Black Projection Headlights
Car: 1987 Camaro Sport Coupe
Engine: 2.8 MPFI
Transmission: 5-Speed Standard
Has anyone used these?
http://cgi.ebay.com/ebaymotors/95-97...#ht_4576wt_915
OR
http://cgi.ebay.com/ebaymotors/H4-HE...#ht_4605wt_975
The goal is to install a HID kit in the car.
I bought a clear pair of these but the beam is all over the place. They don't project light well, so I actually see worse than stock lights, and I light up second floor windows with my right light. The alignment wasn't changed.
So I haven't bought HIDs because I want to find headlights first and want advise! Have you guys used either of these before? My guess is the first link wouldn't be a bad choice....?
OR
Car: 87 GTA
Re: Black Projection Headlights
Neither set will be all that good. Been there, tried that.
Just go get yourself some Sylvania Silverstar sealed beams. That is what I did & can see 100 times better.
Unless you put in REAL projectors and just use them as housings to mount a real projectors in, those things are useless.
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
they'll work fine...
just be sure to point them to where its not in peoples eyes >.>
mine work a lot better than the stock halogens..check out my HID thread..link is in my sig below
Engine: 2.8 MPFI
If I go with D1S HID projectors, and fit them in the housings I have, should i use a stock sealed beam housing and cut it to fit, or should i used my ebay "diamond cut" h4 conversion ones?
i was looking at these: http://cgi.ebay.com/ebaymotors/Mini-...ht_5000wt_1099
how much of these have to be in the housing? if only the grey ring and lens is showing, is that how they work? or do more of them need to be out?
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
69mm is almost 3in.Almost too big to fit.
Put as much of the projector in the housing as possible.With both lenses about 1/8 or less apart.
Car: 92 25th anv z28
Engine: 346 TC78 Turbo
Transmission: 4L80E
Axle/Gears: 3.25 9"Nodular, Strange axles
I like the looks of the blacked out sealed beam on e-bay but i'm hesitant. Love the looks of those headlamps you had built! Good job
1992 Trans Am
May 10, 2023 07:19 PM
listen to him he (841LE) built these for me, plus the bezel mod of mine
