easy gauges
Old Feb 27, 2008 | 09:46 PM
Grizzle B's Avatar
Car: 1984 Camaro Z28
Engine: '92 LT1
Transmission: 700R-4
Axle/Gears: 3.73 factory posi. disc brakes
easy gauges
is there any way of find white faced gauges that will either bolt in. (that cost less than $400) or how to put new aftermarket gauges in my dash. I only need a gas gauge, tach and speedo
Old Feb 27, 2008 | 10:03 PM
berryghardwick's Avatar
Car: 89 IROC-Z
Engine: 89-TPI 5.7
Re: easy gauges
I seen some white face overlays for the 82-89 Camaro on ebay.
Old Mar 5, 2008 | 02:37 PM
ScottyB724's Avatar
Car: '91 Camaro RS
Re: easy gauges
Here's some: http://cgi.ebay.com/ebaymotors/82-89...spagenameZWDVW
Or these: http://cgi.ebay.com/ebaymotors/90-91...QQcmdZViewItem
Old Mar 5, 2008 | 09:40 PM
Grizzle B's Avatar
Engine: '92 LT1
Re: easy gauges
has any one put aftermarket gauges in there dash? that is what I want to do. I just want to knowhow hard it is
Old Mar 6, 2008 | 05:51 PM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Axle/Gears: 9 inch/spool/3.70
Re: easy gauges
I did mine. I took a dremel tool and opened up the factory panel just a little and slid the gagues and lights in.
Old Mar 6, 2008 | 11:13 PM
Grizzle B's Avatar
Engine: '92 LT1
Re: easy gauges
wow those look amazing!!! so just radius the holes and slide in the new ones?
Old Mar 7, 2008 | 03:27 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: easy gauges
BlueBeast that looks real cool, how hard/whats involved in the wiring/connecting these new gauges to our wiring harness?
Old Mar 8, 2008 | 08:19 AM
BlueBeast's Avatar
Car: 1985 Camaro
Engine: 565 BBC
Transmission: Glide
Re: easy gauges
I just opened up the hole just a litte with a dremel, I used the sanding wheel that comes with them until they just slid in made them a litte tight so they wont come out. Then I took some ATV gasket stuff and sealed them in. The wiring isnt in with the factory wiring its all independent. Its very easy to do ground, light, ignition, and depends on what gague for the rest of the wires. I did take out the plasctic housing that the factory gagues push into. I am somehow not getting emails that you guys are posting back so if yuo dont hear from me PM me or email me, but I will check back often.
Bubbajones_ya
Jul 6, 2024 08:32 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
TrevinE
Sep 14, 2015 03:20 PM
86IROC112
Sep 11, 2015 04:04 PM
