Water Spots from Hell...Help Please!!!
Old Sep 12, 2008 | 01:46 PM
91_RED_Z28's Avatar
Car: 1991 Camaro Z28 TPI
Engine: LB9 SBC 5.0L 305ci
Transmission: 4 Speed 700R4
Axle/Gears: Detroit Locker w/ 3.26 Final Gears
I had left my 91 Z28 out in front of my parents house while I was away and when I came back i noticed that there was alot of water spots all over the the hood and the entire right side of the body, I figure a good car wash and wax will get rid of them...nope, come to find out that not only were they staind, but they pretty much got cooked into the clear coat! I have tried alot of things to get them out, is there any way to remove these damn spots without having to do an entire re-clear coat?
Old Sep 12, 2008 | 03:19 PM
Outlaw28's Avatar
Car: 1986 camaro z28
Engine: 350sbc
Transmission: TKO 600
Axle/Gears: stock axle with 4.11's
Re: Water Spots from Hell...Help Please!!!
you can try doing something simple and get some detail spray and see if that takes it off if not....id get some light duty polish and start buffing
Old Sep 12, 2008 | 03:34 PM
91_RED_Z28's Avatar
well that is our next plan...a good friend of ours owns a detailing shop and he is going to try that! i hope it works!
Old Sep 12, 2008 | 05:37 PM
Little Tim's Avatar
Sounds like acid rain. You may have to lightly sand before buffing.
Old Sep 12, 2008 | 05:43 PM
91_RED_Z28's Avatar
Well I sure as hell hope not, but luckily we are getting a new garage soon, so once i do get it fixed...it will not happen again! I hope...
Old Sep 12, 2008 | 05:46 PM
Little Tim's Avatar
I've removed acid rain marks several times. Every time they looked like water spots but you could feel them and nothing would taken them away. I started by buffing but that usually wasn't enought. A little sanding and they went away pretty easy. Each time this was on a new vehicle with factory paint.
Old Sep 12, 2008 | 06:01 PM
91_RED_Z28's Avatar
the only thing is...this is not factory paint.
Old Sep 12, 2008 | 06:52 PM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Get some "Wizards" detail spray and a clay bar and rub one out...
Old Sep 13, 2008 | 09:43 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
if they are water spots, try mixing 50/50 of water and vinegar, let the car sit in the sun to get hot, spray the area and wipe off
Old Sep 13, 2008 | 10:02 AM
91_RED_Z28's Avatar
And it wont ruin the clear coat or paint?
Old Sep 13, 2008 | 02:52 PM
Kevin84Z28's Avatar
Have you ever used a professional automotive clay bar? Not the cheapie you get at the auto parts store, but a 3M clay compound bar you get at an auto paint supplier?
Old Sep 13, 2008 | 03:02 PM
91_RED_Z28's Avatar
Well i have used Mother's Clay Bar system...or is that a cheapie to?
sheachopper
Jul 31, 2019 11:27 AM
RedLeader289
May 28, 2019 01:47 PM
LC2 TECH
Oct 13, 2015 11:53 PM
aaron7
Sep 30, 2015 09:15 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
