what's the name of this stuff?
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
All over my engine bay I broken pieces of this black conduit. I'd love to get a bunch more and replace it all
what's the proper name of it, and where do I get more?
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: what's the name of this stuff?
Split loom, wire loom, corrugated wire loom, etc. Available just about anywhere.
http://www.google.com/search?q=split+loom
ok, i knew there was a simple answer. i'd hard to search for something you don't know the name of
thanks!
thanks!
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
It comes in different colours as well.
You could also try this...
http://www.techflex.com/prod_PET.asp
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
It comes in chrome as well, but I wouldn't use it. I've seen it on show cars and it looks cheap as hell.
Car: 85 Camaro Z28
Engine: 5.7 TPI
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its also available in different temperature ratings. the cheap stuff you get at the local parts stores will melt if its anywhere near, or even remotely close to the exhaust.
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Problem with getting it at the auto parts store is that it's usually only one size, 1/4". There's complete kits on eBay in pretty much all colors that will replace all of the loom on the harness. You don't need anything larger than 1". There's also sleeving on there that will withstand engine bay temps up to 600*F, whereas the plastic garbage is only good for about half that, if you plan on doing any serious upgrades that will increase underhood temps.
Your loom looks a lot better than mine did... Mine was in zillions of pieces, leaving a lot of the harness exposed. Right now, I'm using the plastic loom in red, will probably upgrade to the 600* stuff in the future due to past problems down by the starter and exhaust manifolds.
LT1Formula
Oct 8, 2015 08:34 PM
