lug nuts r ugly,which can I use?
Old Sep 19, 2001 | 08:50 PM
zee28's Avatar
Car: 86 iroc
my 86 irocs lug nuts have had it.they are missing some covers and rusted.new ones from the dealer are to much at the moment.What is a good replacement?can I use any one that fits?Is there a standard type I can get at the parts store,chrome,etc?thanks
~mike~86 IROC-Z
Old Sep 19, 2001 | 09:11 PM
One Eyed Jack's Avatar
Im sure there is if you ask the guy at the counter nicely, and smile. Hehe
Old Sep 19, 2001 | 09:29 PM
prepz28's Avatar
yea you need the acorn style. i had the same problem. just go to a parts store and see if they have some behind the counter. chrome lugs make a big difference
Old Sep 20, 2001 | 07:02 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I've got the same problem. The lugs on my IROC look like hell, and I don't even have any for the GTA. I REFUSE to put cheap chrome lug nuts on the car, and paint won't stick to chrome no matter what you do to it. GM wants $7 EACH for the lug nuts, and the local Big A Autoparts wants $4 each.
SLP sells the style that have the black plastic caps screw over them, but nobody seems to know if they'll fit the GTA or not. I suspect that they haven't changed between thirdgens and 4th gens.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 20, 2001 | 08:24 AM
cg91ta's Avatar
Car: 1991 T/A - Sold (sniff) 1980 T/A Pa
Believe it or not, Chevy is still using the lugs nuts with the screw cap on them on the Cavalier.
You can go to just about any junk yard and find those caps.
I had acorns on my Formula because some cheap b@stard liked my WS6 center caps and lug nut covers, and I too thought the dealer wanted too much. My friend brought her 98 Cavalier over one day, and I took the lugs off to change a tire, and there were the same caps as on the T/A. I switched one that was tore up because some tire place along the way destroyed it. Perfect fit.
Chris G
91 TA WS6
See more of her here!
Wise man once say "Red ones go faster!"
Old Sep 20, 2001 | 09:57 AM
zee28's Avatar
Car: 86 iroc
those lug nuts with the seperate screw on covers are big and ugly IMO.My wife has them on her firebird.Did gm use the iroc type on other cars in the 80,s or early 90,s.I hope they didnt make a special nut for just these wheels.The $4.00 each doesnt sound as bad as the price I got.it was more like $9 each.so thats not bad.anyway thanks
~white~86 IROC-Z
Old Sep 20, 2001 | 01:27 PM
82camaro's Avatar
Car: 82 camaro SC
You can get the 'external thread' nuts and plastic caps from NAPA.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Sep 21, 2001 | 11:27 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
82Camaro,
Any idea what the Napa part # is (I did a search but failed to come up with anything)?
JamesC
Old Sep 21, 2001 | 04:24 PM
82camaro's Avatar
Car: 82 camaro SC
No I don't have the part number. I just went in and looked through their book of lug nuts. The external thread nuts for some of the late model s10/sonoma are external thread. For example a 94 Sonoma with aluminum wheels has external thread lug nuts--It doesn't have the covers though, just a cap that snaps onto the threads. Then just ask for the small plastic caps(they have different sizes).
82camaro
Old Sep 22, 2001 | 03:16 AM
sheet outta luck's Avatar
yeah, i have a 99 S10 Xtreme with the external threads on the lugs. but since my rims have a center cap that covers the lugs mine didnt come with the plastic caps
my brother also has a 97 S10 with the chrome plastic lug caps
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Elephantismo
Feb 13, 2019 12:51 AM
gord327
Sep 29, 2015 10:18 PM
3.8TransAM
Sep 27, 2015 08:37 PM
Fox118
Sep 12, 2015 09:29 PM
