pics of Borla exhaust
Old Jul 29, 2001 | 10:21 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
Trying out new server to upload pictures.
Borla exhaust
installation of SPL 1 5/8 headers
[This message has been edited by 86z/92rs (edited July 29, 2001).]
Old Jul 30, 2001 | 01:34 AM
jobryan26's Avatar
Sweet bet it sounds good too.
Trans Am:
(Engine)305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)Full Kenwood Excelon System
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Member at kyfbodies.org
Old Jul 30, 2001 | 12:34 PM
Krillind8z's Avatar
Hey how hard was it for you to install the Borla? Did it just bolt right up or was there some modifications involved?
Old Jul 30, 2001 | 04:32 PM
Jims83TA's Avatar
Is it true that you can some how "adjust" the sound or tone of the exhaust with the borla set up? I heard that it was possible.
Old Jul 30, 2001 | 05:42 PM
TwicK91's Avatar
There are 2 versions of the borla cat back..an adjustable one and a non adjustable one...the adujustable splits into 2 pipes after the rear axle one goes straight out to the exhaust tips on the passenger side and the other goes into the muffler then exits out the tips on the drivers side...there are plates with different diameter holes that can be inserted into the passenger side tailpipe to adjust how much of the exhaust gets diverted into the muffler or comes straight out of the passenger side pipe
Old Jul 30, 2001 | 08:03 PM
86z/92rs's Avatar
I originally purchased the Borla exhaust back in 1992 for my 86 Z28. The RS is now the benefactor of the Borla system with interchangeable plates. As far as installaton goes bak in 1992, I had in installed by a muffler shop. (I was not much of a gear head back then) With the introduction of the 1 5/8 SLP, I had to replace the plate with the smallest diameter hole. It was too loud. It sounds great at WOT with the small plate and somewhat quite when crusing. Here is another pic of the rear of the RS.
[This message has been edited by 86z/92rs (edited July 30, 2001).]
Old Jul 30, 2001 | 09:02 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Damn that looks sweet. Right now I just have the stock borla muffler replacment on my RS. it doesnt sound too bad with the gutted cat and 2 1/4 inch i-pipe.
Kat
Old Jul 30, 2001 | 09:04 PM
KlayBuRn's Avatar
my friends 87 IROC has Borla on it, and well, i can hear him dump the clutch and go through the gears about 3-4 blocks away...god his car is badass
www.geocities.com/leirch_
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
formula_novice
Sep 5, 2015 03:58 AM
downsouthboy
Aug 29, 2015 11:29 AM
zayne0
Aug 24, 2015 07:22 PM
Nj1987
Aug 19, 2015 08:26 PM
