I finally found pics of custom clear TA tail-lights.....They are the grid style
Old May 3, 2001 | 03:47 PM
Jims83TA's Avatar
I finally found a pic of the clear tail lights everyone wants to see. They are the grid style tail lights. They dont look half bad. I kind of like them. They arent what everyone is thinking. These arent completely clear...they still have the grids...just are otherwise clear...I have no idea how to post the pics so somebody please let me know how to do it. Thanks.
Old May 3, 2001 | 04:40 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
cmon Jim, just email me the picture and I will take care of the hassle for ya. I will host it on my server. just use my email addy below and send it as an attachment. take care. i will be waiting, we will get it up here by tonight so everyone can see those lights
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.formula350.com
or click below to email me
astralbaby11@hotmail.com
Old May 3, 2001 | 09:31 PM
MetalliCamaroRS's Avatar
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Still no clear Camaro taillight pics? Before anyone flames me for wanted them, I'm not ever going to do it but I am curious as to what they look like.
1992 Camaro RS
305ci automatic, all stock til I get some cash.
My 1992 RS
Old May 4, 2001 | 12:35 AM
kiztope's Avatar
Car: 92 Formula
Transmission: A4
So where are these pics?
http://kiztope.50megs.com
92 Rs 3.1/T-5
Its slowly but surely coming along....
AIM : Theonekiztope
ICQ: 8787542
Planetarion: 3GFB kiztope of kiztopia-Camera-92RS-A (33:6:14)
"If it can be better than it is, make it so!" Leon Calrinsky (00)
Old May 4, 2001 | 12:38 AM
AmorgetRS's Avatar
You know, those clear tail w/ the grid are probably just the reflectors taken out. Its really easy to do and I played with the idea for a second when I blacked out mine...
Old May 4, 2001 | 01:00 AM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
Hey guys sorry for the delay. here is a picture of the clear tails, courtesy of Jim83TA... (sorry for the wait Jim!!)
P.S. hey Jim, if you ever need me to do this again, just email me the pics, It wont wont take this long next time) take care man..
Old May 4, 2001 | 01:17 AM
jobryan26's Avatar
That looks GREAT! I want some, does anyone know who makes them?
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Member at kyfbodies.org
Old May 4, 2001 | 01:39 AM
ONEFINE8T9's Avatar
i would also like to know how much they cost and where i can find them......
1989 pontiac firebird
bright red exterior(just repainted)
grey interior
5 spd
305 TBI (stock)
WS.6 formula wheels
3.73 posi rear end
http://members.aol.com/j007golden/Mikey89.html
http://www.geocities.com/firebird/myfirebird.html
1985 trans am
factory bright yellow
4 wheel disks
16 inch wheels
305 TPI
power antenna and mirrors
t tops
Old May 4, 2001 | 04:53 AM
sheet outta luck's Avatar
you have to custom make them yourself.
i kno a guy who did it for his 4th gen and it looks tight as hell.
if you give me enuff money ill make u a set
Old May 4, 2001 | 09:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I hate to break this to you, those are FACTORY tail lights. Those are 85-90 T/A and 87-90 GTA Ffactory tail lights. Only the red lens has been removed from inside. I put those style lights on my 83. There is a red plastic lens that sits over the outer 3 bulbs, no screws or anything. Heres how to remove it.
1.) Remove the tail lights from the car. you gotta remove all the plastic wing nuts from the inside of the hatch. Then remoe the sockets from the light housings.
2.) If you look at the bottom of the light, there are 2 metal clips. Pull up on them to remove them, but cup your hand over it while you do this, because they like to shoot off, and they are a PITA to find in grass.
3.) Now look at the top of each tail light, and you will see a bump in the plastic. These are plastic rivets, and the only way I could get mine out was to break them. I did was take a slotted screwdriver, pry under the rivet head (the bump) and break it off. Then all i had was the shaft inside the hole, which I pushed down out of the hole with the screwdriver. Now carefullt pull the outer lens from the backing. There is alot of weatherstrip goo crap that holds them together, but it will come loose if you pull on it. When you get the 2 halves apart, you will see the 2 smaller lenses inside. One is a clear reverse lens, and the other is the red light lens. This is the one you can take out. Since you have all this apart, I recommend cleaning all the pieces good. Mine had spider webs in it when I pulled it apart!
Hope this helps, hey maybe I should write a tech article.
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
Old May 4, 2001 | 10:46 AM
AmorgetRS's Avatar
Yup, Wards right, anyone w/ Trans Am tail lights could do that in the space of 20 minutes or less.
Old May 4, 2001 | 10:48 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Oh I forgot one thing, though. you gotta get red bulbs so the cops don't eat you alive for having bright-a$$ white tail lights... :P
1983 Firebird
TH700R4 Auto
Small Block 400
Old May 4, 2001 | 01:45 PM
Jims83TA's Avatar
Ward...I forgot to mention that. The guy said he did them himself. He didnt buy them like that....Im not sure if I am going to either make my tail lights clear like that or if I should buy that black out spray. Does anybody know how the black out spray can sold in the Summit catalog works? I want to spray my grid style tail lights.
Old May 4, 2001 | 04:14 PM
2FASTZ's Avatar
just out of curiosity could you do this to the grid tail lights on camaros
Old May 4, 2001 | 04:43 PM
RSFreak's Avatar
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
No. On Camaros, the plastic isn't clear with a colored reflector under it. The lens themselves are red (and amber, of course).
'82 Camaro SC - totalled
'80 Camaro SC - sold
'83 Camaro Z28 - sold
'85 Camaro Z28 - sold
'94 Camaro SC - stolen
'68 Camaro - for sale
'91 Camaro RS - my new baby
Old May 4, 2001 | 06:01 PM
91DropTopTA's Avatar
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
That looks pretty good. Project for this weekend?? Flame it if you want, it looks good. How about pics of the entire car? I want to see how those stripes look.
Old May 7, 2001 | 01:11 PM
vortech305's Avatar
Im sorry i must an idiot, but i cant seem to do it. I take out the lights from my 92' camaro dissasembled the license plate light took those clips apart and i still cant take the two pieces that hold together apart. I had it, every part in the tailight is freakin broken. $hit $hit $hit $hit $hit
Old May 7, 2001 | 05:40 PM
Dsaint's Avatar
Hey Vortech what side did you break? If it's the passenger lens you broke i'll be more than glad to give you my old camaro lens. I work by flushing.
Old May 7, 2001 | 05:52 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
<font face="Verdana, Arial" size="2">Originally posted by vortech305:
Im sorry i must an idiot, but i cant seem to do it. I take out the lights from my 92' camaro dissasembled the license plate light took those clips apart and i still cant take the two pieces that hold together apart. I had it, every part in the tailight is freakin broken. $hit $hit $hit $hit $hit </font>
That's because, as mentioned above, Camaro lights are TOTALLY DIFFERENT than firebird lights. Your *** is going to hurt when you see how much it's going to cost for a new tail light.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 7, 2001 | 07:17 PM
War_Eagle's Avatar
Nice job, but where did you find the red bulbs? aside from the back up light are all 3 of the remaining lights red(on each side)? Need help asap as I am working on this right now and need it for work tomorrow.......Thanks
Old May 7, 2001 | 11:58 PM
PhantomTPI's Avatar
Car: 1986 Pontiac Trans Am
Engine: 5.0 TPI
Most of the time, you can get red, blue, green, whatever color bulbs you want at a pep boys or auto parts shop. I know A&A has a wide assortment out here in PA.
1986 WS6-Equipped 5.0 TPI Trans Am
Random Tech High-Flow Cat
Two Chamber Flowmaster Muffler
Megs Custom 4.5" Stainless Steel Rolled Tips
1999 Grand Am GT In-Dash CD Player w/Equalizer(fits like '86 original)
5% Tint On Rear, 35% On Sides
http://www.pitt.edu/~zyhst/trans86/
OTHER RIDE:
1998 C5 6Spd. Corvette Coupe
Silver w/Gray Leather Int.
12/14 Options
Stock(for now)
Best 1/4th: 13.5 @ 104.4MPH
Old May 8, 2001 | 05:05 AM
call 1-877-FBI-MINI
they are fender bender int., and they sell red bulbs a buck a bulb compared to stores prices of $3-5 each. just remember, that red bulbs have a life of about 1-4 weeks each depending on how much you use your brakes.
Old May 8, 2001 | 09:00 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Okay I have a tip, but it ghetto (it works good, tho). We did this on my buds 65 mustang interior lights to make them all the same color of green. Go to the local office supply store and buy a red sharpie. IT MUST BE PERMANENT INK!! You can color the bulb red and no one will know its not a red bulb.
1983 Firebird
TH700R4 Auto
Small Block 400
Old May 8, 2001 | 08:23 PM
Axle/Gears: Drums?
I've never tried this(Yet), but I've read about using modeling paint to coat bulbs. This was a magazine article, so it's reliable. They used a candy which is transparent. Anyway the paint was candy and they thinned it to get the right consistency. They dipped the bulbs in the paint and let them dry hanging with the glass down so that the paint dried evenly. I haven't tried this, but it should work. The paint I'm talking about comes in small jars not spray cans. You can get just about any color in model paint. They used this for interior lights, but I don't see why it won't work for the exterior lights too.
Old May 8, 2001 | 08:58 PM
406 S10 Man's Avatar
Car: 1971 Corvette
Engine: 6.0 LS1 L92 heads sheet metal etc.
Transmission: M21 4-speed
Axle/Gears: 3.36
i painted the stock bulbs when i put the clears on my truck. i used regular spray paint, just put a thin coat or 2 on there. the light shines thru on mine just fine.
p.s. those ta lights look cool. watch out for the cops if you don't have any red reflectors on the back of your car. i haven't gotten busted for mine yet, but if i don't put a reflector back there soon, i'm going to get pulled over.
88 S10
Dropped 3/4
18" Boyd Coddington Timeless 5s
406 balanced with 6" Eagle H-beam rods, 10.25:1 JE SRP pistons, Comp 284XE cam; 240/246 @.050, .507/.510, Dart 200cc Ironeagle heads, Victor Jr. intake, Holley 750 vac sec.
12.20 @ 115.25 mph
Old Aug 28, 2001 | 09:05 AM
Jims83TA's Avatar
Bringing it to the top. So here they are once again. I am still deciding whether to black out my tail lights or clear them out. What do you think would look good on a red TA?
James
Old Aug 28, 2001 | 12:32 PM
duke_mushroom's Avatar
You know, I knew a guy who had clear tail lights on his Ranger but instead of buying red bulbs or painting them he had bulb covers. They were red pieces of rubber (or something like that) that went on right over the clear bulbs. I don't know if they came with a kit but there's an idea for ya. Personally I don't like the clear tail lights, but they do look ok on some cars.
Old Aug 28, 2001 | 03:45 PM
Blown_n_Injected's Avatar
Red bulbs are ILLEGAL in Texas! The DOT has not approved any red bulbs for use in motor vehicles. You have to have red lenses and white bulbs...somethin to do with how bright thay are. I sure see alot of rice with them though. Wonder how they get their inspections...they are cracking down on Illegal inspections here too.
There is no substitution for cubic inches!
Old Aug 28, 2001 | 04:27 PM
Thirdgenfbody.com's Avatar
Ive got a few passenger side grid style lights.. email me
arthur@thirdgenfbody.com
Old Aug 28, 2001 | 04:57 PM
FiReBReTHa's Avatar
STOOPID, STOOPID BOY,
BAD, BAD FIRE.....
Here's pics, i kept thinkin, hey thats cool... wow thats gotta suck, i would imagine that they made it easier rather then breaking that plasitc seal piece..
then i thoughts some more...
here's my mind hurts...
91 pont firebird tails....
I had these laying around in my room.
some dood needed to trade his GTA lights for one set of mine, i cant remember for the life of me who it was... but until he checks out the ones i have, im not diseecting, afterwards i will....
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Aug 28, 2001 | 05:40 PM
SlowCamaro88SC's Avatar
oh this appeared again... here's the poop. I have an idea to still look stock but not be, either take the red lenz out, and get a red bulb/ or paint it ---- OR ----- take the lenz out, paint the inside of the taillight (not the lense) with candy apple red translucent (availiable @ any hobby store, and paint the light w/ the red too.)
the latter would still look stock. just another idea.
I've done the first my my girlfriend's '94 grand prix SE.
this will work for =
88-96 grand prix
early 90's grand am w/ grid taillights.
95-90 ta
96-02 grand prix (looks like it
new bonnivilles
take a look at most pontiacs, it looks possible on most models, most late model years.
Frozer!!!
Jan 19, 2024 04:55 PM
Polo Z03
Sep 10, 2015 06:43 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
