LED Bulb for front turn/parking lights - Fit Issues
Old May 9, 2011 | 12:12 PM
dirtydust's Avatar
I was going to replace the bulbs in the front parking/turn signals with a 2057 bulb from Superbrightleds.com BUT the bulb wont fit. Part of the bulbs circut bord wont allow the bulb to fit properly into the socket.
Anyone have success with another LED bulb that I shouold try? v-leds, ebay, etc?
Old May 9, 2011 | 12:38 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: LED Bulb for front turn/parking lights - Fit Issues
What car do you have? What housings? Any pics to show what/where it is hitting?
Old May 9, 2011 | 01:02 PM
dirtydust's Avatar
85 IrocZ - The housings are the stock front turn/ parking lights and the issue is when trying to put the bulb into the socket you can not push it in far enough to turn and lock it in place because part of the LED bulb is just a bit to wide and dosent allow you to push it down enough.
Old May 9, 2011 | 08:07 PM
weswisehart's Avatar
Car: 91 RS T-top
Axle/Gears: 3:42 fourth gen disk brake
Only way around it is to cut about 1/8 inch of the plastic that the bulb sits in. I have done it to both my camaro's
Old May 10, 2011 | 11:57 AM
dirtydust's Avatar
Thats what i figured -
Old May 10, 2011 | 12:00 PM
Car: 91 RS T-top
No problem. The still sit in the housing fine and lock good so don't worry about that
Old May 10, 2011 | 08:48 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
I'm having the same issue with a set of V-Stars from V-LEDs. They fit fine in the tail/brake socket, but the turn signal sockets (front and rear) don't allow the bulb to seat enough to twist/lock in place.
Exactly what I had planned to do. I dremmeled one socket I had on another harness, but that just melts the plastic. What I figured was a 13/16 (diameter of the V-Star circuit) drill bit on medium speed to prevent melting, and go down about 1/8".
Old May 10, 2011 | 09:05 PM
Car: 91 RS T-top
I just cut it with a razor knife took all of 5 minutes to trim it.
Old May 31, 2011 | 09:51 AM
graywolfman's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305cid 4BBL E4ME Quadrajet
Which LEDs did you get, and did you get thems to work? Have you done all of the external (Signal/marker/tail/reverse) lights? If so, were they bright enough?
Frozer!!!
Jan 19, 2024 04:55 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
