poping the hood problem
hey guys, i have a situation that must be solved once and for all. well i know many of my fellow thirdgen buddies all have the same problem. everyone has a problem with poping their hood. after pulling the hood cable thing the hood doesnt pop up. you ussually have to play with it and try to get it to pop up. now i tried rasing the bumbers but that didnt help much. now if anyone knew what the solution is, or has any tips, i would appreciate it. thanks
dozer80464@aol.com
dozer80464@aol.com
Car: '89 TA
Engine: LB9
Transmission: M5
What worked for me was adjusting the actual latch and bar that it latches onto. I think it's all using a 10mm socket. The bumpers only affect how the hood rests, I think
http://www.tcnj.edu/~esposit3
https://www.thirdgen.org/rides/index...ew&rideid=1137
Member of FBS, The F-Bod Squad, 3 guys so far and I don't think we're growing
- '89 Trans AM, 305 TPI, 5-spd
- '86 Firebird, 2.8, Auto
Car: 1992 Camaro Z28 & 2k3 Cadillac CTS
Engine: LB9
Axle/Gears: 3:43
well i had the same problem with my hood and i just sprayed some liquid wrench all over the linkage of the release and i havent had that problem since
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
to get the hood to pop you have to push down above the latch and shimmy it side to side. I had this same problem and it was alingment related. if I ever had a problem I just pushed down over the latch and to the right and it would pop.
James
James
I will do that now (WD40).
My hood you have to hit gently until it rises.
1992 Pontiac Firebird (stock)
- 305ci V8 TBI / Automatic Trans / Every option, excluding leather
- Killer car audio system:
- Aiwa CDC-MP3 head unit
- Rockford Fosgate 360a2 amp
- pair of 12" MTX Thunder 5000s in a custom box
- Pioneer 3-way 6x9s, soon to add more more more!
I would like to slap people that use WD-40. It is great for cleaning and that is it. Have you ever watched the commercial for it? If you spay it on oil it will take it right off. It is glorified kerosene! Use some silicon lubricant or something that will creap and has lubricating properties. If you cover it in WD-40 it will work until the grease u freed up is washed off.
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I took the hood latch off and cleaned it with brake cleaner. I then smeared lithium grease on all the moving parts and reinstalled it. It works like a charm. I didn't have to adjust anything, over time it just gets gummed up and needs a good clean.
Street Lethal
Apr 30, 2019 12:14 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
