Painless Dent Removal
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Found this thread on my last car forum I browse from time to time. Maybe somebody will be interested, I sure was. The later video is better, turn up the sound.
http://mymonte.com/discussion/index.php?showtopic=21604
Car: 1989 Trans Am GTA
Axle/Gears: 9 Bolt 3.70
Re: Painless Dent Removal
Wow! I think I'm going to have to try that. (but on the family beater car first) Nice find!
Car: 1989 Pontiac GTA
Engine: 350 5.7 T.P.I.
Transmission: TH 700-R4
Is (airduster) the stuff you clean your keyboard and hard to reach places with??
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
Engine: LO3
Ouch, thats more of a crease. I would buy a new door lol.
I might try this myself tho. I have hail damage all over the hood, and dents on the door from other peoples doors.
Car: 1988 IROC-Z
yeah that was the plan anyways lol,but there a couple more dents that came with the car i can try to get out..
Car: 1991 Camaro RS
Transmission: 700R4 Auto
Axle/Gears: 1 legger 2.xx(needs upgrade)
adam when u try it let me know how it worked!.. are you home from school? i have seen a car that looks exactly like yours.. only thing i think i did see it say formula 350 on the side. but i thought i seen it at DD one night when all the kids were hangin out.
Engine: LO3
no im still in NH for school, but I have been home for the weekends a few times.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
Im gonna try it on my Jeep this weekend. Ive seen this way of doing it before and it will work. It just needs to be a shallow, not creased, larger dent. What im hoping ot get out it more of a wave in my driver door. Hopfully it comes out cause my Jeep is mint, and black of course.
Matt
Matt
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Ive heard/seen this work before. But it seems to work better on big "soft" dents that you'd make by leaning against a car or something. Im not sure it would work for dings or smaller dents.
I have a half dollar sized dent in my fender that Im going to try this on...hopefully it doesnt make my paint flake off. haha.
J.
J.
Car: 1989 Iroc rebuild
Engine: 355 carb'd
Transmission: 5spd
Axle/Gears: 3:08 pos for a while
still waiting to see if anybody has done it yet,and results?
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
i tried dry ice about two years ago on my stealth. i had few dents on the hatch. i never had the patience to wait for the dent to pull out but it did puled out about halfway and looked betteer
i really wish that i knew this 3 days ago before i started trying to pull the dent out of my door, now im running into all sorts of problems with the paint lol damn i wish i had this thread then lol
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Do this trick in warm weather (Or a warm environment). Its obvious that it works by expansion contraction principles, but also by the ammount of energy that can be worked upon it. If you start with a cold dent, then heat it for 1 minute with a hair dryer, it'll reach luke warm temp at best.
Also, I'd like to point out that those are dusters are NOT liquid CO2. If it was liquid CO2, it would spit out dry ice in an UPRIGHT position too. If you don't believe me, take the regulator off a CO2 tank and open the valve for a while (there's no detrimental effects, just don't do it in a closed room).
The ingredients used in air dusters today is usually tetraflouroethane, which will come out of the bottle at -27F. While dry ice is -109F. This is why the panel must be warm, not cold (above 60F) for it to work properly. Then, when heated with a hair dryer, it'll reach a much higher temp, lets say 90F locally for the point of argument. Then, thats a 117 temperature difference within seconds. That's a lot more energy enacted between the two points, as opposed to say a 57 degree difference (rougly 35-40F ambient temperature would get you this).
lol yeah i just painted it in august....some woman hit my car a week and a half after ipainted it...4 days ago i bondo'd and primered the spot, then yesterday i went to paint and the paint bit in really badly so i had to sand it all down again and try again today lol thankfully its fixed now but still, i coulda saved myself some time with this trick! lol
Car: 1987 Trans Am
Engine: 355
Transmission: t56
did you prime over the bondo?
yeah, doing this woulda saved you a lot of time if it actually works.
yeah i primed over the bondo and everything, according to the place ibought the paint from what happens when you apply new paint on new paint liket hat is you have to dust it on so that it stays dry, but if you apply it so that its wet then it'll 'bite' inand look like paint remover was thrown on it
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
yeah what happen to your paint when you tried painting it again is called "lifting" the paint is not cured still so when you hit it with new chemicals on top of it, it reacts looks just like you said, like paint thinner was on it,....as far as that vid goes, i work at a body shop, i wouldnt do that....but thats jus me
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Will this work with some dents? Probably so....it's the concept of heating and shrinking metal. Then again, you have to think what kind of car it is. The aveo's probably have some of the thinest sheet metal out....so it really wouldn't take much at all in order to remove a dent with this method. Just depends with what kind of metal your working with. Would the guys that know the skill of PDR do this technique? I doubt it....it would be so much easier to just put your tool in...and push it out.
Car: 1992 RS
I tried it out today and it somewhat works. the dents I have are not as bad but still not perfect. I think its worth trying.
Car: 1992 RS
I tried both. I already had a couple cans of compressed air and I went to Vons to pick up the dry ice. The thing about it is that you have to be patient. The effects for me were not as dramatic as the video but it looks better. I think the dry ice worked better, I heard a couple pings from it popping out. And sorry I didnt think about taking pics so I dont have any.
Car: 1992 RS
Car: 87 IROC Z28
i just wouldnt use it, my preference since i do body work...i understand how it works...but try it on a old skool car where the metal is as 5 times as thick as cars nowadays...wont work...but i dont have any dents in my car so im not to worried about using it, but if it work for you guys that are trying it, more power to ya.
Car: 91 RS
Transmission: 5 speed
Tried it on my Impala and my Camaro. I didnt heat it up before putting on the dry ice, but it worked for the most part. Didnt take it all they way out but looks a hell of alot better. Im gonna try and heat it up first and see if it makes a difference.
You guys are crazy if you care about your car. "heat the panel and then apply -109* ice?" Metal and paint have completely different properties and doing this can cause the paint to lift.
You can also remove a dent by applying extreme heat to the dent. I've seen it done, but every time, the paint was discolored from being burnt. Not how I would treat my car.
A dent is a place that the metal has been slightly or severely stretched. In a slightly stretched dent, the metal needs to be worked and reshaped back into it's original shape. It's the same for a severe dent, but they require more work. The problem with these tricks is the lowest part of the dent comes up, but the dent will never be completely removed. To test the theory of how metal works, take a soda can, carefully push it in until it holds the dent. Stick a pencil eraser in the can and carefully push te dent out. The dent will "pop" out, but the can still shows damage in the areas that was holding the dent to begin with. The same is true for car metal. It's heavier metal so the damage won't look as extreme, until you look down the panel and see that it's now wavy. Metal works like a liquid in that it gets displaced when hit and creates a wave effect. The metal needs to be moved back into shape or you have the wavy panel syndrome or worse, low spots that look like someone leaned against the car. To remove the low, you need to find the high and remove it also or the wave is on!!!
Car: 1992 RS
I did it today and it looks fine. And I care very much about my car, if you think the method is crazy then dont do it.
Car: 1989 Trans Am
Engine: 5.0 TPI
Transmission: 5 Speed Manual
Axle/Gears: Stock Rear End
im gonna try this with compressed air tomorrow on a small dent on my fender. ill take some pics.
Car: 1989 Trans Am
Engine: 5.0 TPI
tried to get some pics, couldnt really make out the dent. heating the dent with a heat gun on 6 for about 2 mins was enough to bubble the primer but it also got it to the temp so when it hit the air the dent pulled out. it took a few attempts but worked in the long run. cant say id try this on a nice paint job tho.
Also, what was up with that video claiming it was the same method as pdr, that just made the whole thing shout out
What do they charge, 50 bucks to push out a dent, why mess around with this crap?
Car: 1989 GTA
Sure, $50 isn't a whole lot considering fixing a part on a car. However, quite a few members on this board are in high school or college, and that $50 holds quite a bit more value to someone who makes say minimum wage on part time, compared to someone who makes even $20,000 a year.
Lol this is why I made my post, it's not dry ice that you're shooting at the dent, it's tetraflouroethane, which is -27F. The paint doesn't lift off if it's on there good. Also, while of course this doesn't completely remove the dent, not many people are going to look down the side of your car for dents. Even fewer are going to notice the waves. So for $3, a dent can be made much less visible, perhaps invisible to the untrained eye. That's $47 staying in your pocket (if the local shop does charge $50), which you can invest in fuel, ect.
Amen Brotha' Thread
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
[Sold] 87 TPI top end
hydrolic144
Sep 8, 2015 06:59 PM
