New daggers are mounted
Old Feb 24, 2007 | 02:40 PM
ram air'd gta's Avatar
Car: 89 trans am gta; now 92 firebird
Engine: 350 tpi
Just wanted to post a few pictures of the new Centerline daggers I got. They are 17x8 with 245-45-17 on the front and 17x9.5 with 275-40-17 on the rear. They are not the best pictures. Let me know what you think.
Old Feb 24, 2007 | 02:43 PM
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Looking good man! now drop that beast! >
Old Feb 24, 2007 | 02:52 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
I'd like to see that thing with some better lighting! I'm digging the black accents on the red.
Old Feb 24, 2007 | 03:37 PM
TunedPort 335's Avatar
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Awesome wheels man, those are the same sizes that i got on both the wheels and tires. Im sure you will be just as happy as i am with them
Old Feb 24, 2007 | 04:31 PM
Engine: 350 tpi
Thanks, they do look good, can't wait to get it out in the spring time. I've got cabin fever, and right now we are under a blizzard warning.
Looks like you have yours lowered a bit. What spring set do you have on yours. I've been looking into it, but have alot of questions about it. Don't know if I want to do it or not.
Old Feb 24, 2007 | 05:02 PM
camaroman_83's Avatar
Car: 1983 Camaro
Engine: 305 4bbl
WOW! That's a sweet Bird!! I just got one in November and have some work to do but i've been waiting for the wheather to get better. I was able to work in the garage the begining of this week when it was nice, now i have to wait for this crap we're getting now to end!
Old Feb 24, 2007 | 05:16 PM
rs_boy's Avatar
Car: '89 IROC-Z Convertible & '91 RS
Lookin' sharp. Yeah, I'd have to agree on the drop too.
Old Feb 24, 2007 | 05:21 PM
wackytower's Avatar
Car: 1985 Trans Am
Engine: Superramed 406
Axle/Gears: 10 bolt 3:73
Looks good But like the others said it need to be lowered
Old Feb 24, 2007 | 07:40 PM
Yessir i have the Eibach Pro Kit springs. i was skeptical of lowering it at first, but after i put the wheels on, there was no way i was going to drive it with the stock springs. Its probably one of the best, most noticeable things i've done to the car, and it's not any harder to drive it afterwards. Just angle your driveways and you'll be all set
Old Feb 24, 2007 | 08:27 PM
Engine: 350 tpi
TunedPort 335
did you have to get LCA relocation brakets or aftermarket shocks? I've been searching the boards and it seems like everybody has different opinions. Would I be able to get away with just getting the springs?
Old Feb 24, 2007 | 08:49 PM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
TunedPort 335
if you want it slammed go with intrax but the ride around town is pretty tought b/c the front is so low you have to look out for everything, i really love my spings though the car wouldnt be the same with out em, but forget about lt headers and forget about driving over speed bumps, my car with stock style 3" exhaust scrubs taking speedbumps almost sideways...
Old Feb 24, 2007 | 11:15 PM
Dans87GTA's Avatar
Car: 1987 Pontiac Trans Am GTA
Engine: 355 Stealth Ram
Transmission: 700R4 w/ 2600 stall
Axle/Gears: 9-bolt 3.27
Awesome looks Awesome! because of you and tunedport335 im going to put those on my GTA and go the same size i have been debating for a year but after those pics going for it! great looking car too. Are they pretty lite compared to the GTA crosslace? Thanks Daniel
Old Feb 24, 2007 | 11:19 PM
Stevo's Avatar
Car: Pair of 92 Z28s
TunedPort 335
Rims look great! But since i have aftermarket 17s+Pro Kit ill give you my suggestion too. If your gonna replace the springs you might as well do the struts/shocks with it. You can really take advantage of the ride and handling characteristics if you do those both. I was kind like you are now i had just got the rims on, had to lower i did. You definently need to replace the factory struts and shocks if you havent yet. It will get pretty bouncy and like to scrape a lot. Relocation brackets...well i will have those installed sometime this spring. Not a must item but i do have some wheel hop that id like to take care of.
Pro-kit is a great choice to just fill up some of the fendergap shown from going to a smaller sidewall. Good luck and the car looks great as is!
Old Feb 25, 2007 | 10:00 AM
TunedPort 335
I do run aftermarket KYBs. The ride is stiff of course but its not squishy or anything like that. As far as the relocation brackets, i haven't done them yet, i never have wheel hop... just lots of wheel spin.. but i will probably put them on sometime this year since I know the car will hook up better with them.
Also an adjustable panhard bar is a must in order to center the rearend after lowering. I installed an adjustable Hotchkis version and had to move the rearend a little after i installed the springs
92projectcamaro
Sep 12, 2015 12:33 AM
ynk1121
Sep 12, 2015 12:27 AM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
