Painting GTA wheels
Car: 90 Formula
Axle/Gears: 9 bolt/3.27
Painting GTA wheels
I'm stripping the clearcoat and gold from a set of look-a-like GTA wheels to be repainted black to match my Formula. My question:what primer can I use to ensure that I won't be doing this job again in a couple of months? I plan on using either wheel paint or high temp engine paint for the color. What about self etching primer? Any thoughts or suggestions?
Mongoose-NCTGA-1990 Pontiac Formula/305 TBI-700R4 with Edelbrock Performer TBI intake,TES headers,and STB,K&N,MSD-6AL,Holley laser shot coil,Accel Extreme 9000 wires,Jet Stage 2 chip,TCI shift kit with corvette servo,Richmond 3.73 gear with Auburn 3 series posi,high flow cat,SLP 3" cat back,Eibach sportline springs,Energy Suspension poly throughout,Lakewood LCA and adjustable panhard bar package,SSM subframe connectors,IROC wonder bar,Tokico 5 way adjustable struts and shocks,Autometer electric fuel pressure gauge,Alpine,JL Audio,MB Quart,92 GTA taillights,92 GTA aero wing and hatch,Steve Spohn LCA relocater kit and torque arm,MacEwen White face gauges,84 T/A cold air induction air cleaner,Grant Formula GT wheel.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Instead of stripping the gold, just sand it and paint directly to it. You need special aluminum primer, and that stuff still sucks. The gold paint is already on there really well, and your paint will bond to it as well as it will to primer.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I am planning on repainting my black GTA wheels. Now when I sand them....how do you actually get between the "laces or spokes". They are pretty faded...and I want them painted since my car is getting repainted. Now what brand paint should I use....and what type? Where do I get the paint? Please let me know. Thanks.
James
James
<font face="Verdana, Arial" size="2">Now when I sand them....how do you actually get between the "laces or spokes".</font>
<font face="Verdana, Arial" size="2">Now what brand paint should I use....and what type?</font>
<font face="Verdana, Arial" size="2">Where do I get the paint?</font>
The IROC Homepage
Car: 90 Formula
I've already stripped them with aircraft paint remover so all the old paint is gone completely. I'm just looking to make sure the new paint doesn't come off.
Then you have to use aluminum primer. Good luck. I've never had good results keeping primer on aluminum. You may want to have them powdercoated instead.
The IROC Homepage
The IROC Homepage
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
I am hoping to start removing the clear coat as soon as I get home. After I remove it with the aircraft paint stripper, I then sand with sandpaper in very fine amounts. I will worry about grit when I get there. If I remember correctly it is like 1000 or something like that. Anyway, after I strip the clearcoat I want to paint the aleuminum. It is clear coated aleuminum right now, so do I need a primer, or will a few thin layers of paint along with a few layers of clear coat solve the problem? i will do what I have to, but I would like to start out easy. Thanks for the info.
<font face="Verdana, Arial" size="2">Originally posted by TZFBird:
I am hoping to start removing the clear coat as soon as I get home. After I remove it with the aircraft paint stripper, I then sand with sandpaper in very fine amounts. I will worry about grit when I get there. If I remember correctly it is like 1000 or something like that. Anyway, after I strip the clearcoat I want to paint the aleuminum. It is clear coated aleuminum right now, so do I need a primer, or will a few thin layers of paint along with a few layers of clear coat solve the problem? i will do what I have to, but I would like to start out easy. Thanks for the info.</font>
The IROC Homepage
Car: 90 Formula
I'll be using a self etching primer on the centers. After some further research it's supposed to work well on aluminum. And the high temp black should be able to withstand the temps of the wheels.
So how did it turn out? I want to paint my GTA rims today or tomorrow..but I am worried that I will be doing it wrong. Should I just sand them then paint them? Let me know ASAP. Thanks.
James
James
Car: 90 Formula
I hit a snag when I took them to have them polished. It seems that the rims are anodized and it will have to be removed before polishing. I'm waiting for chemicals to remove it to arrive so there's no telling when I'll finally get them finished.
ambainb
Apr 25, 2016 09:21 PM
kah992
Aug 19, 2015 02:55 PM
