spohn red paint
Old Oct 30, 2007 | 07:17 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
spohn red paint
Anyone know how I can get some spohn red paint? I need to paint my x member and sfc's were they are welded.
Old Oct 30, 2007 | 11:00 PM
89importeater's Avatar
Car: 89 RS camaro
Engine: 454 swap in progress
Transmission: th400
Axle/Gears: 4.11
Re: spohn red paint
the spohn parts are powdercoated, i guess you would have to spray a couple of test panel with different kinds/brands of paint to see which one matches best
Old Nov 1, 2007 | 03:52 PM
85_ZED28's Avatar
Car: '85 Z28
Re: spohn red paint
maybe ask spohn?
Old Nov 1, 2007 | 04:12 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Re: spohn red paint
Originally Posted by 85_ZED28
maybe ask spohn?
second that
send an e-mail, theyll probably answer you back same day. I couldnt see them minding telling you what colour it is.
Old Nov 6, 2007 | 09:28 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: spohn red paint
Looks like its prob a close match with a JOLLY RED or BARRON RED powder.
Old Nov 14, 2007 | 12:29 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Re: spohn red paint
If you welded your crossmember, matching the color isn't your biggest problem :-) I'm probably reading that wrong though and you mean you want to paint the crossmember to match the SFCs... in any case, you'll probably have to repaint them entirely if you want an exact match.
Old Nov 14, 2007 | 07:11 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: spohn red paint
I cut an inch out of the center and moved the holes back an inch. Then I boxed it in again with 1/4 steel then mig welded it, just need to have it coated again. Im not sure what others have done with the same swap as mine, but im sure it probably didn't involve cutting a brand new spohn x member. If I would have know it wasn't going to fit i would have saved $200 and made one.
Old Nov 23, 2007 | 05:47 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
Re: spohn red paint
why doesnt it fit?
any pics?
interested.....
Old Nov 23, 2007 | 08:09 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: spohn red paint
No, I dont have any pics. It didnt fit, but not because of spohn. I have a ls1 t56 with a lt1 engine. It moved the tranny back farther. The mount for the ls1 tranny on a sbc doesn't exist yet.
Old Nov 24, 2007 | 08:44 AM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: spohn red paint
you swap tranns for the hydraulic clutch?
Old Nov 24, 2007 | 11:48 AM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: spohn red paint
Im using a lsx trans because I had a t5 before and its easier to use a t5 bell and clutch with a ls1 t56 then it is to swap in a complete lt1 style system. I get a few benefits now 1 being the t5 clutch and 2nd better upgradeability to a future lsx or lq swap.
Old Nov 24, 2007 | 12:15 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
Re: spohn red paint
so the t5 bellhousing and the t56 mate up without using any special pieces, or was there some fabbing involved.
real cool swap.
glad i asked......
Old Nov 24, 2007 | 04:57 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: spohn red paint
real cool swap.
glad i asked.....
Just need a mcloed adapter and pilot bushing. Have the drive shaft shortened and its good to go.
Old Jan 8, 2008 | 08:35 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: spohn red paint
A little late, but I'm touching up my welds now. I used Rustoleum Sunrise Red Gloss, # 7762 and it matches pretty well.
Old Jan 8, 2008 | 09:03 PM
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
Re: spohn red paint
Not to late, I still haven't painted and wont be until most likely April. Thanks for the info Im going to look into that.
Hawk312
Aug 22, 2017 08:55 PM
deracer
Apr 11, 2016 12:04 AM
kairles
Oct 26, 2015 09:13 PM
TheExaminer
Sep 6, 2015 11:40 PM
