Plastics
Old May 2, 2001 | 12:35 AM
pookey's Avatar
Plastics
I know it was asked before but I never got an answer. I want to change my interior platics from gray to black. If I primer the plastic and use spray paint will it work? Or should I do the smart thing and get some penetrating dye.
Old May 2, 2001 | 12:56 AM
Ovrclck350's Avatar
I'd say it would work. I bought some Vinyl spray paint from a store and it looked so good, I actually covered up scratches on my front bumper cover. Can't tell it's there.
Old May 2, 2001 | 09:23 PM
86ZRICHIE's Avatar
make sure you clean it well, then use an adhesion promote like Bulldog, then spray the final color on it, you shouldn't need primer. I haven't used any primer and haven't had any come off yet. I'd recommend the duplicolor vynl/fabric high gloss black, it looks killer. Probably not good for the dashpad though, but that's what dashmats are for
Old May 3, 2001 | 02:30 AM
pookey's Avatar
What about VHT? Are they good or should I hunt for the duplicolor.
Old May 3, 2001 | 06:52 PM
86ZRICHIE's Avatar
VHT's probably good, the reason I recommend duplicolor is that it's all I've used and have had good results and it's easy to come by (most parts places or walmart)
the key is the adhesion promoter though
[This message has been edited by 86ZRICHIE (edited May 03, 2001).]
Old May 3, 2001 | 07:40 PM
pookey's Avatar
Richie, is this adhesive promoter a spray or does it have to be applied with a brush or something.
Old May 3, 2001 | 10:00 PM
86ZRICHIE's Avatar
it's a spray, the kind I use is called "Bulldog" it's in a purple can, usually you have to get it from an auto paint store, but it'll make paint stick to almost anything, i just used it to repaint some door mouldings so I wouldn't get door dings all up and down my car
While you're at the paint store ask them for a can of plastic prep, use that first, then a tack cloth, then bulldog then the paint
Old May 4, 2001 | 02:56 AM
pookey's Avatar
Again my ignorance surpasses me. What is Tack Cloth?
Old May 4, 2001 | 03:02 AM
86ZRICHIE's Avatar
lol, no worries. It's a cloth with a kind of sticky substance on it that grabs dust and dirt, 3M makes a good one, it can be found in the body section of most auto parts stores or even walmart. black & yellow plaid package. they work real good for dusting the interior too (you probably won't want to use armorall much after you paint them since they'll be real shiny anyway, maybe a sponge and soapy water every month or two with tack cloth when dusting is needed)
Old May 4, 2001 | 05:13 AM
sheet outta luck's Avatar
ive painted most of the trim in my S10 a different color, and i got the best results when i:
1. cleaned the plastic really good with a terry cloth towel and rubbing alcohol to remove any caked up armorall and oils
2. used the tack rags afterward
3. since i dont have a compressor, i had to use the spray paint cans, most cans say to shake for 1 minute...i always shaked about 2 minutes and for 10 seconds after every 30 seconds of spraying
the best spray paint ive used on plastic interior trim is Plasti-kote's "flexible bumper & trim color"
its only in a few colors, but it adheres excellent and dries to touch in 1-3 minutes
MrPackstin
Oct 25, 2017 08:09 PM
Twin_Turbo
Mar 14, 2016 10:10 PM
Night rider327
Sep 25, 2015 04:19 AM
Saxondale
Sep 15, 2015 06:42 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
