how to smoke tailights
Old Nov 11, 2007 | 06:41 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
ok so i want to smoke my tail lights and front running lights.. what do i need to buy and what do i need to do? i have no clue on where to start.. and how legal is it?
Old Nov 11, 2007 | 06:52 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: how to smoke tailights
well i'm not sure about smoking the lenses but there are covers you can get to black them out. for smoking the lenses directly i don't know how you would do that. maybe paint them with translucent black? or tint? don't know. good luck though and hope you find the answer you are looking for.
Old Nov 11, 2007 | 06:58 PM
markymarco's Avatar
Car: 89 Camaro Convert,89 Camaro hardtop
Engine: 305 and a 357
Transmission: 700R4,T5
Axle/Gears: 4.10's and 3.43's
check out this thread https://www.thirdgen.org/forums/auto...ng#post2786475
also the helps alot to
Old Nov 11, 2007 | 07:24 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
there's stuff called VHT Nightshade. If your good with a spray can it'll work out really nice. there's alot of people who have done it do a search for it.
Old Nov 11, 2007 | 09:51 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Axle/Gears: 3:73
thanks guys i had not even though about searching, just figured i would ask first..
Old Nov 12, 2007 | 12:22 PM
subliminal's Avatar
The way you do it is you mix black paint with alot of clear then spray it
Old Nov 12, 2007 | 12:46 PM
Stephen's Avatar
Car: 87 GTA
I'll try to get a better pic of my smoked taillights, if you want...
you wanted smoked tail lights...i just had to do it!
Old Nov 12, 2007 | 02:11 PM
MNformula350's Avatar
I used VHT Niteshades on the Tail Lights, 3rd Brake Light, Front Side Markers and Front Signals on this 87 Iroc I built for a guy.
I also used it on my Front signals on my Formula
Old Nov 12, 2007 | 03:05 PM
ewwewwnotme's Avatar
Car: 88 Iroc
Engine: L98 5.7 LITER V8 TPI
Transmission: THM 700R4 Auto
Axle/Gears: 2.77 Posi. Lim Slip
Heres a guy who did his taillights with black paint and some clear mixed.
http://www.superchevy.com/technical/...al/index1.html
Old Nov 12, 2007 | 08:00 PM
1984Z28HO's Avatar
Car: 1985 iroc
Engine: 305 H.O.
Axle/Gears: 3:73
cool thanks guys, i like the idea of mixing some black with the clear.. sounds like a good idea i'm going to try that..
Old Nov 13, 2007 | 05:18 PM
Charged350's Avatar
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
thats what i did...it jus takes a good painters hand to spray it and you have to prep the lights correctly...otherwise...your gonna get stuck with a lot of work to sand it back down....the other question is how dark you wanna go...
Old Nov 13, 2007 | 09:36 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
Charged350-- How well does the light show through? Do you have a night pic with the parking lights on?
Old Nov 14, 2007 | 05:52 PM
Charged350's Avatar
Car: 87 IROC Z28
well you can warry the darkness with how much black you put in the clear and how many coats of it you actually spray on the lights, no pics of it at night but the running lights during the day are kinda hard to see, but once you hit the brakes you can see it perfectly almost...at night i dont think it should be a issue, i had my cherokee done for almost a year now, never heard any complaints from the po po, and i live in NY where they are absolutelly illegal....
Old Nov 14, 2007 | 08:45 PM
What I did when tinting the lights was shine a flashlight from behind after every coat starting with the 3rd, to get it to where I wanted it, and where I wouldn't get hassled.
Old Nov 14, 2007 | 10:04 PM
FYRCHKN's Avatar
Engine: LT-1
I think I like the black/clear mix look better than the VHT. The shine makes all the difference.
What kind of mix ratio did you use with the black/clear?
Old Nov 14, 2007 | 10:23 PM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
I want to try this on my 82 trans am tail lights lets hear more!
Old Nov 14, 2007 | 10:34 PM
brandotron's Avatar
Car: 2002 Camaro z28
Axle/Gears: 2.73 stock, stock, stock
Goddamn that's a nice formula. Those black turn signals really make the red pop. Any night pics?
Old Nov 14, 2007 | 10:56 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Alternating smoked T.Lamps, VHT & alot of masking!
Old Nov 15, 2007 | 07:22 PM
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Are those pop up T-tops? Never seen that before. BTW great job on those tail lights. Looks real nice.
Old Nov 15, 2007 | 07:32 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yep,they are C&C t-tops.
Old Nov 16, 2007 | 12:09 AM
Thanks!
No night pics, but here is one taken inside a parking ramp during the day with the lights on:
Old Nov 17, 2007 | 07:14 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
those tailights look awesome! how exactly did you get that patten in the lights like that? and those t-tops are awesome! I've actually been wanting my t-tops to do that but i didnt think those type exhisted. where you find them?
Old Nov 17, 2007 | 08:45 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
This is what it took to achieve the checker board effect.All the blue squares are masking tape.It was individually cut to fit the small grid sections(squares).Afterward you just spray your prefered color.As for those C&Cs.These were an aftermarket conversion by Cars & Concepts(C&C).They went out of business yearssss agoooo.They wont fit the GM tops either.C&Cs are about 2 inches shorter.
Old Nov 27, 2007 | 06:55 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
HEY IF YOU GUYS ARE LOOKING FOR BLACKOUTS IVE GOT FRONT HEADLIGHT BLACKOUTS FOR A 85-87 CAMARO THEY MIGHT WORK ON NEWER AN OLD ONES NOT SURE , AN THEIR NEW IN THE BOX NEVER USED JUST LOOKT AT , PM IF INTERESTED
Old Nov 29, 2007 | 02:40 AM
Red92Bird's Avatar
Car: '92 firebird
Engine: 305 tbi
Transmission: 700 r4
Axle/Gears: 10 bolt 3.42 gears with eaton posi
anyone have pics of the rear lights on a newer firebird done? and how about anyone with 91-92 front turn signals/lamps painted?? thanks
Old Nov 28, 2008 | 09:52 PM
88_thirdgen's Avatar
Car: 88 camaro
Engine: v6 MPFI
Transmission: t-5
do you have any pics of your taillights without them being on i want to see how they look with out them on and this might be my next mod
Old Nov 28, 2008 | 11:29 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Wow! old post.Well this is the best pic i have.Does'nt really detail much though, but if your behind me you would see the checker board pattern easy.
FormulasOnly
Jul 23, 2018 08:47 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
90formulaVortec
Sep 7, 2015 06:54 PM
Accerrito22
Sep 5, 2015 09:34 PM
