Polishing with orbital buffer ???
Old Sep 18, 2001 | 01:52 AM
Timmys88Z's Avatar
Ok, so I got this orbital buffer/waxer thing and want to use it to shine my damn car up. I've also got a bottle of 3M imperial hand glaze. But the thing just has one pad.
So..... what do I do, and how do I do it?
Old Sep 18, 2001 | 09:10 AM
zee28's Avatar
Car: 86 iroc
be very careful,and if you havnt used one, your better off not learning on your car.I have seen people ruin paint wih these things.Yes it can be used with good results if you know what your doing.Have you already tried to hand apply polish/wax with bad results?If you dont know how to use one then doing it by hand will look just as good if not better.If you must use it then practice on something else.You will need more then one pad also.
~mike~86 IROC-Z
Old Sep 18, 2001 | 07:17 PM
Jza's Avatar
Jza
you're thinking about a rotary buffer. any beginner can use an orbital buffer and not screw anything up. you can buy extra pads for around 7 bucks at walmart or the like. you'll definitaly need at least three.
Old Sep 18, 2001 | 07:23 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I agree if you screw up your paint using and orbital you've got some issues.
I use the big fluffy pads for applying the polish/rubbing compound. I work probably a 3x3 area at a time. Going back and forth then working it up and own. Let the buffer do the work, don't press down on it. The more you use it put lighter and lighter pressure on. Then I'll switch to a terry cloth bonnet to remove the polish. Pretty simple./
1985 ASCD Ram Air Trans Am
Readers Ride at https://www.thirdgen.org/rides/index...ew&rideid=1067
-=ICON Motorsports=-
" I get drunk, I race cars and I fondle women. But... I have weekends off and I am my own boss"
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
tattmann
Sep 27, 2015 05:20 PM
