painting a rusty blower motor box...
Car: 1984 Z28 ~Brown Horse~
Engine: 305 V8
Axle/Gears: 3.23...i dunno...
ok...so it is not completely rusty but has a spot here and there. i want to clean it up and paint it before installing it and was wondering what to do about the little rust spots. and what paint should i use? does wal-mart have a high temp rattle can cause i am headed there to buy the paint for the tail light mod anyway...
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
I bought mine..and it had some surface rust. I just sanded it down with 180, then sanded with 320. Primed...then painted it with satin black....looks great
Engine: 305 V8
by prime you just mean clean right...and did you use any special high temp resistant paint? or does that even matter?...
Engine: 5.7
by prime, I mean prime, haha. I sanded down the rust, and sprayed a rattle can primer on the heater box. Then sprayed the satin black. My engine compartment really doesn't get that hot by the heater box...so I just used regular satin black paint, I've had no problems.
Engine: 305 V8
is it really that important to use a primer? or would i just be fine sanding and blasting since it's just my DD and not as nearly as good looking as yours...
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Use it.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can paint it with a brush too, or maybe just put it on in it's current rusty condition, but why would you do a half assed job just to save the $5 cost of a spray can of primer? If it had no rust and you were able to simply sand the original paint, then you wouldn't need primer, but if you're repairing rust, you'll have bare metal surfaces, so primer is absolutely necessary.
Street Lethal
Aug 13, 2015 08:28 PM
