engine bay paint
Old Sep 1, 2008 | 02:35 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
engine bay paint
What is a good kind of spray paint to use is good? Anyone have a nice white that they used? Name of paint?
Old Sep 1, 2008 | 04:48 PM
87_GTA_5.7's Avatar
Car: 1987 Pontiac GTA Trans Am
Engine: Basic Stroked SBC..383
Transmission: PerformaBuilt 700R4 3000 Stall
Axle/Gears: Moser 9in. 3:70s
Re: engine bay paint
Spies Hecker paint...base coat - clear
Old Sep 1, 2008 | 09:02 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
id go with a dupli-color high heat (gloss black)paint just be sure u scuff the original paint so it sticks and doesnt chip off
Old Sep 1, 2008 | 09:15 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Regular old Tremclad spray paint.
Old Sep 1, 2008 | 09:24 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Have a pic of gloss back on one? Debating between white and black.
Old Sep 1, 2008 | 10:23 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
I just painted mine.I was tossing up between gloss and satin.Outside will eventually be black so I figured glossy would match exterior better.First pic is a little blurry.
This was outside today,sun was bright kinda bleached out the reds in the pic but it does shine.
I just used single stage enamel.Bought it at Tractor Supply for about $30 a gallon.Obviously I can't speak of durability but I think it should do fine.
Old Sep 1, 2008 | 10:51 PM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Yes, looking good. Is the frame gloss black also?
Old Sep 2, 2008 | 06:12 AM
wvabreeze's Avatar
Yes
Old Sep 2, 2008 | 07:10 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I vote either Duplicolor Semi-Gloss black engine paint in a spray can, or Eastwood Underhood black.
Im not a fan of high gloss under the hood, but if you can lay it well, and things are smooth, it looks good like wvabreeze's car. Im also not going for a show finish just because im too lazy to keep cleaning it. So the black made sense for me again, because if something gets screwed up, I just hit it with a spray can to touch it up. Like when I spilled brake fluid while bleeding the clutch. I scuffed the ruined paint and just hit it with spray can. Done and done.
As for color...I like my engine bay's black no matter what the color of the car. Just shows off the other parts well, and the black goes with whatever color the car itself is.
For instance...
Here is spray cans of the semi gloss engine paint on my black 87.
And here is my blue 86 with eastwood underhood black sprayed with a harbor freight gravity feed spray gun...came out much nicer.
If you are going to go with white, you'll need to do some more prep work, and probably do a good coat of primer. Black covers very easy..and also masks some not so nice areas
J.
Old Sep 2, 2008 | 10:34 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Hey ghettocruiser, are those gravity spray guns pretty easy to use?
Old Sep 2, 2008 | 11:36 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
If the bay is painted black and the exterior will be a color other than black, does the cowl area get the black also or is it the exterior color?
Old Sep 2, 2008 | 12:13 PM
Screamin86's Avatar
Car: 86 Trans Am,03 Yukon,92 Z28
Engine: 5.3, 5.3, lb9
Transmission: th350,4l60e,700r4
Axle/Gears: 3.73,3.73,2.73
whatever you want really both my thirdgens have black painted cowl
Old Sep 2, 2008 | 12:21 PM
Car: 86 Trans AM
VERY easy. I never used one before. Eastwoods paint has the thinning directions on it. I just picked up some thinner. Followed the directions.
To set the gun up, honestly, I just played with the dials on the gun while spraying on a piece of cardboard. You'll know when its right. Spraying it soooo nice. No runs, no build up, none of the crap that comes with spray cans. It covers so much easier. Atleast in my experience. It dried pretty fast as well.
As for the cowl question...I painted mine black. You cant really see it with the hood closed, so I figured just spraying it black to match everything else was the easiest cleanest route. i like it. I chose to leave my rad support and everything forward body color. Mostly because thats easy to paint even with the motor in the car, where as the engine bay is a pain to get when the motor is in.
J.
Old Sep 2, 2008 | 01:41 PM
wvabreeze's Avatar
I had to touch up a couple of places already putting the K-member back in and banging the sway bar around trying to install it.I just sprayed it with Rustoleum from a rattle can.For small nicks it looks alright.
Old Sep 2, 2008 | 04:42 PM
87transGTA's Avatar
Car: 87 GTA
no i dont sorry but on google there is a couple of them on google but the cars are red with black engine bay u could just do the fender wells black and leave the rest white
Old Sep 2, 2008 | 05:57 PM
Firebat's Avatar
On a similar subject: Is there a spray paint that doesn't rub off when anti-freeze is spilled on it? I know clear spray paint helps a little bit.
I painted my engine bay with a gun so I don't have the problem but the engine itself(valve covers, intake manifold) is just spray painted so it does have this problem.
Old Sep 4, 2008 | 03:43 PM
87transGTA's Avatar
Car: 87 GTA
idk about paint rubbin off if you spill anti-freeze on it hasnt happened to me,did you scuff what you were going to paint befor you painted it so u can get a better adhesive with the metal and the paint and u could use a primer thats intended for high heat
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
