Bringing shine back to worn GTA crosslaced rim HELP!
Old Jun 13, 2008 | 09:06 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
Ok so my 88' Trans Am came with GTA charocoal rims on it. But my dad decided to clean them after sitting in the barn all winter with a small sos pad and left small scrathes on the polished lip causing them to look dull and faded. What can i use to get the surface scrathces out and make them look shiny and bright again? Also how hard is it repaint them youself. What grit sand paper will i need? any adive is appreacited!
Old Jun 13, 2008 | 09:53 PM
Poject '86's Avatar
Car: 1986 Firebird
Engine: V6
Transmission: Automatic
Re: Bringing shine back to worn GTA crosslaced rim HELP!
Try this link.
http://www.gmtips.com/3rd-degree/dox...els/wheels.htm
Hope it helps
Old Jun 14, 2008 | 08:41 AM
Engine: Vortec 357
Originally Posted by Poject '86
wow when i get some free time i may just have to try that. Thanks for the info!
Old Jun 15, 2008 | 09:51 AM
Engine: Vortec 357
Ok well i just recieved my other crosslaced rim from Foward540 yesterday. Came off an 86 T/A that was in a junk yard so the rim was very dirty and even has small rust dots everywhere. Cleaned it the best i could but how can i get those dots off the polished lip without stripping it? ill take a pic so you all can get a better look at the rim.
Old Jun 15, 2008 | 12:48 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
If you don't want to mess with the hassle of getting the tires and valve stems removed then check out what I did a couple of weeks ago with my newly acquired cross laces:
http://www.austinthirdgen.org/forum/...showtopic=3437
The first set of rims I stripped/sanded were a major PITA and took forever because I used the sanding technique. They were also the "salad shooter" Firebird wheels.
Old Jun 15, 2008 | 07:31 PM
Engine: Vortec 357
i think ill take that route. Rims look great by the way. How much was the stripper?
Old Jun 15, 2008 | 07:54 PM
FYRCHKN's Avatar
Engine: LT-1
I think it was around $5-$6. The brush was about 50 cents. I bought 3 brushes but only used one.
Old Aug 19, 2008 | 11:13 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Did you mask the gold painted part?
lee01
Apr 9, 2016 01:56 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Reddeath210
Oct 6, 2015 08:20 AM
backtothe80s
Sep 5, 2015 12:39 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
