Restoring grille help
Old Jan 26, 2007 | 01:02 AM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Hello all, I have a very faded black front grill and would like to improve the looks of it. I would just like to get your opinions on the best way of doing this. Including paint choice, sanding options, etc. Who has done this and how did it turn out w/ your procedures. Suggestions/Ideas are highly welcome
Old Jan 26, 2007 | 04:37 AM
Stealthy-One's Avatar
Car: 89 RS
Engine: 2.8
Transmission: 700r4 auto
Axle/Gears: huh?? guessing stock.
couple different options...
Plastic and vinyl paint. sand with 300, then warm the rattle can and spray.
Meguirs sells a trim black stuff. I have used it with great sucess on the black body trim on lots of cars. restores that nic dead black they had from the factory.
Old Jan 26, 2007 | 01:34 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
Is 300 too coarse sandpaper? I was going to use some pretty light stuff but if that worked I will give it a shot. Also do recommend putting clear coat on it or will that give it too much shine? Thanks
Old Jan 27, 2007 | 11:42 AM
compuwiz1937's Avatar
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
It'd be better just to buy a brand new one. They're only $50.
Old Jan 27, 2007 | 01:17 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
And it would only cost about $10 and some elbow grease to restore it. And It would still be original. Whats your point?
Old Jan 29, 2007 | 04:31 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
wow you guys are soooo helpful
Old Jan 29, 2007 | 08:05 PM
Stuart S's Avatar
A company called "Crest" makes a very nice quality Satin Black trim paint... If the grille itself is in decent shape, I'd just scuff it with some 800 or 1000 paper (wet), and you should be OK with 1-2 thin coats of the trim paint...
When I had my old IROC-Z, I redid the grille, headlight buckets, and hood louvers all at the same time to match - turned out great, and held up great...
Here's a pic to show how it turned out...
Old Jan 29, 2007 | 08:10 PM
90 white Z's Avatar
Car: 90 iroc
Engine: 305 tpi
THANKS ALOT!! Where can you find crest paint?? And by headlight buckets are you talking about the fog light housings? If so, I was wanting to paint those at the same time if possible. Did you use the same paint for them? Thanks again
Old Jan 29, 2007 | 08:21 PM
Stuart S's Avatar
No problem...
I'm not sure where you can get that paint to be honest. At the time I did it (around 2000?) I had gotten it through the shop that painted that car... I think I found the website of the company who makes it, but I'm not 100% sure that it's correct... I'll send you a PM on that (non-sponsor)...
By headlight buckets, I meant the satin black area around the headlights in the nose... Yes, I used the same paint.
1990RSVERT
Exterior Parts Wanted
May 27, 2024 11:23 AM
skirocz28
Members Camaros
Nov 12, 2015 07:52 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mrbird
Oct 20, 2015 03:43 AM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
