Post pics of stripped interiors!
Old Nov 20, 2008 | 03:41 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Transmission: Built 700R4
Axle/Gears: Unknown 9 Bolt Posi, 3.73s
I've been thinking about stripping the interior of my GTA. The interior is pretty much crap. I only paid $1250 for it though.
I wanted to strip it out, put down black carpeting and headliner, put in 2 black racing seats, and spray paint the grey interior plastics black. (Flat black is the theme) I wanted to build a custom console just big enough for the shifter and locate the window buttons to a panel, attached to the dash.
I am aiming for a race car, more brutal looking approach to the car. I want to remove the rear seats and make room for a small roll cage.
So post some pics of stripped interiors, preferably 'birds.
Old Nov 21, 2008 | 10:29 AM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
Re: Post pics of stripped interiors!
This is the best I could do....sorry but I'm not willing to strip it back down to take a better pic, lol. You understand right?
Old Nov 21, 2008 | 11:15 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
looks good, I want to strip the interior, remove any deadening material, and redo it black, and flat black. (Theme) Black carpet btw... lol
How hard is it to remove the interior? Anything I should no, concerning wires or anything?
Old Nov 21, 2008 | 11:49 AM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Transmission: 4 Speed Auto 700R4
Well I have not remove 100% of my interior but for the picture up above if that as much as you want out then it's pretty easy your just be removing the center console, then the seats and then the carpet give or take the door guard things. I say the only thing I had a problem with was accidently unbolting the shifter and not just the center console. Now if you’re going for the back you'll have to remove the side plastic panels.
Old Nov 21, 2008 | 01:18 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
I can't remove the back seats, how do I go about doing this?
Also the back seats hook up to those black metal pegs attached to the sides. I can fold the seats down but what tool do I use to remove the black pegs? I can't remove the platic panels without this piece out.
Old Nov 21, 2008 | 08:04 PM
RS Reaper's Avatar
Car: 90 Camaro RS
Engine: V6 3.1 MFI
Originally Posted by Karps TA
Theres a nut on the outside bottom corner of the seats(lower right side for drivers, lower left side for pass). I think it's 13mm. Undo that then pull the seat towards the outside to get it off the pivot rod. real easy, just sometimes the nut is hidden by the fabric
Originally Posted by lonsal
You didn't say if you have a solid rear seat back or a split style. They both have a hinge that is mounted to the seat back with a threaded stud pointing down. It has a 13 mm nut attaching to it from below. You have to remove the bottom seat cushions first to ge to the nut. The solid rear bench has just the two hinge bolts to be removed. The split bench style is removed by removing the nut, then twisting the seat back while folding it forward. This gives you clearance to pull it off the post that is welded to the center hump. I hope this helps, Lon.
It's fun to copy and paste then to write it all out.
Old Nov 21, 2008 | 09:26 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Thanks I'll have to try that tomorrow, I have the split seats.
Old Nov 22, 2008 | 10:22 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Here's mine. this one is pretty old but nothing has changed.
Old Nov 22, 2008 | 10:40 AM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
thats awesome, thanks
Old Nov 22, 2008 | 12:34 PM
IROCtheThird's Avatar
Car: '89 IROC-Z
Engine: LSx
This is the best I can do, this how the sport coupe looks right now, it was completely gutted except the plastics.
Old Nov 22, 2008 | 01:09 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
Looks good, what ripping the carpet up straight forward?
Update: got the rear seat cushions out, now working on the seat backs.
Old Nov 22, 2008 | 01:15 PM
Car: '89 IROC-Z
Engine: LSx
The carpet was the best part, once the seats, center console, kicke/rocker panels were off I was able to just literally rip it out. Oh yeah, my Sport Coupe paid me 20+ dollars in loose change
Old Nov 22, 2008 | 01:25 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
My center console is just trashed so I'm just going to junk it, sorta sad I bought a GTA with all those "luxury" options and I'm just gonna rip them out. lol
Old Nov 22, 2008 | 01:42 PM
Car: '89 IROC-Z
Engine: LSx
Just find another center console thats the same, or just get a nice one and you can cut out the spots for the power windows, trunk release.
Old Nov 22, 2008 | 04:04 PM
Z2EIGHT's Avatar
Car: '92 Camaro Z28
I think I'm going to get an aftermarket one, I saw this and I liked it.
http://www.hurst-shifters.com/hurst-...CHET-SHIFTER_3
This will take the place of my whole console right? I want to free up some room up front.
Old Nov 25, 2008 | 01:07 AM
allenfre's Avatar
Awww.. What are you planning to add on this? Headunits? Leather/vinyl seats?
Old Nov 27, 2008 | 09:28 AM
crazyman3737's Avatar
Car: 1991 Trans Am GTA
Axle/Gears: Yukon 3.73 posi
Old Nov 29, 2008 | 12:45 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
wow, those floorpans are mint!
Old Nov 29, 2008 | 01:35 AM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
preparing for a new carpet (one in better shape anyway ) after cleaning up most of what the previous owner(s) left behind.
1992 Trans Am
May 10, 2023 07:19 PM
aaron7
Aug 17, 2016 06:02 PM
neekolzun
Aug 24, 2015 04:59 PM
Linson
Aug 21, 2015 02:12 PM
1985chevydude
Aug 20, 2015 12:29 AM
