weld wheels and studs?
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I want to get some weld pro stars or draglites do u have to put in longer wheels studs or will they bolt up to the stock studs?
Car: 1979 Z28 / 1990 RS
Engine: Matching 350 / 305 TBI
Transmission: Built TH350, 3000 Stall / 700r4
Re: weld wheels and studs?
No you shouldn't have to put in any new studs. They should just bolt right no. Only thing i could assume that would cause the new studs is for like a weird back space. I dont think you need to change them. Which you wanting the most? i like pro stars
Car: '89 IROC-Z
Engine: 355
i like the pro stars but i think im going to get the draglites because my buddy has prostars and i dont want em to look the same. got any pics of both?
actually yes i do lol i have hundereds of pics of third gens lol... here ya go. (sorry the pro stars are in another thread but heres a link to the pic. )
https://www.thirdgen.org/forums/atta...90_25_full.jpg
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
im pretty sure with the pro stars you have to put in longer studs, theres a couple threads about it
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
For safety reasons, yes put in new longer ARP studs. The stock wheel studs don't offer enough threads for the lug nuts to hold onto.
Car: 89 formula
Engine: 305tpi
Transmission: t-56
Axle/Gears: ford 9" 4.11s
you dont use longer wheel studs, you use the long shank style lug nut that goes inside the wheel
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
You use the long studs because the stud must stick up into the head of the lugnut at least 1/2" for strength. (not including washers) Also the aftermarket studs are harder and slightly thicker at 1/2".
I have seen the stock studs on GM cars break at the track too often and the damage it does to quarter panels ect from the rear wheel exiting makes the change worthwhile.
Car: '91 Camaro Z28
ambainb
Apr 25, 2016 09:21 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
