Hood Insulation
Old Sep 1, 2001 | 08:30 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Hood Insulation
If i take off the Insulation on the bottom of the hood will it make the paint peel from the heat of my engine. Or is that insulation just there to reduce sound?
1989 Iroc-Z Blue T-Tops
Lightly Moded:
Headers, Rebuilt B&M 700R-4 tranny, Airfoil, K&N's
Old Sep 1, 2001 | 11:09 PM
FastElectrics's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
That is a good question.. I have a black car, with ratty insulation.. But I didn't want to remove it if the heat would damage the paint on the hood..
89 RS Camaro, LO3 305 TBI
Cooling Fan Overide Switch
L69 Duel Snorkel Intake
Dynomax Ultra Flo SS Cat Back
Old Sep 2, 2001 | 01:21 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
The hood insulation is there for the main purpose of deadening noise. Fast, you of all should know that on a nice hot day with the sun shining on your hood,, there is no way you engine runs hotter than the temp of your hood after a nice sit in the blazing sun. Keep in mind, you're motor is regulated to the temp of your thermostat, if you're engine is running hotter than what the sun does to black paint,, you've got more problems than what happens to your hood paint to worry about.
Just to make you feel more at ease to what I said,, my camaro when I bought it and to this day, has no insulation,, a month or so back a heater hose broke while my bud's g/f was driving it one night,, it got hot enough to make the temp gauge stick pegged (and is still fubar'd) and there is no paint problems.
For the most part, especially with urethanes, temp is not a problem until you get to blisteing heats past 600° which in some cases, a black car on a good hot sunny day can get almost to w/o causing a problem. I'm shutting up now . Hope that eases your thought some.
The mind is like a parachute, it only works when its open
Old Sep 2, 2001 | 10:06 PM
Car: 89 Camaro RS
Engine: 305 TBI
Ya, you probably are right on that one.. Thanks.. : )
Old Sep 5, 2001 | 05:11 PM
johnyIROC's Avatar
I ripped mine out when I did my engine swap... I haven't had any problems yet, and it looks alot nicer when the hood is up.
johnyIROC 1983 Z28
"5.0 is way too slow"
Old Sep 5, 2001 | 08:17 PM
82camaro's Avatar
Car: 82 camaro SC
6 years without one on mine without any problems.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
[This message has been edited by 82camaro (edited September 05, 2001).]
Old Sep 6, 2001 | 06:54 PM
colinfinkle's Avatar
Rip it out!
Colin Finkle
87 Sport Coupe Camaro, 5.0 L V8
Old Sep 6, 2001 | 08:07 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Thanks, I just took mine out now I don't have to worry about the paint.
Lightly Moded:
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
