need to lose some weight..
Old Oct 15, 2006 | 10:00 PM
82whiteZ28's Avatar
Car: 1982 Camaro z28
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
so i had no idea which part of the forum to put this in. Im looking to make my car have about a 3000lb race weight im trying to think of some ideas to shed some extra pounds. so any suggestions are welcome. im trying to make it have a factory appearence still. i already have done most of the stuf in this article https://www.thirdgen.org/sheddingpounds
Old Oct 15, 2006 | 10:08 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
there's a bunch of weight reduction threads. it costs some cash to make it that light for sure. At that weight I'm not sure you'll have much of anything left in the car...fyi mine is 3250 race weight and my only future options are lexan windows and taking out the passenger seat basically.
Old Oct 15, 2006 | 10:20 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
i was thinking about busting out the holesaw and cutting out some stuff in the doors HAHA GIVE ME IDEAS.................
Old Oct 15, 2006 | 10:27 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
Get on the treadmill lol you could get a fiberglass front clip and doors
Old Oct 16, 2006 | 01:11 AM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
is it seriously that hard to make a car that light?
Old Oct 16, 2006 | 02:34 AM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
drop the GFX, there goes about 100 lbs...
Old Oct 16, 2006 | 01:21 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
VFN Fiberglass - All your fiberglass parts
I wish they had fiberglass fenders for my firebird, but I believe they have them for your camaro.
/edit: Seems like your in the same boat as me on that weebsite, they have the entire front end molded together. My friend has a website that sells Camaro fenders in fiberglass though, when I get that site, Ill passs it on to you.
Old Oct 16, 2006 | 01:29 PM
ezysk's Avatar
Car: 1986 Firebird / 1985 Trans-Am
Engine: 305 4BBL / 383 4BBL++
Transmission: 700R4 / 700R4
Axle/Gears: ?.?? / 3.47
92RS(real slow) Joked about a treadmill, but if you happen to have some extra, and you are truely serious about pulling better times, that also helps.
I had a buddy find an extry 50Lbs on the old treadmill..
Works for other sports..
Note: This isn't a flame, just makes great since if you have it to lose.
Remove the carpet..
I guess I should ask if the car has to drive on the street..
Old Oct 16, 2006 | 01:51 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
well ezysk i want to make it "look" like a street car so a carpet is something i want to keep. but i was thinking of some kinda lightweight carpet or removing the padding...
how much can i lose with the bumper supports?? do i "need" them? haha
Old Oct 16, 2006 | 01:56 PM
ezysk's Avatar
Good point..
So I guess removing the tail lights and head lights are out of the question, unless you buy are red and white flash light.
Old Oct 16, 2006 | 02:18 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
thx ezysk you're going to make my ride look like white trash
Old Oct 16, 2006 | 02:27 PM
ezysk's Avatar
Old Oct 16, 2006 | 09:55 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
is there anything wrong with removing the front swaybar?? and how hard is it to drive with an s10 gearbox??
Old Oct 16, 2006 | 10:31 PM
xpndbl3's Avatar
Car: 1984 Z28
front sway bar has been gone for years off my car and i use skinnies and the manual steering....reminds me of an old honda i used to drive.
Old Oct 16, 2006 | 10:38 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Try giving this post a once over..
https://www.thirdgen.org/forums/fabr...ht-quest.html?
Old Oct 16, 2006 | 10:45 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
thank deadbird...
xpndbl3 you're local to me i wouldnt mind checking your car out to see how u have things setup, that is if its not already put away for the winter :x
Old Oct 16, 2006 | 11:23 PM
xpndbl3's Avatar
Car: 1984 Z28
it's parked in the garage as always, might have it out wednesday around the block...supposed to hit 60s. if you have any questions/whatever post on the chicago board
Old Oct 17, 2006 | 02:34 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
FYI the doors are an important parts of your car's structure. So don't get too happy with that saw.
And if it's a street driven car then theres only so much you can do. Getting rid of the A/C and the back seats are the first things I think of.
Old Oct 17, 2006 | 05:09 PM
BOTTLEDZ28's Avatar
Transmission: A4
loose the front and rear bumper supports and plastic.
fiberglass hood
aluminum heads
discard any unneeded parts under the hood(smog,A/C, evap, etc.)
get lightweight wheels
ditch the spare tire
ditch any power option like power windows and locks.
get lightweight carpet and loose the padding under it
theres more, I just cant think of them. Notice I didnt say ditch the stereo. thats up to you. You said you drive it on the street so I assume you want some tunes while driving. There a down side to loosing weight to acieve fast times at the track. Theres a thin called track safety rules and if you accomplish your goal and get your car running a lot quicker due to less weight then the track may tell you thatr you need a roll bar or roll cage along with a harness and driveshaft safety loop. those things add weight but you wont have a choice if your running 11's.
Old Oct 17, 2006 | 05:52 PM
slowfast's Avatar
Car: 84 firebird
Engine: 400 sbc
Transmission: th350
Axle/Gears: 3.08
dont let me start
!air,!ac,!egr
remove the underpading of the carpet, spair tire,junk in the car, change ash trays, misc bolts you dont need. empty or remove windsheild washer fluid resevor lighter wheels(gta's are 17 pounds!)
go runing and eat right, thats right there is free or cheap..
if you wanted to get more into it, you can suffere looks by taking apart more of the interior and removing more creature comforts,
you can buy exhuast,suspension,heads,intakes etc etc that weigh less too!!
also if you use nitrous, go with a 10 bottle instead of two 5's
Old Oct 17, 2006 | 09:49 PM
82whiteZ28's Avatar
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
BOTTLEDZr28 i have heard that power window assembiles weight the same as the crank ones do, plus u cant crank windows with a cage..... im diggin most of your ideas..
what are people doing for a lightweight front bumper support cause i dont want the nose caving in ya know.. so i have to have something there... and does anyone have any ideas on lightweight carpet??
Old Oct 17, 2006 | 10:35 PM
xpndbl3's Avatar
Car: 1984 Z28
i crank windows with my cage so that's not true at all.
Old Oct 17, 2006 | 10:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Just build more power.
Old Oct 18, 2006 | 03:14 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
Get a Lexan hatch
I've had my hatch off by myself, and I KNOW it's gotta be 75-100 lbs.
chromoly k-member and a-arms. PA Racing makes a k-member and spohn makes a-arms.
ditch all your stock suspension for chromoly pieces. swaybars, lower control arms, panhard.
plastic gas tank out of a 4th Gen. I don't know if theres a difference, it was just a thought because I know people have put them in third gens with little trouble.
Old Jan 31, 2007 | 04:47 PM
GTA_340's Avatar
I'd check out hawks site, they have an aftermarket "notchback" made of fiberglass, i havent weighed my hatch but im sure you could loose some weight by switching that out. (i personally think their ugly, but i do like the factory notchbacks)
PurelyPMD
May 5, 2016 04:57 PM
Giocio
Oct 1, 2015 12:20 PM
Stryker412
Sep 20, 2015 06:59 PM
bryan623
Sep 19, 2015 10:13 AM
