Stripes or No stripes on SS hood?
Old Aug 26, 2011 | 08:04 AM
m_birzer's Avatar
Car: 88 IROC
Axle/Gears: stock 9 bolt
I just had the car recently painted and its going back to the shop to get a wet sanding and another clear coat spraying to help the new paint pop like it should and fix a few minor flaws. The paint guy said he would do the stripes for free. I was thinking of doing black stripes just along the edges of the raised section on the hood and come to a sharp point. Good or Bad decision? Black iroc decals are also getting applied to the doors and cleared over.
Old Aug 26, 2011 | 08:14 AM
lunati397's Avatar
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Stripes or No stripes on SS hood?
very important the line from the tip to the back has a pin stripe and for some reason it doesnt look as good without it I think it helps the contrasting colors blend better
Old Aug 26, 2011 | 01:27 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I like yours w/o stripes. But I think it'd look good with them too.
I love yours with the stripe. white deffinately has to have some black contrast
Old Aug 27, 2011 | 01:23 AM
KiLLJ0Y's Avatar
Car: 1993 GMC Typhoon
Engine: 4.3 Turbo
Transmission: 4L60
Question, which Vendor did you buy the hood from, was it difficult to prep? Would you buy it again?
Old Aug 27, 2011 | 02:00 AM
camarosrock1989's Avatar
Car: 1989 Camaro RS--
Engine: MPFI
It looks great just like it is. Clean, not to busy! With that hood you don't need stripes.
What color is that? I am looking to stay with the original color on mine, looks kinda close.
Old Aug 27, 2011 | 04:08 AM
lunati397's Avatar
Hawks third gen I got it back in 2003 it was good but did alot of finish work and a couple years ago it delamed basically the top half peeled off the bottom half and flew about 200ft up in the air but then again I was doing 160 and no pins but I would buy from him again I have met Bruce and hes a straight up good guy and stands behind his stuff and believes in what he sells
Old Aug 27, 2011 | 04:17 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
I think on your car the "less is more" thing applies. I'd stay without stripes
Old Aug 28, 2011 | 01:11 AM
m_birzer's Avatar
Car: 88 IROC
My original color was a maroonish or burgandy color. I wanted to stay close to it but wanted more red. I dont know exactly but can probly find out when i take it in. Its a dark red metallic.
Attached Thumbnails Stripes or No stripes on SS hood?-2011-06-08_15-02   Stripes or No stripes on SS hood?-2011-06-15_03-47   Stripes or No stripes on SS hood?-2011-04-24_12-22
Old Aug 28, 2011 | 01:30 AM
m_birzer's Avatar
Car: 88 IROC
Thanks for the input. I'm still undecided though and it goes in on wednesday. lunati397: The stripe does look good on white and I do like it on yours. But I was only planning on doing a stripe along the edges of the scoop (like some do on cowl hoods) and not the entire scoop.
And screaminformula for the "less is more" idk, but it may ruin that if I do go with the black ZO6 wheels.
Old Aug 28, 2011 | 04:20 AM
lunati397's Avatar
its hard to get a regular paint to look good on a metalic and just doing the sides is tough because there is no difinitive edge to go off of
I had a friend with a metalic gunmetal car that copied me and did the scoop in flat black and it looked good he was in gm hightech about 6 months ago
Old Aug 28, 2011 | 08:40 AM
Abubaca's Avatar
Here's something I mocked up on Kandied's car a few years ago. Hope he doesn't mind me using his pic! ...anyhow, I was going to do this on my Iroc, but ultimately chose to stick with the stock hood. The stripes really break up all that solid color on the hood. On your car, I'd also paint the headlight buckets. The accent colors tie it together just like they would in a room in your house.
Old Aug 28, 2011 | 11:22 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I'm looking to change my car up a little. Can you do it with and without the headlight buckets painted black? And use gold in place of the black on the hood. Also does anyone know if those hoods can be made so they truly use fresh air intake?
Old Aug 29, 2011 | 01:25 AM
i think black wheels and painted headlight buckets would be perfect on this car. i really like the stock wheels (REALLY DO) but adding the black wheels and painting the headlight buckets would set it off nice. i still say no stripes. yes the stripes would look good, but i think she looks better without 'em.
Old Aug 29, 2011 | 11:45 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
I do think the black headlight buckets would look good also
Old Aug 30, 2011 | 03:11 AM
m_birzer's Avatar
Car: 88 IROC
Yea im convinced on the headlight buckets. I'm liking the pic abubaca posted, so I'm leaning more towards getting the stripes.
Old Aug 30, 2011 | 07:55 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
This looks quite good.
Attached Thumbnails Stripes or No stripes on SS hood?-red-20and-20black-20camaro.jpg
Old Aug 30, 2011 | 08:14 AM
stroken85z's Avatar
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
with black wheels and black decals the stripes will look really nice. are your windows tinted
Old Aug 30, 2011 | 09:41 PM
GeorgiaSS's Avatar
Where did you find black IROC emblems at? I need some.
Old Aug 31, 2011 | 06:41 AM
m_birzer's Avatar
Car: 88 IROC
If your talking about the door decals I bought them on ebay and they were fairly cheap if I remember correctly. but if you mean the rocker panel and bumper emblems, I still need to get those. Seen them on Hawks for around $70-80 I think.
Old Aug 31, 2011 | 04:49 PM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Can you post some pics from the side of the hood.
Old Sep 1, 2011 | 07:55 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Its the only pic I have of the car. Its a member on the board, but I dont recall the name.
Old Sep 17, 2011 | 01:44 AM
m_birzer's Avatar
Car: 88 IROC
Update for anyone who was curious on what I did. I chose to go with the stripes and had the headlight buckets painted also. Installed the Iroc-Z door decals and blacked/smoked the turn signals.
Attached Thumbnails Stripes or No stripes on SS hood?-2011-09-14_07-10   Stripes or No stripes on SS hood?-2011-09-14_07-14   Stripes or No stripes on SS hood?-2011-09-16_19-56
Old Sep 17, 2011 | 04:27 AM
lunati397's Avatar
looks good
Old Sep 17, 2011 | 07:52 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
I like it.
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
z28venezuela
Oct 24, 2015 08:15 PM
