I NEED REAR LOUVER MOUNTING HARDWARE!!!!!!HELP!!!
Old Mar 29, 2010 | 04:04 PM
Camaro Man 02's Avatar
Car: 1987 Camaro IROC-Z
Axle/Gears: Idk
Ok, I just bought a set of rear window louvers for my 87 iroc. It doesnt have the mounting brackets or also called hinge mount plate. I need this part. Please help me find one or msg me if you have one. I've called Classic Industries, SFX Performance, and checked the chevy dealership and nothing. They are the factory aluminum louvers with the hinge mount.
Old Mar 29, 2010 | 04:36 PM
Axle/Gears: Idk
Re: I NEED REAR LOUVER MOUNTING HARDWARE!!!!!!HELP!!!
The only numbers on it are: US PAT: 4453762
4469366
Then at the top it says: AAI3727B
Help is much appreciated!
Old Mar 29, 2010 | 04:45 PM
mh82camaro's Avatar
Car: 82 camaro berlinetta (z28clone)
Engine: gmpp 350,edelbrock,msd,k&n
Transmission: stage 2 maddog 700r4
Axle/Gears: motive gear 4.10/ eaton posi
hello i have a plastic rear window louver (3-piece) that i got from jcwhitney.com it has 2 hinges on top and about 6 stick on plates that hook onto the window and ahear to the window...i am not sure if yours mounts the same bt i am assuming it probably does...but made of aluminum. you can call them and see if you can get the hardware kit. otherwise you could just make them...there just small metal squares with a lip that goes around window with tread welded to the middle. you could just forget the lip part cut small 3 by 2 squares and weld just the threaded part to the bracket and put 3m tape on the bottom and stick them were you need them. i hope either idea will work for you. it is also good to see that i am not the only one who also like the rear louvers
Old Mar 29, 2010 | 04:49 PM
Axle/Gears: Idk
i looked on the jcwhitney site and i cant find any window louvers listed?
Old Mar 29, 2010 | 04:59 PM
mh82camaro's Avatar
i bought it about 4 years ago...you can try calling them and see what they say. but they have had rear louvers for many different style of cars...hope you find them,but if not try making them....there really nothing at all
Old Mar 29, 2010 | 05:07 PM
Axle/Gears: Idk
Could i just use double sided 3m adhesive? Would that be strong enough? I dont have any resources for welding.
Axle/Gears: Idk
I mean i dont want the wind getting under the louvers and having them fly off.
Old Mar 29, 2010 | 08:38 PM
irock88's Avatar
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Im in the same boat dont have the hardware perhaps if someone has pictures of the hardware I would be able to fabricate what would be required
Old Mar 30, 2010 | 08:00 AM
Werewolf SS's Avatar
Car: 1989 Camaro RS
Engine: V6 - LS Swap Incoming
Transmission: 700R4 - T56 Mag F Incoming
I'll post pics off hardware when I get home.
Mine is the Chastain Shadow louvers but it is the three piece so it should be similar.
It has the metal clips that lock around the metal frame of the rear hatch glass and then the main body is on a hinge that is connected to a metal bracket that mounts under the black buttons (thats what I call them they're like vibration dampeners or something) that holds the main piece in place. The side pieces have a long thin bracket that connect the main body at the metal bracket (under the buttons) and then the sides are clipped on with a metal bracket that is shaped to hug the underside of the side framing of the glass.
At least thats what I figured out from mine as thier where no instructions but any ways heres a pic I have of it on the car.
(I'm taking it off because I'm not sure if I like it or not)
Old Mar 30, 2010 | 08:13 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
i'll get pics!
but what to do about the screws?
Old Mar 31, 2010 | 10:50 PM
Bigbuds1's Avatar
Car: Chevy
Engine: 355
Transmission: 350
I need hardware too... Pics would help. I had them on a '87 I bought new back then, after 20+ years I forget the details.
Old Apr 2, 2010 | 07:59 AM
irock88's Avatar
Pictures anyone
Old Oct 17, 2011 | 07:10 PM
iroc87edgekid's Avatar
inb4 old thread is old, holy old thread batman, etc.
i found a set of these chastain shadows as well, but i was fortunate enough to find the mounting brackets with them, even though they were rusted to sh*t. i dremel'd the crap off of them and primed them and painted them an anti-rust black. i just painted them and i'm inside now, so i cant get pictures of them as of right now. but as mentioned earlier, they are basic metal plates that can be handmade. also, the hardware are just little tiny phillips head screws with 9mm hexhead locking nuts, or at least that's what came with mine.
Last edited by iroc87edgekid; Oct 17, 2011 at 07:11 PM. Reason: i know, it's an old thread.
Old Nov 23, 2011 | 08:56 AM
jmcatee10's Avatar
Hello all I found a site that sells the NOS window louver hardware but its expensive! For all the parts it will run you around $300 (no kidding).
If you are interested pm me and I will send you the site information.
Old Dec 6, 2011 | 10:59 AM
bwmcam's Avatar
Car: 1987 IROC Camaro T-Tops Rule!
Transmission: 700r4 Pro Built / 2600 vigilante tc
What is the link?
Old Jul 31, 2012 | 03:05 PM
wesgmc's Avatar
From: coos bay.oregon-u should see it here-it is beautifull
Car: 88 camaro-02 sierra truck-86z28
Engine: 2.8 mpfi-383 in the red z
i am hoping that i can get some assistance. I have the same set that you were thinking about putting on your car. I took these off my 1992 trans am about 5 years ago. When I removed them I put the top stainless steel brackets in a bag and marked it louvers. I have all the side clips still on the side louvers. They look like they have been homemade but? Do you have a picture of the hardware for yours. I would appreciate it. I have a guy that seems to want to buy them but im not sure if its all there. Could you help please.
Old Jul 31, 2012 | 09:20 PM
jmcatee10's Avatar
I created a document that should be very useful that illustrates the louvers, parts, part#'s, and where they are located when mounted. If you are interested PM me your email and I can send it.
Old Aug 1, 2012 | 12:14 PM
wesgmc's Avatar
I clicked on all the icons trying to find PM. My email is. wes.atwestco@charter.net. I'm certain that My louvers are chastain's I think that everything is there but if you send me the hardware Picts I can verify that the louvers I have are complete. The gentleman is going to drive 4 hours roundtrip in his 1987 RS and wants me to help put them on, to make sure they fit I guess? I figure if I can verify my louvers as complete I can call him and let him know.. By the way your car looks nice with them, I have looked at the diff. Styles for a couple days and I think the chastain's are the best looking louvers outta the whole bunch. Thanks Wes
Old Aug 3, 2012 | 11:42 AM
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
I think I have a set sitting around. When I sold my old set of steel louvers, I didn't have the mounting hardware. I found it when i gutted out the back of the interior. I'll look and see if i still have it.
Old Aug 3, 2012 | 06:43 PM
wesgmc's Avatar
thank you thank you and thanks. Hoping that you have the chastain three peice louver hardware. The guy is supposed to be here by 11 am to buy it. I am just wanting to make sure that I have all the hardware that is needed. With no picture of what is original I cant tell. Thanks again..
Old Aug 12, 2012 | 10:06 AM
javimetal's Avatar
Car: 87 iroc-z camaro
Can you please send me any info to my email javi_Silva77@Yahoo.com
Old Sep 21, 2012 | 05:38 PM
VMIROC-Z's Avatar
could u send me info on that ?
Old Sep 22, 2012 | 02:20 PM
dubbuzz's Avatar
Car: 1986 Camaro Berlinetta
Engine: 5.0 305 4bbl LG4
Transmission: AT 700R4
Axle/Gears: 2.73 Posi
Here's the GM part number for the crager metal louvers like the ones on my Berlinetta. I am missing two of the mounts too, luckily not the hinged ones though...
Old Apr 17, 2015 | 04:14 PM
toyhole's Avatar
hello. saw in an old post you had made a list of the parts and part#'s for the OEM Rear Hatch Louver mounts. Do you still have one? send it to virtuarebel@mindspring.com
Bill
LilHot
South Central
Apr 13, 2026 11:46 PM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
NBrehm
Aug 5, 2015 07:57 PM
