The Resurrection
Old Mar 19, 2009 | 01:34 PM
lasher_350's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 9 bolt 327
The Resurrection
Okay, due to some custody issues with my daughters, I had to sell the purple camaro, and now, after 2 years of isolation, the 85 Trans Am is beginning to undergo it's umpteenth resurrection...just thought I'd keep an online log of it for myself and others. At this point I'm open to any an all suggestions/advice/comments! Tally ho!
January 2007, fiance decided the bridge rail was a better option than a semi's grill...
and after 2 years of abandonment while I built up a replacement camaro
If you spot anything that needs repairing besides the painfully obvious, feel free to shout it out! Thanks guys!
Old Mar 19, 2009 | 01:42 PM
L0tuS's Avatar
Re: The Resurrection
wow that doesnt look bad at all, get the car put on a frame machine to get the rails right and repace the bottom of the core support. they make the metal peices that go around the radiator new its 3 peices and each one cost about $40 each.my 91' had a wayyyyy worst front than that and i drive it every day. ill fix it some day but i hope your rebuld goes well.
Old Mar 19, 2009 | 01:54 PM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
lotus's car was worse. trust me i saw the pics he took. just make sure you get the frame checked first. once you start putting it back together you my notice something here or there you want to replace.
Old Mar 19, 2009 | 02:01 PM
lasher_350's Avatar
Engine: 5.7 L98
I will do that as soon as I get a battery in it and get it running again. Good call, I had totally not even thought of it. Thanks! And I do have the bottom piece of the radiator support, just need the left and right sides.
Old Mar 19, 2009 | 02:04 PM
TAGTASCOTTY's Avatar
Engine: 408ci Stroker, 520hp 515Ft.Lbs.
Transmission: Outlaw 700r4
Axle/Gears: 3:73
My only advise... don't let your women drive your car. j/k.
Old Mar 19, 2009 | 02:08 PM
lasher_350's Avatar
Engine: 5.7 L98
Old Mar 19, 2009 | 02:18 PM
eschevyrda's Avatar
Car: 89camaro rs
Engine: 350tbi (needs carb!)
Axle/Gears: 32x in process
that motor looks so forighn to me wats it out of?
Old Mar 19, 2009 | 02:24 PM
lasher_350's Avatar
Engine: 5.7 L98
It's just a little ol' 305...I've been watching craigslist for a newer 350 though.
hillntx
Members Camaros
104
Apr 1, 2025 09:03 AM
pwdbychevy
Apr 16, 2023 07:27 AM
grassyflats
Aug 26, 2013 09:52 PM
Narcah
Nov 11, 2011 06:23 PM
brn agn
Members Camaros
32
Jan 23, 2009 11:48 PM
