Ground Clearance: Normal or Not?
Old Oct 22, 2001 | 08:11 PM
MetKiss316's Avatar
On my 1987 Camaro Sport Coupe, it has 15x7 wheels with 215/60/15 tires. When on level ground, it sits about 2-2.5 inches off the ground. Im thinking about getting the 3 inch. American Thunder Flowmaster Cat-back, but im faced with this ground clearance issue. Most of the Sport Coupes i've seen sit a lot higher than mine. Even z-28s sit higher than mine. Is there something abnormal or wrong, or what? Should i get new shocks and struts? Im planning on getting 16x8 wheels and 245/50 tires, but there is a possibility that i get 15x7 88-90 IROC wheels. What should i do to get a little more ground clearance without it sitting like a 4x4?
1987 Camaro Sport Coupe 305 V8 LG4-rebuilt-All Stock.
Future Mods: Flowmaster American Thunder Cat-back, Catco High Flow Catalytic Converter, Hooker Super Comp Shorty Headers, Dual Snorkle Air Cleaner with K&N Filter, CompCam 264H, White Paint, 88-90 IROC wheels or BBS ASA JS5 wheels, Sony XPlod 50x4 head unit, KICKER Impulse Coaxials 4x6 speakers, KICKER Impulse Coaxials 6x9 speakers, KICKER ZR1000 Amp, KICKER 12 in. subs, Grant Steering Wheel, New Intake(Edelbrock carband manifold),New Fuel Pump, Ground Effects
Old Oct 22, 2001 | 08:49 PM
un4givin89's Avatar
Yours has probably been dropped, as was mine when I bought it. I wasn't aware till I really looked. Mine sits 3 inches off the ground near the doors, my cat is maybe about 2 to 1 inch off the ground... lol. Its still in tach and working fine.
Old Oct 22, 2001 | 09:02 PM
MetKiss316's Avatar
Thats exactly how mine is. The cat is literally about 1-1.5 inches off the ground. What should I do in order to be able to put 3 inch pipes on? New shocks and struts?
Old Oct 22, 2001 | 09:08 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Maybe the tires are making the ride a little lower. I believe stock was 215/65R15 and the 60 series you have will be shorter height-wise. It shouldn't make a huge difference though. It's likely that your car has been lowered.
Old Oct 22, 2001 | 10:20 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Shocks and struts do absolutly nothing for raising ride height (a seemingly common misconception).
You can add spacers in the springs (better left for correcting minor body height issues, like body lean, imo) or, you can
go to the junkyard & get a set of stock springs from another camaro or firebird or, you could get a new set of lowering springs in hopes it will raise the car slightly w/o making it look like a "4x4".
The only real problem with those tires, they will cause the speedo be fast.
"Always do sober what you said you'd do drunk. That will teach
you to keep your mouth shut."
Old Oct 23, 2001 | 03:15 PM
MetKiss316's Avatar
How will 16x8 wheels with 245/50/16 tires affect the height. Will the lower profile tire match the bigger wheel, making it no bigger than the old 215/60/15?
billybob6110
Sep 23, 2015 01:30 PM
BWilcox
Sep 20, 2015 12:19 PM
gta892000
Sep 16, 2015 12:37 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Glowsock
Sep 5, 2015 07:48 PM
