T-TOP water spots/etching??? HELP!!
Old Feb 13, 2008 | 02:50 PM
92z28tpi's Avatar
Car: '92 Z28
Engine: 5.0l TPI
Well after recently selling my Corvette, the sports car withdrawl really set in. I had a 91 Z28 before the Vette and really liked that car. A few weeks ago a wholesaler I know tracked down a 92 Z28 (blue) for me with 78k on it in near mint condition. Not a speck of rust, chips, tears, stains, etc. Perfect car even with the window sticker. So I consider myself very lucky and happy. I'd post pics but the weather here in NY resembles Antactica right now...so pics will be posted soon. There is one cosmetic issue with this car though. The T-tops have what appear to be permanant water spots on them. I've tried the vinegar thing and a few other common remedies with no results whatsoever. Hopefully members of this forum can shed some insight on this problem. I've had about 10 Z28's and Trans Am's but none of them ever had this problem. The T-tops were always nice black and shiny. These are dull and frankly look awful. The tops on it do not leak so I'm not too keen on the idea of replacing them but I will if neccessary. Any help or ideas would be beyond greatly appreciated. Thanks.
Old Feb 13, 2008 | 03:14 PM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Re: T-TOP water spots/etching??? HELP!!
Top's plastic or glass? I've had good luck with clay bar removal of hard water spots on glass tops.
Old Feb 13, 2008 | 03:18 PM
92z28tpi's Avatar
Car: '92 Z28
Engine: 5.0l TPI
GLASS T TOPS
Old Feb 13, 2008 | 03:22 PM
Wadebryant's Avatar
Try clay bar + application lubricant.
Old Feb 13, 2008 | 03:26 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Acid rain in your part of the country and they are etched in and may be impossible to remove.
92z28tpi's Avatar
Car: '92 Z28
Engine: 5.0l TPI
Thanks. I'll try the clay bar. Keep the ideas coming =)
Old Feb 13, 2008 | 05:31 PM
Wadebryant's Avatar
http://www.eastwood.com carries a product that you can apply to glass to remove scratches. Part #s, 40030 and or 12843. It might be usefull if the glass is damaged in some way by pollution or other air borne nasties? I've used a similar product for light scratch removal, sold by the Snap On guy's. Dont have the product # in front of me.. but it works the same way. A little more agressive than the clay bar.
Good luck
Old Feb 13, 2008 | 05:34 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
My Acrylic t-tops have water spots and etches that won't go away and what I'm doing is using the stuff they use to darken tailights to restore it.
Old Feb 13, 2008 | 05:45 PM
Mike-in-Orange's Avatar
Car: 1992 Camaro RS
Engine: 3.1L
Go to a paint and body store and pick up some Meguiar's #4 Heavy Cut Cleaner. Put some on a terry cloth towel, wet it just a little with some glass cleaner and have at it. Go over it all again with a light spray of glass cleaner and a clean terry towel. If that doesn't get rid of them they may well be etched in and virtually impossible to eliminate. If you have a DA polisher, or even a rotary, you can use those with the #4 also, just keep the speed on a rotary low and stay away from edges - best to tackle those by hand application.
Old Mar 16, 2008 | 10:05 PM
GMODUDE's Avatar
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
what about on fiberglass ttops. mine look terrible but my car is perfect other then the tops. I even tried to buy new tops from hawks i orderd glass ones for over 200$. the glass was in perfect shape but the plastic side and the pins were awful and crack old and peeling. please help would really like nice ttops but am afraid to buy tops due to past experiences.
Old Mar 16, 2008 | 11:54 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
Zaino bros has a glass specific product just for what you are dealing with. i have used it myself and the stuff is KILLER!!!! it will take out the spots within a few mins and the glass will be slick after.
sheachopper
Jul 31, 2019 11:27 AM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
