Centerbolt Valve Covers (Descriptions and Pictures Wanted)
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
I am in search for Centerbolt Valve Covers and am kind of dissapointed.
I have found only 1-3 with 3 holes.....so does anyone have pictures of their setups.
I am looking for NO CHROME (anything else) Centerbolt valve covers with 3 holes 2 for oil cap and PCV and 1 for breather on pass side. SOmething like these
http://store.summitracing.com/partde...5&autoview=sku
But I cant get proforms because I have these and proforms covers have a lowered bolt hole and these have to sit flush..
Let me know whats out there.
Also this might be a stupid question but can I fill my oil through my diptick? If I can then I wont need 2 holes on one side and 1 on the other. I can just have 1 n 1. Let me know guys, thanks.
-HATING TORQUE STEER!!!
COTM Editor
Re: Centerbolt Valve Covers (Descriptions and Pictures Wanted)
I run the Trans Dap version of the tall polished center bolt covers (2nd link). I used teh ball milled versions to match the lines in the intake. Mine have only two holes... PCV and breather. I installed Billet Specialties ball milled PCV, and breathers to match. I fill my motor oil through my breather hole... just pops in and out like a normal oil cap.
Here is the only pic I have access to here at work...
Car: 89' IROC-Z
Engine: LO3
Damn that looks nice. Only problem is Trans Dapt is backordered at Summit and thats where I am buying everything....I am looking into these. Made by Billet Specialties but are the same design (minus ball-milled)
http://store.summitracing.com/partde...part=BSP-95729
What Brake Resevoir Cover are you using? I think you told me before but I forgot. Do you know the part #. If not where did you buy it so I can go search there....unless it was summit. Lol.
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
The ones I have are from Summit and have no holes predrilled. That way you can put them at which end you want and they come with the baffles so you can put them in if you shoose to.
Car: 89' IROC-Z
Engine: LO3
I could but Im sure it wouldnt come out nice. I have looked into those for that reason but kind of just want to bolton and go...been 7 months since I bought my car and only drove it for 3 blocks...LMAO. So kind of in a hurry....
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
dumb question: why would one go with a tall valve cover design?
Car: 89' IROC-Z
Engine: LO3
My theory is if you have to replace it ANYWAY, why not go bigger and aftermarket.
Mainly though Tall are to clear Roller Rockers....some get big, so you'll need the extra space at sometime.
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
would i be able to put tall covers on my smog pumped tpi?
Edlebrock Aluminum center bolt valve covers. You have to use the PCV hole as your oil fill.
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I would like to see some composite LT4 valve covers on either a carb or Tbi'd
car.(thinking about getting some.)
I have the ones in the second pic. Nice thick polished aluminum. Only catch is the lip for the gasket is not deep enough. You have to glue the gasket to the valve cover to put them on. Unless you have like three sets of hands to use. Oh, mine are tall to clear roller rockers. And the hold down bolts have a tapered head to fit flush with the top of the valve cover.
Car: 89' IROC-Z
Engine: LO3
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm not sure that the smog equipment will be an issue. As far as I know, the only issue you may run into is the coolant diverter valve and associated lines, but I'm sure you can fab up a bracket to raise that valve a couple inches. PCV can be easily modified (if it's necessary at all) to work with tall covers, and there isn't any other smog equipment that I can think of that would be in the way.
Car: 1979 Camaro Sport Coupe
Engine: 350 LM1 with 083 2.02/1.60 heads
Transmission: TH350, soon to be 2004R
Axle/Gears: 2.41, soon to be 3.42
I don't know if you are still in the market for the tall valve covers, but in case you are, I am in the same boat! Now, I am looking at my engine which is outside of the car and I see no reason why you could not use the taller valve covers, they should clear all of your smog equipment, even though the top edge may sit up against your AIR tube collector, but with a little careful bending you should be fine. I'm going to email proform to find out exactly how much taller the tall VC's are compared to the "stock height" ones.
My main reason for wanting the taller valve covers is that they are baffled where as the stock height ones are not, or atleast summit says they are not.
All in all, hopefully I will have more info on this subject soon! Wish me luck
Joel
Joel
Car: 89' IROC-Z
Engine: LO3
I ended up purchasing Billet Specialties VC's (tall). I have yet to put them on but I recently removed all emissions besides EGR...as thats the most important. I will take pictures when finished.
Car: 87 Iroc-Z
Engine: 5.7 350 TPI
Transmission: stage2 700r4
Axle/Gears: 2.73 for now
Check these ones out guys. Ive been searching for ones like this for a very long time, and will probably be buying then this week.
http://www.cfrperformance.com/product_p/hz-6512.htm
let me know what you guys think./
Oh and the ones listed right above those on the website have the provisions for the oil fill and pcv valve!
COTM Editor
Those are nice looking valve covers! I attempted to use a set of fabricated covers that had the internal gasket rail, and the front of the drivers cover would make contact with the postive post on the alternator. The external rail on the ones above might??? have enough clearance (but looks a little tight).
I would definitley pay the extra 95 cents to have the oil filler and pcv holes!!
Good luck and post pics, if you get them!!!
Car: 1987 IROC-Z Camaro
Engine: L98 5.7L TPI
Transmission: 700-R4
Axle/Gears: 3.27 BW
I'd buy the carbon fiber ones, then paint them so they look like unpolished aluminum.
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
I have a set that I am willing to sell. It comes with baffled gromets but only 2 holes...
Here is a pic..
Billet Specialties...
Used a scuff here and there. I had them ON, no problem, I just don't need them. After replacing my intake I just went with the stock ones. Just have other plans.
Trying not to hi-jack, but if anyone wants it its up for sale.
Here is a pic..
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
I ordered these out of the Classic Industries catalog, and they have the same amount of holes as the factory ones due.
The only thing I did, was to switch sides to make it easier getting to the oil filler cap.
Leon
Leon
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
you could always take them off and send them out to be powder coated. What a difference that makes. They come back better than new and give your engine a different look.
Car: 1987 Iroc-z
Transmission: Modified T-5 World class
Axle/Gears: 9 bolt borg-warner 3.45
I agree. I used to work in a powdercoating plant and it's a quick and easy way to make an old set look new. The color choices are very nice and diverse as well. While I was there I powder coated in almost any colour you can think of. The only thing that a powder coater generaly can't do without alot of expense is color match what is already on the vehicle. The coater can't mix the powder like paint, it comes from a supplier in the color requested. anyway these are my covers and engine:
I powdercoated the TPI plate in red and clear and I coated the valve covers in chrome black (smokey black) over a metalic silver. A number of brakets and the egr lines are coated in a semi-gloss black. (The plenum and runners are painted in Metallic graphite)
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i sandblasted my centerbolt valve covers and used plasti~cote chevy orange, everyone thinks they are powder coated, and the paint job has 25,000 miles/ 3 years on it and still is good, i also clean my motor every time i wash the car. I seen wrinkle finish on them to that looks good, you can always use black wrinkle and the follow up with any color you want for a sharp look to. You can always strip all the paint and polish or swirll up the natural metal then use clear cote motor paint for a natural look that wont tarnish. if thats not your taste you can find a 2 hole set one for the PCV and one for a combo breather/oil fill easy to find at jegs or sumit or your favorite autoparts store. It will take a year and 2 days to fill via the dipstick! Also there is an adapter to make old school valve covers fit a center bolt, but they are as much as i high quality set of valve covers and then you got to go buy valve covers
1992 Trans Am
May 10, 2023 07:19 PM
NBrehm
Aug 25, 2015 11:49 PM
Street Lethal
Aug 12, 2015 11:33 AM
