1a Auto ABS Headliner Install
Car: 1992 Camaro RS 25th Anniversary
Engine: 3.4L v6 with a t3/t4 Turbo
Transmission: T-5 Conversion
Axle/Gears: 3.23 SLP Limited Slip
well after the fiasco with marks custom kits(https://www.thirdgen.org/forums/afte...custom-2.html?
I decided to order an ABS headliner from 1a Auto... despite all the threads if read on bad fitment i cant say that i had any problems. the holes for the visors are tight but had no problem really getting them installed. seems to fit just fine to me and will look tons better once i cover it with fabric.
heres some pics
heres some pics
Re: 1a Auto ABS Headliner Install
and another
just make SURE you follow the directions
also you need to line up the visor first before you tighten anything down
Car: 87 IROC-Z
i noticed when i did it that the black triangle on the visors rotates
well if its rotated the wrong way it wont fit into the hole in the roof right. the passenger side did that to me i had to take it back down and rotate it so that it would go in right.
That looks like a perfect fit (or REALLY close to it). Impressive! Despite the good and bad of this mess, thanks for sharing. I've been considering the one from Mark's Custom KITTS and now think that's not the road to take.
once its covered ill give me rating of its fit...but im pretty happy with it as of now
no problem i hope lots of people stay away from marks, the attitude he had with me was not one of a business id care to do business with again. 1a auto has made me happy with two purchases so far and great service when i call.
Car: 92 Camaro Z28 / 07 Subaru WRX
Engine: GM RamJet 350
Wow, does look really good. How easy do you think it would be to do the cut-outs for the optional overhead console?
You're going to uninstall it to cover it and then reinstall? I would hate to take it down after getting it to fit so nice.
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
i see that the back side of the t-top section sags on your install to.. this was the main issue i had with mine. according to all the companys these headliners are made by acme company. that sag behind the t-tops is not right and it always got to me. i used a **** ton of velcro and it helped a little but not much.
The cut outs are marked and would be easy to cut out with a dremel.
There's a small gap in the rear of ttops but it doesn't sag. The material will fill that void, the foam backed material is pretty thick.
I need to shift it forward a bit in the front which should help any issue you see there. I test fitted it in all of 15 mins just to make sure it fit since it's coming back out.
Car: 1986 Camaro Iroc Z
Engine: V8 305 TPI
so everything installed easily? it came with all the hardware?? looks good, im getting one but going to order it covered.
Easy is a matter of opinion... But I found it to be easy. It uses your factory hardware, however, you don't need the metal retainers of the old headliner.
Car: 1987 Trans Am
Engine: LQ9/L92
Glad to hear you're happy with your purchase and thanks for the review! These do vary a little from the OE's (unfortunately no perfect replacements out there yet), but looks like you were able to get things in without issue.
Engine: 350TPI
since ive got your attention dan is there anything that can be done to contact acme company and tell them the problems where having with these headliners i cannot find any valid contact info for them.. that huge sag behind the t-tops is not right. certainly not for the price of that part.
Car: 1987 Trans Am
Engine: LQ9/L92
I'm still trying to figure out where you see a sag? I really haven't seen any big enough off spots worth a complaint. Could it use some work? Probably, but what part doesn't these days.
Look at my pics from the fiberglass liner.... Now that's a fitment issue lol
$150 bucks free shipping... Fair for what I got. It def needs covered though, a plastic roof isn't very high end lol
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i put a abs liner in my 86, it fit really well, but it does hang a little in the front center, since there is nothing there to hold it up.
my visors seem to be holding it up pretty well in the front middle so far
Car: 88 Camaro Coupe - 99 Corvette
Engine: 305TPI - LS1
Transmission: A4 - A4
Axle/Gears: 3:73 - 3:15
i installed one in my 89 formula... fit perfect but i forgot where i got it. it did sit low in the front center but when the sunvisors were flipped up it was fine
Engine: 350TPI
If You look where the roof rail meets the body in the back right over the passanger seats. theres a significant sag!! you can really notice after you see a camaro with the factory original headliner. its supposed to actually sit above that rail lip. i can understand because its an aftermarket. but theres no other headliner company out there. weather you get it from 1A or classic indusrtys its the same product. and its a drag when your trying to do a complete resto. this is the second time its happened to me. The photo below shows it. i actually use a huge amount of velcro in this picture and it helped alot so you can imagine how bad it was.
Thanks Dan for taking time out to respond to me appreciate that!!
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Engine: 350TPI
Thanks man, white leather .. more money then i paid for the car lol
Car: 83Z28 HO
Transmission: G Force 5 speed
Pillsbry10 - Thanks for posting the installed liner. Hopefully mine will turn out that well. I plan to use heavy duty velcro wherever I think it may help - if I need to.
Car: 1987 Trans Am
Engine: LQ9/L92
Hey, no worries, I'm always kicking around. I lucked out (so far) and still have headliner that appears to be in good shape, other than the material. Counting myself lucking and will just scrape and recover the factory piece. A bit of fiberglass cloth and resin should make things a bit more sturdy and waterproof while I'm at it. Especially since we all know how well these t-tops enjoy leaking.....
Engine: L31 350
I would take some welding rod or equivalent, bend it to match the contours for the roof line and fiberglass it to the back of the headliner. That should sufficiently stiffen it...
however, i havent seen a factory headliner in ummm....8 years or so lol last time i saw one it was in a trash can
Car: '87 IROC-Z
Engine: 350ci
Transmission: 700r4 rebuilt
Just swapped in the ABS headliner on my '87 IROC t-tops- got it in alright but there are definitely some gaps that will need some dealing. It hasn't rained here since last July and the t-tops still seal pretty good, so water isn't much of an issue. It's just a bit unsightly with them off. Still looks better than the stitching job I did to the old fabric and my attempts to get it to stick to what amounted to sawdust. :-)
Car: '87 IROC-Z
Engine: 350ci
Car: 1988 Transam
Engine: 5litre
Heck played around starting to fit my abs liner.all lines up at the back seatbelt end but the front is way out.Will upload some pics shortly
Car: 87 IROC-Z
I know this goes for Camaros, not sure about Firebirds/Transams but...
Are you sure you have factory t-tops and not aftermarket? Some hard tops were chopped and t-tops installed. I assume you have t-tops, I believe that is what I am looking at in the first pic.
Car: 1988 Transam
Engine: 5litre
Yeah there original t tops. The back section of the hood liner fit great it's just the front. Not sure what to do with that part . Could cut the lip down and then hopefully covering it will take up the gaps
Car: 1987 Trans Am
Engine: LQ9/L92
make sure when you put the headliner up, you do not tighten anything down - loosely get the back in place and put the sunvisor brackets up loosely. make sure you follow the included instructions and you shouldn't have an issue, but you're best to start aligning up front, not in the back.
Car: 1987 Trans Am
Engine: LQ9/L92
Car: 1988 Transam
Engine: 5litre
Car: 1988 Transam
Engine: 5litre
Well got the front lined up and the back.Its half and inch out in length and only option was to cut the middle.I cut where the interior light bolts up so little less noticable and when covered can fill that area.Annoying being that amount out but looks a treat now.I have attached pics of the finished item.Like i said once its covered will be fine but annoying just the same
Car: 1988 IROC Z
Engine: 5.7 litre
Axle/Gears: 3.27 Posi with 4 wheel disc brakes
I bought my IROC 2.5 yrs ago and the factory headliner was close to perfect. However, after driving the car with the T-Tops off the summer of 2009 and the summer of 2010 the fabric began to rip along the edges of the T-Top (the dreaded yellow cardboard was beginning to show). Unfortunately, 20 yr old fabric just doesnt have alot of strength when wind is beating it up over the coarse of 2 summers. I ended up replacing the headliner with an ABS one last September. Fitment has been ok but not great. The gap along the T bar on the drivers side is too big for my taste but otherwise it looks good. I kind of wish I had kept the original headliner and just recovered it but thought the ABS one would last forever so I went with it.
Car: 1988 Transam
Engine: 5litre
Car: 1988 Transam
Engine: 5litre
Dam seats not ready.Another week.Sigh
Car: 1986 Trans-Am
Engine: 305 4 bbl
Transmission: 700R4 auto
Axle/Gears: posi
I had that same problem with mine, especially since I left out the sun visors (looks better without them). I drilled a small hole towards the front center of the headliner and into the sheet metal. Used a black screw. Holds headliner up nicely!! Can't hardly tell that the screw is there.
Car: 1986 Trans-Am
Engine: 305 4 bbl
Axle/Gears: posi
i installed a used ABS headliner in an 89 formula, was already covered with fabric too, install was super easy and it fit great.
