Powder coat TPI plenum and runners?
Old Aug 25, 2009 | 10:57 PM
87_TA_GTA's Avatar
Car: 87 T/A GTA
Engine: 5.7L TPI
Axle/Gears: 3.27:1
this seems like a good idea in my head but im not sure if itle actually work. i would really like to have my plenum and runners powder coated to a gloss black or semi gloss black, but im not too sure if u can powder coat engine items because of the heat.
Old Aug 28, 2009 | 02:01 PM
H8TRAFIC's Avatar
Re: Powder coat TPI plenum and runners?
I powdercoated the upper & lower plenum on my V6 & have had no problems. Hope this helps.
Old Aug 28, 2009 | 03:41 PM
johnnyGTA9's Avatar
yes, you can do it
Old Aug 28, 2009 | 03:59 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
I powdered coated my MiniRam. Well worth it. Always looks good and cleans off easy. It's been on my motor for 5 or 6 years now.
Old Aug 29, 2009 | 05:37 AM
andrewmp6's Avatar
Yes you can powder coat anything i have had a set of exhaust pipes on my bike done in black for the last 3 years still looks great.Think about it they bake it on in a oven it likes heat and they have a high temp one also.
Old Aug 30, 2009 | 06:58 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
You could also "Jet Hot" your parts. Jet hot comes in different colors.
Old Sep 1, 2009 | 09:56 AM
1986maro's Avatar
Car: 86 Camaro Iroc-z
Engine: Lb9 (305 TPI)
Transmission: 700r4w/ 2500 stall shift kit
Axle/Gears: quick performance ford 9 3:70
Powder coat TPI plenum and runners?-hpim0631.jpg i powder coated my intake and i love it. it cleans right up.
Old Sep 1, 2009 | 10:09 AM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Do it, you'll love it no matter what colour you pick. I did mine a gunmetal gray, 2 years ago and it still looks awesome.
Old Sep 1, 2009 | 03:17 PM
Car: 89 IROC
Spray on Duplicolor gloss black engine enamel.
Old Sep 1, 2009 | 04:21 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I've done intake manifolds and valve covers and different things like that. If you need help with it, I'll help where I can.
Old Sep 1, 2009 | 06:26 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I had the inside of my intake manifold, runners and plenum coated with a themal barrier coating as used on headers. I had the outside of each coated with a black heat dispersent coating. The intake charge is down a minimum of 10 degrees.
MantyZ28
16
Dec 21, 2015 11:02 AM
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
Sanjay
Aug 12, 2015 03:41 PM
