water spots in glass
Car: 88 trans am gta
Engine: 305tpi
Axle/Gears: 9 bolt 3:27
i have tried everything to try to get the water spots out of my t-tops and my rear hatch with no luck. i have tried waxing it, and i have also tried useing a real fine buffing compund with no luck. any sugestions?
thanks,
Brian
thanks,
Brian
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Re: water spots in glass
I don't know if it will work, but I use Bon Ami cleanser to clean all my glass. It is a powder abrasive, sold in supermarkets, and is "guaranteed not to scratch".. It's cheap enough and easy enough to find for you to give it a shot. Sprinkle liberally onto wet sponge, polish, then rinse with plenty of water.
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Try a little baking soda with vinegar and a low scratch pad.
Engine: 305tpi
thanks you guys. i will obviously try to keep everything off the paint, but if some of the vinegar and baking soda get on the paint will it hurt it? thanks
Engine: 305tpi
thanks for all the replys. i ended up getting them out with some fine steel wool with some buffing compound
RedLeader289
May 28, 2019 01:47 PM
