can i see some pics of cars in black primer
Old Jul 15, 2006 | 07:55 AM
i8myz28's Avatar
Car: 86 z28
Engine: 355 TPI W/305 HEADS
Axle/Gears: 3/73's
i'm about to prime my car and was thinking of leaving it flat black anybody have pics i could see......
Old Jul 15, 2006 | 11:50 AM
Yellow85IrocZ's Avatar
Car: '85 Z28 Iroc-Z
Engine: LB9 305 TPI
I found this in a random thread when I was searching for something. Looks awesome
Old Jul 15, 2006 | 09:21 PM
Slave One's Avatar
Car: 1991 Camaro RS
Engine: 5.0 TBI
Axle/Gears: 3.08
That actually does look kinda sweet... hot-rodish
...Thinkin about doin the same thing...
Old Jul 15, 2006 | 09:33 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Bro you probably wont get too many responses to this thread because leaving any car in the primer state is BAD for the metal. good luck on your search!
Old Jul 15, 2006 | 09:44 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
what about with the stuff PPG makes thats a primer/paint. is this still bad for metal and what exaclty is bad for the metal when leaving a car in primer
Old Jul 16, 2006 | 08:17 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
primer
i was going to use a sealer primer then clear it... is that good enough..?
Old Jul 16, 2006 | 12:20 PM
fenton06's Avatar
My friend had a lumina he painted flat black, it wasn't primer, but actual paint. It looked pretty killer for a lumina. I'll see if he can chime in, he's here in the boards.
Old Jul 16, 2006 | 03:07 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
flat colors
Ok, here's the deal with the paint, if you do leave it in primer it will chalk over after time. If you do use primer use a really good primer sealer so that it doesnt look like the front fender on my car where the previous owner went cheap . I'm the one with the flat black lumina, I used the cheap stuff from wal mart, I wouldnt suggest it, i just wanted my car to be one color, and didnt want to put much money into a car with over 200K miles on it. I'd say do black primer, then good quality flat black paint and then use a clear with a dulling additive in it. That way its sealed and will look nice for a long time. Thats my
Old Jul 16, 2006 | 03:52 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
do a search on this site for flat black or DP 90
You should find a few threads.
DP90 is a primer sealer and you will be just fine using it.
Old Jul 16, 2006 | 05:07 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
the real way to do it or at least the best way. is to do a regular black paint job and there is a place that makes a "flat" clear coat. when you spray the clear over the black paint it gives it a flat look. but most people that want the flat look want it b/c you can primer a car for cheap. the paint job im talking about cost the same as a regular paint job.
we took our 67 camaro to a well known shop here in town and thats what the guy told us to do if we were going to keep it that color for a long time. but we ended up not getting it painted anyway. i would rather primer a car with a good sealer and then sand and respray the primer if it starts looking bad that would be a whole lot cheaper than getting a "flat" paintjob.
Old Jul 16, 2006 | 06:56 PM
NoItsNotForSale's Avatar
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Transmission: 700R's
Axle/Gears: 2.77 - 3.70
Did mine with PPG DP90
Attached Thumbnails can i see some pics of cars in black primer-black222.jpg
Old Jul 17, 2006 | 01:18 AM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
I dont have a pic up yet but I just got done doing mine in DP50 PPG's gray primerit looks good. I dont know about any other states but here in Cali you cant get PPG DP primer anymore I found this out the hard way took all the paint off my car just to find that I could not get DP90 but I had some DP50 so I used it the whole gallon.
Old Jul 17, 2006 | 01:46 AM
Black85sport's Avatar
Car: 91 Silverado
Engine: 350 TBI, EBL Tuned
If you have no intention of giving the car an actual "color" anytime soon, why not paint it a satin for flat black, instead of primer.
Old Jul 17, 2006 | 06:41 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
good to hear some advice
well my cars right now is red. i'm picking up 1 green door and 1 gray door, so those needed to primed plus the rest of the car needs to be sanded in spots and taken care of, plus my ss hood is flaking because i didn't know you needed to sand it first for the primer to stick better to the dp90 obviously needs to be sprayed out of a spray gun.? i guess..
Old Jul 17, 2006 | 06:57 AM
i8myz28's Avatar
Car: 86 z28
Axle/Gears: 3/73's
HOW MANY.??
how many quarts will i need to do my whole car..? has anybody heard of rust bullet paint.?
Old Jul 17, 2006 | 11:46 AM
Car: 87 & 89 Iroc's
Engine: 5.0 - 5.7
Yes you will need a gun. DP90 is a sealer so it is waterproof. I used about a half a gallon.
Old Jul 17, 2006 | 02:31 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
rust bullet isn't bad stuff i wouldnt paint the car with it but bare interior and underneath along with suspension parts is a good idea. I've got a 99 ls1 rear in my car that is sprayed with it. it's been a year now and no chips even when it was being jacked up and set on jack stands no problem. It was sprayed to the guy i bought it from did his camaro interior and entire underneath with it. I think it would be alot better brushed on.
Old Aug 2, 2006 | 07:00 AM
Night rider327's Avatar
Car: 1988 Camaro
I shot mine with black primer back on Sept 24th 2005. It's been that away since. I like the look, and I like the fact I don't have to worry about my paint job getting chipped being I live out in the country where gravel/dirt roads are common.
Here's some pics...
Right after I sprayed it, still taped up....
Picture 521 picture - Webshots
After primer cured and I untaped car....
Picture 531 picture - Webshots
Here's another one from that same time.....
Picture 536 picture - Webshots
Here's one from Oct. 2005....
Picture 543 picture - Webshots
Here's some after I added the cowl hood in Nov. 2005
Picture 575 picture - Webshots
Picture 573 picture - Webshots
Here's 3 pictures from a BBQ/get together I went too back in late march of this year (2006)
carsfrombbq10 picture - Webshots
carsfrombbq9 picture - Webshots
Picture 725 picture - Webshots
As you can see be the timed pictures the primer is holding up great.. This is my daily driver car too and I keep it outside year around, not covered or in a shop.
For primer I used rather cheap stuff I picked up at the local mom & pop auto parts store for around $50 for a gal of primer and gal of reduecer.
Here's the info on primer I used......
AutoBody Master
Professional Hi Prime Lacquer Surfacer
Hi prime Hot Rod Black #8404
1)Wash surface with #5900 or 5910 wax & grease remover
2) Mix 2:3 with VOC compliant thinner
3)Apply 2-3 full wet coats with a 10-15 minute flash
4) To sand: 20-30 minutes
1992 Trans Am
May 10, 2023 07:19 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
drathaar907
Aug 10, 2015 07:44 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
3rdgenparts
Aug 8, 2015 07:09 PM
