gauges
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
gauges
OK guys lets see your custom gauges! and any info on troubles you might have had installing them.
Car: 1992 Z03 RS
Engine: (L03) 305TBI
Transmission: TH-700R4
Axle/Gears: bone stock
Re: gauges
geesh, every time I look at aftermarket gauges, even the old style OE ones, I drool. I have a 92 so is it a hard swap to do, practically the entire dash has to be swapped correct? I hate the late model gauges, they look like something out of a caprice or something, hardly muscle car.
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Re: gauges
that looks killer man! i got auto meter pro comp 5" tach & spedo along with 2 5/8" fuel gauge,my pillar pod has 3 2 1/16" gauges, im still waiting for my volts and other gauges.im still trying ti figure out what im going to do about designing a new gauge face plate.
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: gauges
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: gauges
WOndering where he got these and if it was mechanical or electrical autometers? I had to put mechanical water temp and oil since my sensors went out on those. and i put them on the right side of the dash where he has other gauges at? and wondering where he got those?
Re: gauges
That's a warning limit, you can see a tick mark above the tach that corresponds to that limit on the graph. If I hit that limit, the whole gauge will start to flash. That's also where the SES (displayed as "ENGINE") shows up for any codes. I suppose I could change that limit, but that was where the yellow band started on the cluster I sent to Dakota Digital, so they programmed it accordingly. The other gauges have programmable alarm limits too, and will flash when they are reached.
