Fog lights
Old Jun 11, 2010 | 09:20 PM
lonesomeloser's Avatar
Car: 1983 Z28
Fog lights
Anyone have some other than oem? What type, how much, where you bought them.
Old Jun 12, 2010 | 02:03 AM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: Fog lights
stealership
Old Jun 13, 2010 | 08:10 PM
Car: 1983 Z28
Re: Fog lights
Looking for pics if anyone has anything other than oem...
Old Jun 13, 2010 | 08:16 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog lights
I've seen some at Wal Mart that are virtually identical to the OEM ones on my 87 GTA & my 89 GTA (RIP).
Old Jun 13, 2010 | 09:08 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: Fog lights
i got some advanced auto parts ones.
they bolted into some existing holes when i used a smaller diameter bolt to hold them.
the light output is pretty crappy, but i got them for looks mainly... the car just looks empty without anything in the front end.
they were $20 and look like miniature headlights.
Old Jun 13, 2010 | 09:11 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Fog lights
I saw a set there too, they looked VERY similar to my IROC fogs, and they were discounted, too. Should've bought em.
Old Jun 13, 2010 | 11:56 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: Fog lights
I found a set of dual duty type auxiliary lights from Summit by Hella that fit the bowtie grille almost like stock. It's a driving light and a fog light in one housing. I've since changed the supplied H3 bulbs with a set of 5150K blue (ultra white) and 2500K yellow bulbs.
http://www.summitracing.com/parts/HLA-H71010321/
White driving lights
Yellow fog lights
Since I didn't have stock brackets (not sure if they'll work anyway), I ended up with a set of 4th gen brackets which fit nicely over the upper bumper support.
Old Jun 14, 2010 | 12:14 AM
Stephen's Avatar
Car: 87 GTA
Re: Fog lights
Knowing me...I'd put white bulbs in both sides (all 4 sockets) and wire them together.
Old Jun 14, 2010 | 02:35 AM
1990z28's Avatar
Car: 1990 Z28 Camaro
Re: Fog lights
I got ones that are shaped as the Bowtie and there Amber and Ill get a couple pics up tomorrow if anyone whats to see them.
Old Jun 14, 2010 | 06:09 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Fog lights
If you have a Trans Am, the wal-mart (or other parts store) lights are virtually identical to the factory lights except for the housing mounts. The lens, reflector and bulbs will directly swap into the stock TA housings. If you don't have the stock housing then you could almost certainly fab these lights into the stock location. The brand name I've used is "Blazer", iirc. When I had a bulb burn out the replacement lights were around $18 vs. a pair of bulbs at near $8. I swapped in the new lenses and reflectors (with the bulbs) for a like new appearance.
Camaro lights will be different.
Old Jun 14, 2010 | 09:13 PM
Car: 1983 Z28
Re: Fog lights
Which is why I posted under the firebird section, but it was moved. Anyway, I was looking for pics of different style TRANS AM fog lights. I guess everyone has the small oem ones. I have an issue of GMHTP from 2002 and there is a trans am with some wider fog lights, and it looked really good. Just don't know what brand they were...
Old Jun 14, 2010 | 09:22 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog lights
You mean Mark Frouhar's '85 TA?
http://www.gmhightechperformance.com...ure/index.html
Those are the OEM C4 Fog/Parking light combos. I got one intending to do that to my car, but never wanted to cut my fascia to make it fit. If you decide to go that route, I have 1 of them, so you'd only hafta find the other one.
Old Jun 14, 2010 | 09:40 PM
Car: 1983 Z28
Re: Fog lights
Yes, that's the one! I'm up in the air about cutting the fascia.
Old Jun 14, 2010 | 09:44 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog lights
After reading the article, I got ahold of him & talked to him about it. Sorry, but I don't really recall any specifics, but it seems like it wasn't that big of a deal for him to fit them in there. Just cutting & new holes/mounts to get them in there.
Old Jun 14, 2010 | 10:23 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Fog lights
You can see the ones I had on here but you gotta be so darn careful as going up is fine but backing out of a steep drive will beat them up.
Only got tired of buying new builbs for em, such small housing means they ran real hot and burned out quick. twice a yr at $6-7 a bulb.
Old Jun 17, 2010 | 01:24 PM
Transmetal's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 350 TPI L98
Axle/Gears: Borg-Warner 3.27
Re: Fog lights
Go with the Blazer ones from Walmart. As stated, the lenses are a direct swap plus they don't have the ugly metal piece in the inside like the oem ones do. The lense is clear and they're way brighter than the stock ones. I paid about 25 bucks for em.
Old Jun 17, 2010 | 02:31 PM
Stephen's Avatar
Car: 87 GTA
Re: Fog lights
But it isn't a big deal to pull the shield out of the OEM ones & make them brighter.
Ponriac OEM Fog Light improvement...
And you can convert your stock wiring so that the fog lights stay on, while the high beams are on even easier!
Pontia Fog Lights on with the high beams
Old Jun 17, 2010 | 05:57 PM
Transmetal's Avatar
Re: Fog lights
I was kinda surprised that the Walmart ones are actually a glass lense too. I figured for 25 bucks they'd be a cheap plastic.
skeltor
Feb 2, 2016 10:37 AM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
