Lifting the rear of a 91 firebird
Old Jul 27, 2006 | 12:39 AM
Slicschlei's Avatar
Does anyone know where i can buy some springs that lift up the rear of the car instead of lowering it i can only find lowering springs and i dont want that i want the car lifted in the back.... Please Help
Old Jul 27, 2006 | 12:45 AM
91Camaro's Avatar
Car: 91 Camaro
Engine: 305 TBI
How about these
Spohn Performance, Inc.
Old Jul 27, 2006 | 01:27 AM
Demon355's Avatar
Why the hell do you want to lift you're car?
Old Jul 27, 2006 | 02:29 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
i guess the real question is ???? where can i find ""progressive rate cargo springs that increase rear ride height!""??
Old Jul 27, 2006 | 03:49 AM
sogabe's Avatar
Car: 91 Camaro RS(RealSlow)
Engine: 3.1L
Axle/Gears: unknown/mostlikelycrappy
IMO when u have a higher rear,
it looks more agressive.
just my opinion
and i think it looks nice too when the front is a bit lower than the rear.
anyways usually u will end up raising the height of the car
when u replace the spring,
as our spring could be as old as 24years.
Old Jul 27, 2006 | 07:40 AM
Slicschlei's Avatar
see thanks! it really does look more agressive!! i think it looks so cool!! it adds alittle more muscle car look to the car!!!
Old Jul 27, 2006 | 09:09 AM
TX_1987_GTA's Avatar
Car: 1987 GTA Hardtop
Engine: 350 T. P. I.
you could approach this 2 ways.....
#1 Replace rear springs with new ones or see if there is a facility near you that will remove your existing springs and modify them or re-arch them. You probably dont want to raise it to much, just enough to give it a nice stance or rake. Or you could go the way of the old school and just install a pair of rear air shocks ( can you still buy these? ) that will allow you to adjust the rear ride height just by applying air or removing it.
#2 Drop the front suspension a little bit.... thus giving you that stance your looking for. This can be done with suspension components, or even by just adjusting tire sizes from front to rear. Maybe go with a slightly taller side wall height tire on the rear and slightly smaller side wall height on the front.
Old Jul 27, 2006 | 09:42 AM
TheBandit's Avatar
Car: 72 Fbird. Want another 3rd gen :(
Engine: Poncho 350
Transmission: Turbo 350
i agree with the ^^^... i would drop the front, not raise the rear
Old Jul 27, 2006 | 09:58 AM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
you want your car to look like this dont you?
Get lowering springs, but beef up the rear tire fyi hes got intrax springs and I will have the same set up springs/rim/tire combo
http://i8.photobucket.com/albums/a46...0/100_0453.jpg
its not how high the rear sits to make it muscley
Old Jul 27, 2006 | 10:12 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
probably more like this:
my car is actually lowered all the way around, but with that big tire up in there, it helps give it a muscle car stance like your talking about. this is what seperates the men from the boys my friend!
Old Jul 27, 2006 | 10:18 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
you asked in the suspension form as well right?
I answered there, stock rear springs will do the trick.
hard to see the raked stance while i'm on the slanted driveway though
pic
Old Jul 27, 2006 | 11:11 AM
dr1's Avatar
dr1
Car: '89 Firebird Formula
Engine: 305 TBI
seriously go with air shocks, totally adjustable ride height.. doesnt sound like your shooting for any kind of performance just looks anyways ;0
a friends 86 camaro has them (dont ask, previous owner towed a small boat) and we had never messed with them but decided one day to check the air, and it was way low so we filled em up way past max apparently
his headlights were pointing like 10ft in front of the car when we were done, it was hilarious looking
Old Jul 27, 2006 | 11:19 AM
mw66nova's Avatar
Engine: 7.0L
oh goodness...back to the hay-day of hijackers, glasspacks, and gum-wall tires
Old Jul 27, 2006 | 04:01 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The only problem with using air shocks is, there isn't enough metal in that area to properly support the vehicle weight. The body mount point for the shock isn't much more than the shell/tub sheet metal with a another piece of sheet metal reinforcement spot welded there.
Sometimes, in more rotten cars, it's not even strong enough to keep a stock shock from getting yanked/pushed through.
Old Jul 28, 2006 | 03:23 AM
purpleZ-28's Avatar
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
oh god, i have those on my Z and they SUCK!!! they are so damn soft. and it sucks because i have no money to replace them with a quality shock.
but seriously, when are you actually going to get under there and use them like they wer meant to? i havent once and ive had this thing for over a year now.
Old Aug 1, 2006 | 01:24 PM
Blackbird down's Avatar
Car: 91 Formula
Engine: 305E
lift
A coil- over kit, and shock extenders for the rear shocks, about a $35 fix. Should get you higher, but you are changing the cornering characteristics of your suspension.
Old Aug 1, 2006 | 01:29 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
If you're going to jack the back of your car, do it right. Hockey pucks and air shocks. That's the best way to fit 28x12" Futura tires.
Old Aug 3, 2006 | 11:52 AM
formul8!!'s Avatar
Car: 2004 GTO
"Stinkbug Stance".... LMAO..
You will need to add some wide-azz tires on some Cragar S/S wheels. Don't forget the feathered roach clip thingie for your reat view mirror and the "Easy Does it" bumper sticker....
Old Aug 4, 2006 | 02:45 AM
gottfuel's Avatar
i never thought of it that way befor.,,. and im a big ol white boy,.,.i think ima start gitin gas somewhere els now!!!!!
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
I'llrocya
Feb 2, 2016 11:43 PM
E Rod
Aug 28, 2015 05:17 AM
anesthes
Aug 8, 2015 09:37 PM
