How can I clean my car cover?
Old Sep 22, 2006 | 12:57 PM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
I have an Exoto's CoverUp car cover, and since they no longer make those types of products, they had no information for me. I need to know how I can wash this thing, it's a little dusty and every time I use it there is a lot of dust and stuff all over the car (which is not good becuase then I have to re-wash it). Does anyone know how I should go about cleaning this? I don't want to ruin it.
Old Sep 22, 2006 | 01:59 PM
85maroz28's Avatar
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
I dry cleaned mine!
Old Sep 22, 2006 | 10:32 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
dry clean OR put it on the car and wash it (i wouldnt take TOO much soap to it cause it may take a while to get all the suds out)...turn it inside out and do the same. then let it dry. your car will get wet in the process unless you can find some other car
Old Sep 22, 2006 | 10:56 PM
Car: 2012 Corvette
Engine: LS3
Ok, so I can't put it in a regular washing machine?
Old Sep 22, 2006 | 11:46 PM
rwdtech's Avatar
i dont think you could even get it to fit in a washing machine. if you could, that might work...you should probably use the lightest wash cycle. still seems risky though to put the cover in a home washing machine
Old Sep 23, 2006 | 04:21 AM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
honestly for $10 or $15 bucks, its worth it to take it to a dry cleaner.
Old Sep 23, 2006 | 06:49 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Go to local laundry and use there largest washing machine. did that with my car cover and no problem. Cost you about five dollars or less in quarters.
Old Sep 23, 2006 | 07:18 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Bring some loose change. No more than $5 tops will get you a wash and a dry in the industrial machines (most laundramats have these large stainless steel units). Use a mild liquid detergent for clothing and not your dishes (and usually 15-20 ml will do the job).
I do mine once in spring time and in the fall when I put the car away.
Old Sep 23, 2006 | 05:56 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Most car covers are designed to be machine washed but often the thicker ones simply won't fit in a home washer and need an industrial machine, as has been pointed out. Generally they recommend air drying or light machine drying - just don't dry it on high heat.
I take mine to my dry cleaner twice a year - $15 and it's beautiful.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 8, 2015 01:18 AM
