1a Auto ABS Headliner Install
Old Nov 11, 2011 | 08:24 PM
  #51
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: 1a Auto ABS Headliner Install
Originally Posted by stahrman0612
I had that same problem with mine, especially since I left out the sun visors (looks better without them). I drilled a small hole towards the front center of the headliner and into the sheet metal. Used a black screw. Holds headliner up nicely!! Can't hardly tell that the screw is there.
Well, if this headliner fits as bad as is described (I've also forgotten how my headliner was when I removed it over a year ago), I'm going to do the same thing the PO of my car did when he recovered the factory board. He put snaps in the fabric and used leopard-print buttons to cover the snaps, through which he drove screws into the roof rail around the T-tops and a couple in the rear roof bow. Except that the new buttons won't be leopard print. I didn't care that the buttons weren't factory and still don't. Except for the pattern, I kind of liked them (some cars now use similar retention on headliners).
Ended up crap-canning my factory headliner board after removing it for the last time because it was badly water damaged due to leaking roof seals (and even the dryer duct tape wasn't helping, lol).
Old Nov 11, 2011 | 08:49 PM
  #52
Pillsbry10's Avatar
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
velcro would work better than screws
Old Nov 11, 2011 | 08:53 PM
  #53
Engine: 2.7L V6
Axle/Gears: 4.41
I'd rather not have to worry about the glue coming off (which has happened before as it does get pretty hot up here occasionally) and then the headliner sagging. And that would defeat the purpose of the buttons, which I would like to reinstall (with a different pattern).
Old Nov 11, 2011 | 08:59 PM
  #54
Pillsbry10's Avatar
if you get the good stuff...such as 3m it wont come off in the heat.
if the headliner didnt need to come off ever the 3m body panel/trim adhesive tape would keep it up there forever
the 3m spray glue is so sticky its ridiculous..there is no way itll ever sag with that stuff on it.
Old Feb 5, 2012 | 05:54 PM
  #55
cdoyle's Avatar
I got one of these ABS headliners from Stock Interiors, and I have to say that the quality is kinda poor. I'm guessing it's the same ABS mold that all the other companies sell.
Why don't these headliners have the little clips at the front like the factory ones do? Mine is sagging right where those clips should be. If it had the clips, this would look so much better. Right now, I think I have a larger gap than the original one I had in there did.
I'm not too happy about it right now.
Old Mar 15, 2012 | 09:30 AM
  #56
ctwpc's Avatar
can anyone tell me how to get the ceiling console off? I found 2 screws in the light cavity but can't figure out how to get the rest of it off. Also have headliner I bought from a guy and I think it is an OEM cardboard one but there are no fasteners on it any ideas?
Old Mar 15, 2012 | 10:13 PM
  #57
mantaguy's Avatar
Engine: 5.0 EFI
Transmission: THM700R4
Axle/Gears: 277 Posi Speedo
You have to push forward on the OH console to remove it.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
Golfvette
Aug 24, 2015 06:35 PM
TheJoeY88
Aug 13, 2015 06:51 PM
