painting wheel wells?
Old Jul 27, 2011 | 01:25 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
my rear wheel wells got over spray in them when i had my car painted and i want to respray them black. is this hard? any techniques to this or is it pretty much just spray?
Old Jul 27, 2011 | 01:33 PM
KonArtist's Avatar
Car: 1992 Camaro z28
Engine: 350 HSR
Axle/Gears: 3.42's
Re: painting wheel wells?
1. Jack up the rear.
2. Remove rears wheels.
3. spray with de-greaser and scrub then rinse and let dry.
4. Tape off the inside edge of fender lip and i usually tape the outside of the quarter panel too incase of some paint dust. Tape off any suspension parts you dont want painted too.
5. Paint away.......i used rubber undercoating and as it got tacky went over it with some cheap wal-mart 99cent black paint. You could just use paint thought.
Old Jul 27, 2011 | 01:43 PM
BADNBLK's Avatar
COTM Editor
I basically used this same method, except in step 3 I just washed with water and did not de-grease, or scrub. I guess it depends on how nasty the wheel wells are. Worth the end result for sure!
Old Jul 27, 2011 | 01:51 PM
58mark's Avatar
Car: 89 rs, 86 Trans Am
Engine: RS-V6... Trans Am-LG4
Transmission: RS-T5... Trans Am 700r4
yeah, rubberised undercoating... the marhyde stuff is more brown than black, FYI
Wheel wells look so nice black
Old Jul 27, 2011 | 01:54 PM
KonArtist's Avatar
Engine: 350 HSR
Axle/Gears: 3.42's
Yeah mine was more brown then black thats why i got some cheapo black paint. First time i used it I coated my wheel wells and went in side for a few minutes then came outside and was like WtF?! its brown.
Old Jul 27, 2011 | 01:55 PM
58mark's Avatar
the rustoleum stuff you can buy at wal mart seems to be good, and it's jet black
Old Jul 27, 2011 | 01:57 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
I was gonna get some of this Duplicolor stuff to do mine: http://www.utilitysafeguard.com/Kryl...rcoating-20oz/
Old Jul 27, 2011 | 03:45 PM
bracket rs's Avatar
i use "engine" paint, black, covers nice
Old Jul 27, 2011 | 03:56 PM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Go to an auto body supply house. Ask for 3m body shuts, It will fill any cracking that has formed over the years, and looks just like factory. Other wise rubberized under coating.
Old Jul 28, 2011 | 01:33 AM
puma1552's Avatar
First half of this post has a great writeup about the 3M stuff:
http://www.stangnet.com/mustang-foru...959-post1.html
Old Jul 28, 2011 | 07:16 AM
Transmission: t-56
Heres the stuff im talking about. It builds just like the factory.....
http://www.amazon.com/3M-08864-Schut.../dp/B000PEQGMM
Old Jul 28, 2011 | 09:15 AM
Car: GTA
That stuff sounds good, but also requires an air compressor & spray gun to use, unless someone wanted to try brushing it on which I have no idea how that stuff would worth with being brushed on. Know of any good aerosol undercoating?
Old Jul 28, 2011 | 10:57 AM
Transmission: t-56
Well, yeah it has to be sprayed on, It looks exactly like the factory stuff, and is what i used with any collision repair. If your in the need of something with its own propellant I suggest the 3m rubberized undercoating as suggested earlier. It works really well, but drys to a brown/black color.
Old Aug 4, 2011 | 05:08 AM
KingsHustleLA's Avatar
Car: 1986 Camaro
Axle/Gears: 411
What About Just Using Degreaser, Drying It & Spraying On Some Gloss Black KRYLON Plastic Bonding Spray Paint???
Old Aug 10, 2011 | 03:46 PM
banker's Avatar
Car: 87 TA
Axle/Gears: LSD
I'd recommend POR15, doesn't crack and lasts ages
Vintageracer
Jan 10, 2020 05:33 PM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
maroe624
Apr 16, 2017 08:29 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
