How Big?
How Big?
Ok guys heres the deal. On my car i wanna run big fat street legel drag slicks. But here is the problem. I dont know any thing about tire size and how it relates to wheel size. And i also dont know how big of a tire i can fit in our cars. I like the Crager Quick Trick 1 wheels. If i were to get these what size could i fit it back with what tires would i be able to run on them. Just looking for something to go on. Thanks A Lot. Bobby.
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
what size are the rims? and do you care about minor rubbing or not? also, do you care about speedo calibration?
Have not picked a size of rim yet, dont know what will fit and look good. How minor is minor rubbing, is there a way to fix this minor rubbing. Nope dont care about speedo, im always going to fast any way. I am wanting this to be a bad-a$$ looking muscle car, you know with small tires in front and the big in the back. Also dontknow it this affects anything but i will soon be adding traction bars, will these interfere with any thing. Thanks. Bobby
An crappy handling
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
See my Ride:
I know that you can go to far. Thats why i want to see what you guys would think would be the best mix of performace and looks. This car is meant to go straight, fast. Thanks, Bobby.
Car: '89 Firebird
Engine: 7.0L
If you want the big fat tire look you want a 15x8 rim with some drag radials on them. I've got a chart here somewhere that tells me what backspacing you want on the rim and what tire size. I'll have to look for it and post again.
Say I was to run Cragar SS/T Street Super Trick Wheel 15x8's in the back and 15x6's in the front. Witch one would i by there are two opitions for the back. They are:
4.25'' Rear Spacing, 5 on 4.5 - 4.75 - 5'' Multi Bolt Pattern
or
2.75'' Rear Spacing, 5 on 4.5 - 4.75 - 5'' Multi Bolt Pattern; Reverse Offset
And last, i want to run BFGoodrich Comp T/A Drag Radials in back. Witch size tire would i by to fit on these back rims, will it fit on the car with no problems. Also what kinda tire should i run in front?
Thanks A Lot. Bobby
or
Thanks A Lot. Bobby
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
do you want to run a slick or a radial street tire? do you just want wide or wide and tall? do you plan on doing any sanctioned racing with this car? if ya do most will only allow a 10.5" wide rear tire. Most guys seem to run either a 26x10.5x16 or 28x10.5x15 slick, either M/T ET Streets or Hoosier quik time pros. if you want to run just a drag radial, get a Nitto and put it on a normal 16" rim.
I'd like to see some nice pictures of like a 17-18 inch wheel, 8-8.5 inches wide, on a nice flat straight wall and corner with white lettering that fills most of the guard.
Also those fat "drag style" wheels, the kind that "go in" and have a lot of depth 5 spoke if you can =)
Like centerlines
*** I ask for a lot don't I? =)
Nobody ever got cancer from smoking tires!
gibsandwich@hotmail.com
Get ICQ Page My ICQ
ICQ # 18562788
1982 Z28 Camaro
305ci LG4, Muncie 4-Speed, Holley Carburettor (CFM Unknown), 2.5" Stainless steel exhaust all the way through.
Fibreglass hood.
Boston 4x6" CX7e 2-ways, 6x9" Nippon America (no-name?) 3-ways
Other stuff I haven't figured out yet.
Like centerlines
Get ICQ Page My ICQ
ICQ # 18562788
1982 Z28 Camaro
Fibreglass hood.
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
