BMW E36 Headlight Conversion
Old Jan 18, 2010 | 09:48 AM
  #101
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: BMW E36 Headlight Conversion
there isnt a way around cutting. I tried my very very best to not cut so much. but i had to in order to get the lights to fit they do now. I could of cut much more but felt like this was good enough. Cutting is something you have to do with these headlights.
A write up would be a novel to do. You just got to jump right into it. I will be more than happy to help out. But its a very very risky mod. You could spend thousand if you mess up. LOL
Old Jan 18, 2010 | 09:55 AM
  #102
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
Thanks for that info. Well can you take better close up pictures of the parts that you cut? Perhaps with the headlight removed if it is easy to remove? Did you take out only what you had to with a die grinder? Or did you use a cut-off wheel and just lop parts off?
Old Jan 18, 2010 | 06:06 PM
  #103
bvahnee's Avatar
If I fly you to Massachusetts will you do the mod for me
On a more serious note very nice job, future mod on my 91 for sure.
Old Jan 18, 2010 | 10:47 PM
  #104
mos68x's Avatar
Yeah I'm gonna have to side with that, this will become a necessary mod...however to include some sort of stiffening of the front end after I complete it.
Old Jan 20, 2010 | 07:30 AM
  #105
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Ramair21, do you have any pics of the covers that you said you made that cover the top of the headlights and hide the core support cuts?
I'm real close to pulling the trigger on a set of lights.
Old Jan 20, 2010 | 07:53 AM
  #106
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
Are those headlights expensive to buy?
Thanks. Tony.
Old Jan 20, 2010 | 09:16 AM
  #107
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
I like the light install, good touch for Camaro. Heres a E39 pic (BMW), too bad it wont work with in a T/A
Old Jan 20, 2010 | 09:42 AM
  #108
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
I wouldnt mind flying to Massachusetts. I want to see my boy Mr. Brown! LOL
Jim, I do have picturs of the front covers. I just got to download them from my phone.
The headlights are about $250 off ebay. Plus you have to get the angel eyes from another company. They have great stuff. Plus make your own wire harness in order to make the lights work with our setup
Old Jan 20, 2010 | 09:44 AM
  #109
mos68x's Avatar
That is because most of the time they are true HID's.
Speaking of which Ramair, did yours come with the ballast's? or do they use standard bulbs? I looked at one of them listed in ebay and noticed they were using 9006 and 9007 connectors.
Old Jan 20, 2010 | 01:06 PM
  #110
Jim85IROC's Avatar
This is what I'm running into. It seems that all of these aftermarket lights are designed to use a halogen even in the low beam projector. A lot of these places offer true HID upgrades, but it just doesn't seem that the projector is specifically made for HID, so who the hell knows how good it's going to be?
I'm having a hell of a time deciding just what I want to go with here.
Old Jan 20, 2010 | 01:42 PM
  #111
Engine: 3.0L 2JZGE
Hey,
What do you mean that I would need the angel headlight from another company? I thought the halo's came stock with the headlights. Now im confused.
Tony.
Old Jan 20, 2010 | 02:18 PM
  #112
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
That has to be by far the best healight swap i have ever seen on the 3rd Gen Camaro's and I have to say the final install very professional looking great attention to detail and great job....look killer
Old Jan 20, 2010 | 02:31 PM
  #113
Jim85IROC's Avatar
I've been talking with a guy that sells these lights, and who is very familiar with them. I sent him pics from this thread. He thinks there's enough dead space at the back of the headlight housings that I could cut that space away, and get these to fit without touching the core support.
Stay tuned.
Update. This is a pic of the back of the light with the cover off. According to the guy I'm talking with, they retro-fit these into Maximas and cut a LOT of the housing away. He feels that much less of the housing would need to be cut for this install.
Here's a better pic that shows the back of one of these housings with the cover off:
Here's a heavily modified e36 setup to fit into a maxima. From what I can tell, this has the e36 innards behind the maxima lense and with some different backing pieces. If anything, it makes me more sure that I can modify the housing to fit.
Old Jan 20, 2010 | 05:56 PM
  #114
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
i never thought about cutting the extra plastic off. That makes a lot more sense to do it that way. If that is the case you wont need to cut the support as much as i did. great looking out Jim
Old Jan 20, 2010 | 11:37 PM
  #115
mos68x's Avatar
Stay tuned.
From what I see here in your pics these are NOT HID's, they are just 9006/9007 bulbs. So if I wanted to upgrade these beyond this I'd still have to find a Bi-Xenon HID kit to upgrade the light output.
RamAir, I'm sure that you've taken your car out at night already so how much do you think the light output has increased just by changing to these headlight housings?
Old Jan 21, 2010 | 01:08 AM
  #116
i read theres a simple mod one can do to upgrade to H.D without buying the upgrade kit, bmw owners do it all the time. http://forums.bimmerforums.com/forum....php?p=8222169
Old Jan 21, 2010 | 07:27 AM
  #117
Engine: 3.0L 2JZGE
Theres shop out here in the LA County are I believe that sells the germany made headlights you know with the glass instead of plastic like US ones. Anyways and they come equiped with the halo's as well and you could also get them in different colors too. I called yesterday and they also told me that they come with bulb's and the HID's as well for $350 sound kinda high though not sure.
http://www.myspace.com/europeanvision
Tony.
Old Jan 21, 2010 | 07:29 AM
  #118
Jim85IROC's Avatar
Originally Posted by transam85dudeman
i read theres a simple mod one can do to upgrade to H.I.D without buying the upgrade kit, bmw owners do it all the time. http://forums.bimmerforums.com/forum....php?p=8222169
You can buy these housings with the HID upgrade already done. The kits come with the HID Xenon bulbs already installed, and comes with ballasts. The one drawback is that you're still using the cheap pseudo-HID projector that comes with these lights.
Some guys are actually taking the HID projector from other headlamp assemblies and retro-fitting them into these assemblies with minimal modification.
I may try doing this in stages. My guess is that even with the H1s that come with these lights, the output should be superior to our sealed beams. I can then upgrade to the HID bulbs, and if I still feel I need to do more, I can retrofit a set of HID projectors in place of the ones that come on these lights.
Old Jan 21, 2010 | 01:48 PM
  #119
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
I'm glad to see this is getting some legs. I'd like to do it myself I just don't have the time to mess around with it these days. Good luck to you guys!
Old Jan 21, 2010 | 02:17 PM
  #120
86TA4SALE's Avatar
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
Great job. That is the best Camaro mod I've seen. We definitely need a cool firebird one now.
~Matt
Old Jan 21, 2010 | 04:06 PM
  #121
Jim85IROC's Avatar
I just pulled the trigger on the lights, the angel eyes and HID ballasts & bulbs. This is going to be an expensive experiment.
Old Jan 21, 2010 | 04:10 PM
  #122
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Should turn out great jim. your projects always seem to come out good.
Deff. toss up a post of your own so I can follow your work. Im wanting to do this to my vert.
P.S. I picked up a pre-90 gauge bezel and am gonna work up some trim rings.
Old Jan 21, 2010 | 05:28 PM
  #123
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
yes it is. I wasnt able to get my lights to adjust the way i wanted them. But i able to see at night. thats all that matters. Good luck with the build Jim
Old Jan 21, 2010 | 07:24 PM
  #124
mos68x's Avatar
Any suggestions on how to make it adjust better? Or is it just where you have the mounts that is fooling with your headlights aiming?
Old Jan 21, 2010 | 07:25 PM
  #125
mos68x's Avatar
I hope that you do a thread of your own and with a tons of good pics. I really want to do this, but I would like to see how and where everyone is cutting and such before I get to it.
Old Jan 21, 2010 | 07:44 PM
  #126
adjustments for bimmer lights, http://forums.bimmerforums.com/forum...d.php?t=893721 btw on these cars, the head light always stay level with a servo/solenoid. theres two adjustment mounts each side. two are static adjusters and a third moving mount is a servo that tilts the light up and down.. For example if you go up a hill, the lights stays on the road instead on the air, going down the hill the lights point forward ahead instead of the road.
Old Jan 21, 2010 | 08:06 PM
  #127
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
This is getting REALLY interesting now that we could potentially just cut the light housing.
I'm watching this!
Old Jan 21, 2010 | 08:31 PM
  #128
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
awesome BMW E36 set up dude
are you running any hids ?
Old Jan 21, 2010 | 11:38 PM
  #129
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
they way i mounted the headlight is causing this issue. I dont think there is a way around this cause the head light itself is not straight. Its more of a curved to it. So dont expect awesome results. But it works
No HID just H1 bulbs. HID are in the near future. I just love the angle eyes LOL
Old Jan 22, 2010 | 07:40 AM
  #130
Engine: 3.0L 2JZGE
Hey Ramair21,
Tell me about the halo's are one of the coolest ideas that bmw has done for their head lights. In the link I have posted above that company also installs halo's and they have them in different colors as well. I though about it if I would go with this converstion I would go with the red halo's like that black out ss 5th gen maro.
Tony.
Old Jan 22, 2010 | 11:08 AM
  #131
xbox07's Avatar
Car: 86' Z28
Axle/Gears: 2.73 (for now)
I'd kill for a set of those head lights with red halos on my camaro
Old Jan 22, 2010 | 05:07 PM
  #132
Engine: 3.0L 2JZGE
Hell yea!
Tony.
Old Jan 22, 2010 | 08:43 PM
  #133
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Ive seen a Red BMW with red halos. It wasnt my taste at all. to much red lol. They do sell halos that change colors but are expensive really expensive
Old Jan 22, 2010 | 10:26 PM
  #134
M G Brewer's Avatar
Car: 1988 IROC-Z
need some pics with the hood up so we all can see the detail there and copy off of your genious idea. thanks for thinking outside the box. makes the 3rd gen look million times better and looks a lot newer of a car than what it rly is.
Old Jan 22, 2010 | 10:31 PM
  #135
KITT1983's Avatar
so how much did the BMW project run you? yes angel eyes are awesome
do you have any driving videos
Old Jan 22, 2010 | 11:09 PM
  #136
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
No driving vids yet. But the project cost around 300-400. Something like that LOL and a new pair of ***** LOL
Old Jan 25, 2010 | 11:35 AM
  #137
capedcadaver's Avatar
o hay.... someone found my photobucket.
yea, those are depo E36 lights (entirely different from the ones you posted above it) with a stock 89-94 (also 3rd gen, heh) Maxima corner lamp bondo'd onto it, and a wade cover bondo'd over the whole thing. It's a H7 halogen projector and i forget what the highbeam bulb is (H1? 9005 maybe? i dunno). sadly the projector bowls were all bubbled up so output was HORRIBLE. I never actually put them on my car because of that.
however the projector modules just pop out (heat up the glue with a heat gun, 4 screws holding it on) so you could put in a HID-spec projector in its place with relative ease.
Old Jan 25, 2010 | 11:42 AM
  #138
Jim85IROC's Avatar
Good to know! Thanks for that information. Welcome to the forum.
Old Jan 25, 2010 | 11:47 AM
  #139
thanks. I don't drive the car those were intended for anymore... but I do have an 85 300zx (looks kindasorta like an F-body from the side 100ft away haha) but it's getting an LS1/T56 next year so i guess i'm not a total outsider.
for it i'm using a 7x6 ebay sealed-beam-replacement housing with a Hella E55 bixenon projector and 5000k d2s HID bulbs. what size are the stock sealed beam units on your cars?
Old Jan 25, 2010 | 01:08 PM
  #140
Jim85IROC's Avatar
4x6.5", but they're usually referred to as 4x6".
Old Jan 28, 2010 | 12:12 AM
  #141
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
Ramair21, you have one of the best looking 3rdgens I've ever seen! Great job with the BMW lights! I have always wondered how I would go about putting angel eyes on my Camaro. I gotta do this mod! Thanks for doing the leg work!
Old Jan 28, 2010 | 12:17 AM
  #142
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks RsFreak!! You dont have a bad ride yourself man!
Old Jan 28, 2010 | 12:41 AM
  #143
RSFreak's Avatar
Thanks Man! My T/A will be MUCH nicer if I ever finish it!
Old Jan 28, 2010 | 12:06 PM
  #144
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
ordered mine yesterday... YAY!!!
Old Jan 28, 2010 | 02:10 PM
  #145
Jim85IROC's Avatar
What did you wind up ordering? I decided on the Depo IV with the HID upgrade and Orion V2 angel eyes. I bought mine through bavtoys... great guy to deal with. He answered all of my dumb questions prior to my order!
Old Jan 28, 2010 | 04:31 PM
  #146
Car: 88 IROC
Engine: 305TPI
lol i ordered the same thing..off of ebay
Old Jan 29, 2010 | 07:39 AM
  #147
Jim85IROC's Avatar
Cool. I hadn't seen quite that setup on Ebay... most seemed to be different angel eyes and no HID.
Old Jan 30, 2010 | 09:14 PM
  #148
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
im about 2 shakes from buying these. i want the black set in link 1
http://cgi.ebay.com/ebaymotors/92-93...item518f6cc084
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
both show to use halogens, i'm thinking 9005/9006. however i don't see headlight sockets??? how does bmw power the bulbs? i see a connector for the corner light, and one to go to the harness, and wiring to work the halos. is the bulb harness separate in a bmw?
Old Jan 31, 2010 | 09:40 AM
  #149
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
those are not the EURO style lights. Those are the Cheap USA ones. No projection. just regular lights. Your choice but i would not get those. I mean those would fit in perfect without really any cutting of the car but wont look as good as the EURO DEPO lights.
Old Jan 31, 2010 | 12:06 PM
  #150
matthufham's Avatar
Car: 90 z28
Transmission: t56
i actually prefer the halogen look over projectors, projectors look like bug eyes to me. plus light output isn't a big deal because i live in the city and actually it is an upgrade from stock. so tomorrow i think i'm going to get the black ones and i'll have a little install session with pics for yall.
