Removing side trims.. Need some tips on removing residue
Old Aug 28, 2008 | 01:53 AM
BladeX10's Avatar
Car: 1991 RS v8
So i just now noticed on my Camaro that 1 side has trims and the other side doesn't.. So i had a small debate with myself whether to keep the trim and add it on the side that doesnt have it or remove it all together.. I decided to go with the clean no trim look.. So i took off the other trim. Now heres my problem.. Theres a crusty solid residue left over and i dont know how to get it off. I tried to scrape it off with a flat head screw driver but the stuff is too thick and i dont want to risk scratching my paint even more. I want to know some SAFE tips on how to get rid of this stuff without messing up the paint.
Thanks!
Old Aug 28, 2008 | 08:02 AM
IROCDU's Avatar
Re: Removing side trims.. Need some tips on removing residue
heat gun is your friend.
Use a heat gun to where it gets all gooey, and then scrape it off
Old Aug 28, 2008 | 11:06 AM
Greg '85 T/A's Avatar
Car: 1985 Trans Am/WS6
Engine: 5.0 TPI
If you can soften it up with the heat gun, go at it with some WD40. Keep the WD40 away from the heat gun, ok?
Old Aug 28, 2008 | 02:04 PM
BladeX10's Avatar
Car: 1991 RS v8
Call me stupid but what is a heat gun? Lol.
Old Aug 28, 2008 | 02:24 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
like an industrial strength hair dryer . good luck.
Old Aug 28, 2008 | 03:52 PM
jaykar's Avatar
Car: 87 Iroc Showcar - Saturday Nite Hun
Engine: 383 4-Bolt Truck Hyd Roller MiniRam
Transmission: B&M 700R4 - Edge 3200
Axle/Gears: BW 9 Bolt-TA Cover & Stud Kit - 3.2
WD-40
Spray on, let sit, couple apps, wipe off.
Works great on all adhesive residue.
Flat head screwdriver---Whoooo.
Give me a hammer,crescent wrench,Bailing wire
Duct tape and WD-40 and can fix anything.
Later
Old Aug 29, 2008 | 10:52 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I use Dupont 3812 Enamel reducer. It's the stuff we use in body shops to break down molding glues for removal before paint. I still use it today. You can get it at NAPA and sometimes Carquest. Don't worry it will not harm the paint at all and it works wonders. Its the best stuff out there for what you are trying to do. If you brought your car into a shop that is what they would use on it.
Do not use a screwdriver to scrap!! Use a plastic or nylon scaper they will not scratch your paint.
Old Aug 30, 2008 | 01:51 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
we got this stuff at the garage where i work called wipe and wash does wonders for removing crap off of your car dont touch the paint either i think its made by dupont
Old Aug 30, 2008 | 05:10 PM
BladeX10's Avatar
Car: 1991 RS v8
WD 40 isnt working too well. lol.
I found this crap at Kragen for like 2 bucks.. Its suppose to help remove residue.. Ill give that a shot next.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
Hello, Michael
Aug 20, 2015 03:19 PM
Street Lethal
Aug 14, 2015 08:25 PM
3rdgenparts
Aug 8, 2015 07:09 PM
3rdgenparts
Aug 5, 2015 11:57 PM
