Clear Taillights on a Maro' -- Pics!!
I had two hours to kill and paintshop pro as my friend. Here are my best examples of clears on a camaro.
stock
<img src= "http://www.nconnect.net/~briones/camrearside.JPG">
clear
<img src= "http://www.nconnect.net/~briones/camclears.jpg">
clear with brakes and hazards/turn signals on.
<img src= "http://www.nconnect.net/~briones/camclearsbrakes.jpg">
doesn't look too bad... I'd use em' if I had em.
don't bash it too much, I spent like two hours manipulating the pic.
I don't think altezzas would work too well considering out tails aren't very round.
--- 1988 Camaro Sport Coupe ---
2.8 V6, TCI 3200 Stall TC, B&M Transkit, Flowmaster & Catback (No Cat)
CFI Z/28 Hood, '87 16" IROC Wheels, Bowtie Grille, IROC Gauges, IROC Taillights,
IROC Foglamps w/ 9005 hi-beam bulbs
Heritage Style Hood and Decklid Stripes
[This message has been edited by SlowCamaro88SC (edited July 07, 2001).]
stock
clear
From: First one out of liberty city, burn it to the ground
holy **** those are sweet
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
1989 Firebird
Coming for my v6:
#3 Forever
<font face="Verdana, Arial" size="2">Originally posted by Graeme'sFirebird:
</font>
</font>
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Yeah, it doesn't look like "rice", it looks like domestic "rice". LOL.
89 RS
Looking For:
87 IROC-Z28 350 TPI
[This message has been edited by IROCZTWENTYGR8 (edited July 08, 2001).]
89 RS
Looking For:
87 IROC-Z28 350 TPI
I think they need the grid to be a "seperator" from each light section.
finally I do something to my camaro that others like. so to speak..
yeah that's my camaro.
just because import boys jumped on the idea first, doesn't mean it's rice to a point. it means it's a style that is popular with the young crowd. it's mostly seen on rice. only because that's the most popular trend right now. it wouldn't be rice if we'd (domestics new and used) have jumped on the idea a long time ago.
and the idea isn't even a true clear. I used the backup light section as a basis. Another good idea would be to keep the stock tailights config color wise, and have someone fab up a new cover in the same red-amber-white/clear config, but not have the textured backside that makes the light diffuse the way it does. someone could sand it down until it'sperfectly flat then work their way up the grit scale till it's like colored plexiglass.. that would be bitc^in'
i don't have a spare to try on though.
I emailed elitez5 a while back on how I was planning on doing mine. You could ask him(nicely) to post the email. I could go through it all (yet again) but it's late and I'm tired. It does require some spending and ALOT OF PATENICE!. I made the molds for mine for about 10 bucks. Cement(yes concrete), plastic wrap(food cling type) and bondo.
The way I plan on doing it they will come out crystal clear(no reflective properties at all) And you can use lexan, acrylic or what ever the home improvement store has...
and by the way you lose the grid pattern too....
[This message has been edited by Camaro_hunter_d (edited July 07, 2001).]
<font face="Verdana, Arial" size="2">Originally posted by SlowCamaro88SC:
</font>
</font>
i think I'll play around with a piece of plexiglass... I can keep the grid pattern if i grind out a recessed area just like the original tails, and paint it black. I still kinda want to try to make the factory taillight clear.
<font face="Verdana, Arial" size="2">Originally posted by 1991tealRSt-topGuy:
i am going from being a rice basher to a total freakin hypocrit-----those are pretty cool.........</font>
Well sence the nights gone and the sleeps caught up, heres what I did.
1. go to a local home improvement store and get a bag of concrete(small stone) 2.50 here, a sheet of lexan/acyrlic around 12.00 here and a roll of aluminum flashing. 10 inch by 6 feet(the smallest available) around 6 bucks. a heat gun 500 deg is the hottest you'll need.
2. a tub(a big one) of bondo. 9.90 here.
3. a box of that food cling film. .99 cents.
4. Take off the tail lights. Remove the lenses(take your time) they will eventually pop off.
5. Clean the adhesive off the lens.
6. Place a large sheet of the plastic wrap into the lens.
7. mix a small amount of the 'crete to fill it about 1/4 inch. As the 'crete dries ONLY FILL IT 1/4 INCH AT A TIME OR ELSE IT WILL CRACK THE LENS!
8. after letting the 'crete dry for at least 36 hours, after all layers have been laid in.(the 1/4 inch thing should be within 6 hours) about 5 layers I think not sure...
9. After the cure is done remove the concrete at an angle the squared end first(you'll see what I mean if you do this.)
10. the plastic wrap should peel right off. Take the bondo and fill in all the creases, and lines on the 'crete. Sand them down.
11. go to www.aircraftspruce.com and order the book vacuum forming. and some bagging film. around 20 bucks all togeather.
12. You can use your household vacuum to create the neccesary vacuum. Use duct tape to get a good seal around everything.
13. get a stand so the 'crete mold can sit without anything below it to the sides.
14. bag the thing with the "lens material" inside. Apply vacuum and heat to the lens material. TAKE YOUR TIME GO SLOW! it will come around.
Next enjoy your new absolutely clear lens. Just make sure to ge the colored bulbs as to not get pulled over.
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
well, i realized to, while riding in my friends Mustang (oh my god, I'm friends with a Mustang owner!!! :eek
when we saw another Mustang that had clear tailights
i mean, i think you can get clear tailights for 4th generations camaro's, so all in all it cant be THAT *****
only thing i was concerned about a few days ago was do "2 Much" to a camaro..........cuz then it looks like crap when you deviate 2 much from the stock exterior
when we saw another Mustang that had clear tailightsi mean, i think you can get clear tailights for 4th generations camaro's, so all in all it cant be THAT *****
too much work for me. lol... sorry about the "brakes on" pic. it looks like crap, but that's the best I could do...</font>
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I think I could deal with them (even maybe like them?) on a white car. On anything else I think I'll pass.
And just because they make them for 4th gens doesn't mean that they're rice-free. They make sheetmetal shopping kart spoilers and stickers for 4th gens too.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
keep in mind though my representation isn't truely clear. I used the backup light as a basis. it's flat and clear, but it's textured on the backside like the amber and red sections, if it were truely clear, I'm sure it would look better.
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
Next enjoy your new absolutely clear lens. Just make sure to ge the colored bulbs as to not get pulled over.</font>
Ok the supplies... listed above...
Now first step of the molding process.
Take a peice of the food wrap and lay it inside the removed tail light lens. Remember to leave at least 1 inch over hang in all directions...
Second step. Mix only enough concrete(I got the ready mix only add water type) to cover about 1/4-5/8 inch of the bottom of the lens.
Third step. WAIT UNTIL THE FIRST LAYER BEFORE ADDING ANOTHER LAYER OF THE SAME THICKNESS. IF YOU DO NOT WAIT AND TRY TO POUR ALL OF IT AT ONCE YOU WILL HAVE A RUINED/CRACKED LENS WHEN THE STUFF STARTS TO DRY.
Fourth step. after waiting approx 36 hours from the last "layer" pour remove the 'crete. Do this by easing out the squared end first.
Fifth step. BONDO!!!. Crack open the gallon sized tub and bondo away. fill in the lens grids, you know what to so if you've ever used bondo. Also make sure to get the entire thing even.
Sixth step. sand it down. Self explainatory. make sure its SMOOTH!!! THIS CANNOT BE EMPHASIZED ENOUGH!!! I used 220 grit first to rough the shape out then used 350 then 600 grit.
seventh step. Buy that book from aircraft spruce. It will come in handy for more than just this tail light lens thing(like making custom vacuum formed boxes/panels). Also get that vacuum bagging film stuff. you want at least 400 deg tolerance.
eighth step. make the "bag"(explained in book from aircraft spruce) the and place the lens material over the mold.
nineth step. hook up the vacuum and seal it with duct tape(works best). Then with the heat gun about 6-12 inches over the "bag" sweep back and forth(start at the middle of the mold, if you see the "bag" start to melt move further away from it) with the vacuum on. The vacuum will keep the lens material tight against the mold as you apply the heat to "melt" the lens material.
Sorry no pics.. No dig. camera.. These "new" instructions should help out some....
[This message has been edited by Camaro_hunter_d (edited July 09, 2001).]
why do you have to sand it smooth???? If you didn't, you'd be able to keep the grid.</font>
As soon as anybody finds a place that sells these or a person who makes them, oyu need to post it and tell us where to get them. I ahve a white Z28 and those will go great with my clear blinkers and sidemarkers.
91 camaro Z28:K&N's, flowmaster 3" cat-back exhaust, competition stero, strut tower brace, ZR1 chrome rims, eibach springs, slp headers, msd wires, bosch +4 plugs, throttle-body-bypass, kyb shocks-struts, airfoil
<font face="Verdana, Arial" size="2">Originally posted by Doogie91Z28:
</font>
</font>
umm.....i bet the will look alot different when on the car, I just hope who ever does this does not ruin their car. ....good luck....
1987 Black 305 TPI 5spd IROC, seems to be fully loaded, but can't find RPO codes.
AIM: SzkiRM125
---Give up the defending ***** stuff camaro_hunter_d, there is plenty to do to out cars, if not more----
AIM: SzkiRM125
I am not sure if someone has mentioned this but they have to reflect red when a light is shown on them, true clear is illegal, at least here in texas.
But it does look good, just my 2 pennys
<font face="Verdana, Arial" size="2">Originally posted by pred1tor83:
But it does look good, just my 2 pennys</font>
I just posted this cause some people seemed really interested in this... SO you have theinfo you need have fun!...
ok true clear is illegal even if u put 50 red bulbs inside, it, it has to have a reflector, so that when a car is parked and u are driving down the street, the headlights light up the reflectors, making the parked car more visible at night , the nice thing about altezza`s is that they are dot legal, while true clears are not..
87 IROC-z 305 TPI 5spd 10-bolt 3.73 posi ,8.8 Accel wires , bosch platinum +4 plugs,gutted air box ram air, K&N air filters,TB coolant bypass ,polyurethane tranny and torque arm mounts, K&N oil filter,Mobil 1 synthetic oil 10w30, futura GLS super sport tires 265/50/15 rear and 235/60/15 front mounted on 86 monte carlo SS rims ,
400 sbc and a 6 spd in the works
[This message has been edited by Fastcamaro87 (edited July 10, 2001).]
the housing is chrome, add a red light bulb and there you have it(you need to run the light bulb anyway)
'86 Camaro SC 2.8 V6, 5spd, T-Tops
Mods:
(Performance)
Flowmaster cat back exhaust
(Non-Performance)
Pioneer DEH-P4000 CD receiver head unit
Pioneer 6X9 Tri-Ax speakers
Jensen 8" dual voice coil sub
Blacked out tail lights and side markers (VHT
Nightshades spray tint)
Well, since you can take the reflector area out, here's a radical idea, put it back in when you're done
it's clear so you won't notice it much, if you need it red, well, get some translucent red paint and spray them. I'm thinking of making a set just to paint the whole thing with a translucent red
Anyway, Camaro_hunter_d, so you make the mold on the inside of the lenses? can you get the grid look that way without making a mold of the outside and sandwiching the two together and have the lexan in the middle. sounds like an interesting idea, I have a furnace at school that's set up for vacuum bagging, I might have to try a run there
[This message has been edited by 86ZRICHIE (edited July 11, 2001).]
it's clear so you won't notice it much, if you need it red, well, get some translucent red paint and spray them. I'm thinking of making a set just to paint the whole thing with a translucent redAnyway, Camaro_hunter_d, so you make the mold on the inside of the lenses? can you get the grid look that way without making a mold of the outside and sandwiching the two together and have the lexan in the middle. sounds like an interesting idea, I have a furnace at school that's set up for vacuum bagging, I might have to try a run there
what about that red "reflector" crap being on the bumper? That's how alot of Pontiacs come out of the factory. 88-96 grandprix's did. I made the tails on my girlfriend's white '94 grand prix clear, by taking out the red part on the inside of the tail, and put red bulbs in there. it has red reflectors in the bumper from the factory so my mod is legal.
<font face="Verdana, Arial" size="2">Originally posted by Jim85IROC:
</font>
</font>
http://albums.photopoint.com/j/View?...nce=0&res=high
Derek 90 IROC 5.7
Mods: All the usual bolt ons siamesed base , 2500 stall , 373's , SS hood ,big and littles , lotta reduced weight. Stock heads/rockers , cam ,runners , chip and TB
Best Et: 13.12@101 ...1.701 60 ft.
<font face="Verdana, Arial" size="2">Originally posted by 86ZRICHIE:
[This message has been edited by 86ZRICHIE (edited July 11, 2001).]</font>
it's clear so you won't notice it much, if you need it red, well, get some translucent red paint and spray them. Anyway, Camaro_hunter_d, so you make the mold on the inside of the lenses? can you get the grid look that way without making a mold of the outside and sandwiching the two together and have the lexan in the middle. sounds like an interesting idea, I have a furnace at school that's set up for vacuum bagging, I might have to try a run there
The grid thing... well I think they look better with out the grid... but I guess you could make the mold(yes from the inside) and see what can be done to keep the grid. Though you will have quite a time tring to get the lens material to form around all the compound curves of the grid... Make a mold and experiment is all I can say...
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
I'll still pass, the VHT paint blackout look the best on our cars, but have fun toying with you idea, don't hurt yourselfs.</font>
am i allowed in here??? i kinda like them
i dont think i would do it to my camaro----
actually i mite consider---mustangs get away with it and are not called rice........
i think they look pretty cool kinda like not crystal clear, but more of a blurry clear with the gridlines
i think that would look "phat"--so to speak
i think that would look "phat"--so to speak</font>
hey, that comment towards camaro and jim was kinda harsh.
camaro6spd, just said his opinion it was kind, and non degrading....
Be nice.
those are somehella good photshopping jobs, i applaude you man, except... now we have to see it on a 91-92 bird...
any one got a rear end shot?
Be nice.
Be nice.
91 FireBird 305 V-8
Edelbrock Catback, Fourth Gen Console. i have six cupholders. all for starbucks!
ghetto rigged cold air intake,
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
God Created The Earth, And Then Turned Up The Bass
F-Body Meeting, Naperville IL, Chicago Ave and Washington. July 27, 8:00ish.
Part Search, I NEED A Harness For A Radiator fan, THANX
Be nice.
91 FireBird 305 V-8
GheTTo Riggers INC.
