Cleaning/polishing tail lights and fog lights
Old Jul 17, 2008 | 11:27 PM
K.I.A.'s Avatar
Car: 1991 Camaro
Engine: 305 TBI
Transmission: 7004 R4
anyone know if those metal armor light polishing kits are legit? or just blowing smoke
Old Jul 18, 2008 | 10:53 AM
Realmac4's Avatar
Car: 1991 Z-28/ '94 Impala SS
Engine: 355 TPI/ 350 LT-1
Transmission: T-56 in both
Axle/Gears: 3.73 / 4.56
Re: Cleaning/polishing tail lights and fog lights
No not really but try sanding them with 1500 grit and clear coating them, they look great
Old Jul 18, 2008 | 08:35 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
For light scuffs and scratches on plastic you could try http://www.meguiars.com/?clear-plast...Cleaner-Polish or a similar product. It's cheap and does help minor cosmetic issues. If you have significant damage, then a solution like Realmac4's would be the answer.
Old Jul 18, 2008 | 08:47 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
clear coating them
Really? Never would have thought of that.
I'd just "Flitz it". Some people sand their molded lettering/numbering off the lights with 800 grit or so and then wet sand with 1500 and polish just like paint. The ones I've seen like that look great.
Old Jul 19, 2008 | 08:52 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
i started cleaning black tape off my tail lights . previous owner tried to make them look like grids . after cussing with mineral sprits 2 hrs. finally got all glue off . still did not look right , could see tape marks . had a can of brasso metal polish on my work bench , remember i used it on a plastic watch crystal . tried it with a sonic scrubber ( xmas gift ) . OMG , what a difference . turned out great , i even took off stock horz. black stripe ( r/s lens ) , imo looks great . worked for me . good luck .
Old Oct 15, 2009 | 08:56 PM
Jimmy D's Avatar
Car: Camaros and Suburbans
Engine: V8's
I've used a $19.00 kit, (Pep Boys), made by 3M...
It comes with everything needed to do 2 lights...
Although I actually intend to replace the front and rear lighting after I paint the IROC, I wanted to post some pictures of how well this kit could work for those of you who intend to keep the lighting that you already have. I've used this kit on the plastic shell that covers the headlights on both of my Suburbans with great success!
Here is - before...
During...
and After...
The whole process to do both front lights took me 30 minutes, maximum.
Where the instructions called for the use of water during the next to the last stage in this kit - I decided to use Windex glass cleaner, (it just made sense to me).
Have fun...!
Old Oct 15, 2009 | 09:14 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Can you tell me the grits that kit has for i could do that to my lights but with the plastix polish
Old Oct 15, 2009 | 09:38 PM
Jimmy D's Avatar
Engine: V8's
Sure thing,
The "Sanding Discs" are 500 grit and the "Finishing Discs" are 800 grit.
Old Oct 15, 2009 | 11:09 PM
91whtRS's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Borg Warner T5
Here is what i did on my DD 4th gen, i used 800 grit, then 1500 grit, then Duragloss plastic polish, you water sand the lenses by the way. If they arent bad, you can just use the plastic polish by itself.
Attached Thumbnails Cleaning/polishing tail lights and fog lights-before-after.jpg
Old Oct 16, 2009 | 10:22 AM
1Aauto's Avatar
Former Sponsor
The headlight polishing kits work well but it's a temporary fix. If your lights are oxidized the kit will clear them up for a few months,but it'll return.
Old Oct 16, 2009 | 05:37 PM
Thirdgen Ranch's Avatar
Former Sponsor
Car: Too many
The best thing for tail lights is to wetsand and buff them. Use 800/1000/1500 grit paper and then buff them and they'll come out looking like new.
Old Oct 16, 2009 | 06:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Originally Posted by Jimmy D
Sure thing,
Thank you i am gonna do that with mine
Old Oct 16, 2009 | 06:59 PM
Jimmy D's Avatar
Engine: V8's
Sure thing, you should be happy with the results. Just be careful of the body edges that surround the lens while you're working on it.
Like I stated before; because of the overall condition of my lights, I'll be replacing them when I paint the IROC. I just wanted to post this to possibly help some other members - every situation is different.
383cam
Sep 9, 2015 06:01 AM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
TBRays98
Sep 6, 2015 05:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
