three-piece spoiler, and drill 'pilot' holes for the new spoiler, and then drill out the 'pilot' holes so that you can bolt in the aftermarket. It also comes with some foam like material to cushion the mount between the spoiler and car. Without the foam stuff, you'll rub the paint off your car(i know, I tried to go without the foam stuff). My problem was that the factory spoiler holes stayed on the car, you'll have to fill them in... which can run quite a bit of money to fill in and repaint the rear half of the car. As for the spoiler, it's identical to the factory high-rise spoiler, practically same dimensions. Just be sure to line it up straight when drilling. Honestly, I did mine in the dark, with my phone as a light, it's very simple.
Here's picture of install before paint, and after paint... notice the factory spoiler holes.
Engine: 305 TBI
Wow thanks for the great information and pics!! What did u think about the quality and what price did u pay for yours?
Check out Third Generation USA, I believe he has a factory 91-92 Z28 High Rise Spoiler for $ale.
Car: 1991 Camaro Z28
Engine: L98 5.7 V8 TPI
There are a few for sale on the parts board..
https://www.thirdgen.org/forums/part...8-parting.html
https://www.thirdgen.org/forums/part...t-91-92-a.html
Car: '91 Z28
Mine ran $125 and that includes shipping. Got it off Ebay, had it in bout 4 days. Spoiler was properly wrapped and came in great condition.
It's honestly a simple install. You'll have to pull off that plastic trim along the underside of your hatch. You will then line up your drill locations(comes with hardware to do this), drill pilot holes, then drill out 1/4in holes(i think). From there, go back to underside of hatch and open the holes up more so that bolts will fit in. Put spoiler on car, then bolt up from underside. Mountin the spoiler yourself is a bit of a hassle, but I did it, ya have to hold the hatch up, and the spoiler in place while bolting in at the same time, but a buddy can help ya. You can have it installed in less than 2 hours if you take your time, probably took me around hour and'a half... and I was workin in the dark because I was desperate to get it on my car!
Car: 1988 trans am GTA
Engine: 350 tpi
i just got mine in the mailtoday off ebay come out to 125ish$ looks great but now i need to take my trunk lid off sand blast it, fill in the holes from old spoiler, drill new holes then repaint it.im putting it on a trans am so no holes match up, as for the gaskets they just look like some foam that was cut with sissors im sure you can find some rubber at any hardware store that could acomplish the same task.
