Slammed Third Gens - Post Pics
Old Jun 29, 2013 | 06:19 PM
  #501
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: Slammed Third Gens - Post Pics
Good stuff .. Doing some serious drag racing huh
Old Jun 29, 2013 | 08:17 PM
  #502
RubberDucky's Avatar
Car: 1989 Camaro RS
Engine: LH6
Axle/Gears: 3.42 Auburn Posi
Nah, I got them for stupid cheap so its what's going on the car.
Old Jun 29, 2013 | 08:32 PM
  #503
Engine: 305 to 350
Axle/Gears: 10 Bolt
Roger That !!
Old Jun 30, 2013 | 01:45 PM
  #504
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Pwdbychevy, I really like the look of your ride. You've put a lot of work into it and it shows.
That sunshade in back looks right at home on there too. Later.
Old Aug 11, 2013 | 12:11 PM
  #505
atterack833's Avatar
Engine: 6.5 turbo diesel
Transmission: 4l80e
Axle/Gears: 3.21
Originally Posted by mrrman
Here is my 87 TA GTA
Its quite low that I have to go really slow over any speedbump. I cant even put the car on a drive ramp and the rear will drag
ha you kidding me , min was so low it sucked to be me , i had to jack the front up then place wood under when the rear hit , then jack up the rear , then put wood there , then the front again , then jack stands at lowest settine then same for rear , then notch by notch lift and set the jack stands , then it could have ramps slid under , and now im slapping a 1000lb motor and a 4l80e in it (btw its a 6.5 diesel) oh and im not saying yours isnt low , btw love the notch back , your rear looks great
Old Aug 12, 2013 | 05:06 AM
  #506
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Originally Posted by atterack833
......oh and im not saying yours isnt low , btw love the notch back , your rear looks great
Yeah, he must work out sorry i just finished watching dumb and dumber.
Old Aug 12, 2013 | 02:30 PM
  #507
Transmission: 4l80e
Axle/Gears: 3.21
lol ya , i kinda foresaw that , i might be going full frame , gonna be hard to do while staying low enough to look cool (or at least to me , btw i hate the look of a body kit , it doesent look nice on these , well maybe camaros , so i dont have that as an option , if not full frame then front section of frame replacing the subframe , either way ill be cutting the top off of the areas that would hit then fliping them and re welding them in lower , then ill spread the top into a v so it braces good , that way its still strong but also low , my suspensions so weak that even with no engine if i sit on the fender the thing almost bottoms out
Old Aug 22, 2013 | 02:31 PM
  #508
Car: 1989 Camaro RS
Engine: LH6
Coilovers on, still got another 1/2in to come down after new bushings and strut mounts.
Old Aug 22, 2013 | 08:36 PM
  #509
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
I like how it sits right there.
Old Aug 22, 2013 | 08:51 PM
  #510
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
Haha, I'm kinda excited that I can post in this thread.
I dropped the z28 to where I want it. Well atleast the front. I'm doing the rear tomorrow.
Old Aug 23, 2013 | 03:18 AM
  #511
karl's-92'-z28's Avatar
Car: Too many cars
Buggy...Im loving the color ..SMO?!?!?! What suspension mods & rim & tire combo are you using?
Old Aug 23, 2013 | 09:51 AM
  #512
Axle/Gears: 4.10
Thanks! It's actually Brilliant Red. It is more of a Maroon color out in the sun. I'm running Moog Springs all around. I cut .75 off a coil up front and about half a coil in the rear. I will be cutting a tad more off the rear today. The next step is strut tower brace, adj panhard bar, sub frame connectors, relocation brakcets and etc.
The wheels are TSW Indy 500's with Nexen Tires.
Old Aug 23, 2013 | 10:11 AM
  #513
BADNBLK's Avatar
COTM Editor
Man that looks really good! Those are 20" right? Those are new right? I thought your other? wheels were chrome?
Anyway. Before cutting your rear spring you might be able to remove in upper coil insulator, and just put a small section on heater hose directly on the coil spring to get the drop your looking for without chopping a spring.
Old Aug 23, 2013 | 10:26 AM
  #514
Axle/Gears: 4.10
Thanks BadNBlk! Yeahp they are 20" wheels. And nope, they are the same chrome wheels I have been running for a while.
I already removed the rear Isolator and wrapped it in heater hose, which did drop it about 3/4" lower. It still needs that additional 1/2-3/4" drop though. But, that's no problem since I have removed and reinstalled them so many times.Haha, I can remove, cut and reinstall the rear springs in under 10 minutes now.
Old Aug 23, 2013 | 10:39 AM
  #515
BADNBLK's Avatar
COTM Editor
Guess the wheels didn't look as shiny, or maybe just now that they sit about perfect in the wheel well it help pull the look together... Look great one way or another.
Post the after pics on the rear. I'm sure its gonna look killer.
Old Aug 23, 2013 | 03:14 PM
  #516
Car: 1989 Camaro RS
Engine: LH6
I used the isolators from the front springs on my rears when I put my coilovers on.
Old Sep 1, 2013 | 07:14 PM
  #517
Car: 1989 Camaro RS
Engine: LH6
Old Sep 1, 2013 | 08:49 PM
  #518
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Not "slammed" but as low as I am going with it.
Old Sep 3, 2013 | 03:38 PM
  #519
Ruckusz28's Avatar
Car: 1986 IROC-Z
Axle/Gears: 4:10
Looks good! I want to see more!
Old Sep 22, 2013 | 09:12 PM
  #520
1986camaro385's Avatar
Car: 1986 Camaro Z28
Engine: 385
Transmission: 700R
Axle/Gears: 323
Old Sep 25, 2013 | 06:19 PM
  #521
Raiderfan's Avatar
Car: '92
Car looks awesome Buggy.
[IMG][/IMG]
Eibachs
Old Oct 14, 2013 | 12:25 AM
  #522
DBLTKE's Avatar
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
I thought this was for slammed third gens
Old Oct 14, 2013 | 08:23 AM
  #523
87camaroirockid's Avatar
Car: 1987 iroc
Transmission: 700r4 with shift kit
Axle/Gears: 3.08
nice cars
Old Oct 14, 2013 | 10:58 AM
  #524
BADNBLK's Avatar
COTM Editor
Right! Where's all the low?
Old Oct 14, 2013 | 11:23 AM
  #525
DBLTKE's Avatar
Engine: LB9, LB9
Anyone else dip down into the 23" range?
This 19mm impact socket is exactly 1 1/16" wide...
Old Oct 14, 2013 | 11:33 AM
  #526
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
The pictures really don't do it justice. You have such a nice car man.
Old Oct 14, 2013 | 11:39 AM
  #527
NufNuffZ28's Avatar
Car: 1987 Iroc
Engine: 357 Single plane and a Ysi vortech
Axle/Gears: 3.50 9"
I'm just over 26" DAMN at 23!
Old Oct 14, 2013 | 08:55 PM
  #528
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
DBLTKE,
Is that with the weight jacks cranked all the way down?? Looks great !
Old Oct 15, 2013 | 12:49 AM
  #529
DBLTKE's Avatar
Engine: LB9, LB9
Originally Posted by FSTFBDY
DBLTKE,
Yes, in addition to 1" extended ball joints and 2" raised strut mounts. I will be getting drop spindles this winter to try and get my suspension geometry close to acceptable at this height. I'm also relocating my rear shock mounts 2" lower and will be C-notching my rear inner fender wells for axle tube clearance.
Old Oct 16, 2013 | 05:00 PM
  #530
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Damm, that will be slamed after that. Im thinking of a GC setup for my vert. I don't plan to keep it at full lock like yours but man that looks great.
Old Nov 18, 2013 | 03:48 PM
  #531
DBLTKE's Avatar
Engine: LB9, LB9
Old Nov 18, 2013 | 05:24 PM
  #532
Engine: LB9 | LS1
I dig it.... This "Board" needs "Like" buttons
Old Nov 18, 2013 | 06:09 PM
  #533
bigdavesiroc's Avatar
Car: 87 iroc
Engine: 410 sbc
Transmission: tremec 3550
Axle/Gears: 30 spline 3.73
crap...i thought mine was pretty low in front. just at 25.5" i couldn't fathom 23"?????
Old Nov 18, 2013 | 07:47 PM
  #534
DBLTKE's Avatar
Engine: LB9, LB9
I still need to change a few things before I can drive it regularly. I'm going to go with stiffer springs, though its still up in the air though with exactly what speings rates i should go with. I need do a slight fender pull in the rear and roll the front fenders flatter, C-notch the rear inner fenderwell, and clearance the pinch weld in the front upper fenderwell, as well as redo my rear lower shock relocation brackets. My 240sx is this low and I daily it with no problems so we'll see if I can do it with the Camaro too.
Old Nov 18, 2013 | 07:53 PM
  #535
Engine: 305 to 350
Axle/Gears: 10 Bolt
I am at 25" would love to go lower but roads out here are the worst and I know how to drive a lowered car
Old Nov 19, 2013 | 08:57 AM
  #536
maks10's Avatar
Car: 1990 Trans Am
Engine: 5.7 350 HSR afr195 xfi268
Axle/Gears: 3.08 posi
^^same in WV
dbltke, real nice stance!!! and wheel combo
always like seeing this thread but then realize the truth...potholes
Old Nov 19, 2013 | 01:06 PM
  #537
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Originally Posted by maks10
^^same in WV
Weird. The roads around here are absolute crap but I've never had issue with that. It's ingress and egress of parking lots, ramps, lots etc that makes me cringe. I scrape front end almost everywhere. :/
Old Nov 19, 2013 | 01:19 PM
  #538
maks10's Avatar
Car: 1990 Trans Am
That too lol i guess most can make their arguments even in parts of Fl...enough views of this thread and ill be motivated to do a small drop
Urs is well done btw
Old Nov 22, 2013 | 10:59 PM
  #539
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
It's true... the overhangs on these cars are absolutely insane... There's just SO MUCH car in front of the front wheels and behind the rear wheels...
DBLTKE , I gotta say, I hate those SS wheels in their normal silver, but in black/competition gray they look great, and I've decided just now from seeing those pictures I think they look even better than your Y2k wheels on your car. They look incredibly good and I hate black wheels.
Old Jan 30, 2014 | 01:01 PM
  #540
z-roc-u's Avatar
how did you slam it on the 22 did you do any cutting or shaving
Old Jan 30, 2014 | 02:41 PM
  #541
Transmission: 4l80e
Axle/Gears: 3.21
Ya before I took my engine out I was just half an inch above yours underneath but I was cheating , I had 3 broken coils on each spring , my exhaust hit when I first got in and when we went into (yes into) speed bumps , I had to get out and push up while my dad worked the trhotle and brake
Old Jan 30, 2014 | 02:55 PM
  #542
Transmission: 4l80e
Axle/Gears: 3.21
Edit: oh I ment ground effects , your kit , your doors mainly look cool , not the way I'm going with mine but I'd love to run beside you on the highway , like a pack of wolves , I wanna do a running with the f-bodys or something sometime with some 3rd gen. .org members , maybe we could take turns being PAC leader(everyone gets a turn or something) then you could see everyone's car and take a big cross Continental road trip , when the fuel usage gets too much you can drop out and head home, I'm thinking we should use walkie talkies on a single band so we can request stops , what do you guys think , should I make a thread for this? If I do , I won't be able to participate till my cars on the road again , but I'm sure I could still help organize it , I'm thinking two laps and stops at different areas where members live , also you can request a stop near your house
Old Feb 23, 2014 | 03:55 PM
  #543
BlackSoul's Avatar
Car: 1989 IROC- Z28 convertible
Engine: LB9
Transmission: 700-R4
Originally Posted by flrtin1
lol see your old skool and raise ya 11yrs lol.....here are some of mine in 86, before you could buy hardly any after market stuff for them, back when if you wanted to do it you had to make it yourself .
I absolutely loved and still love the early third gens especially in red with silver; and yours is a non t-top!! Super beautiful car!!!
Old Mar 3, 2014 | 12:59 AM
  #544
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
Here's my road height. At the track, I can go lower. You can barely make out the LT's.
Weight jacks & drop spindles up front, coil-overs out back.
Old Mar 9, 2014 | 08:34 AM
  #545
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
only ones that are third gen slammed are db and flirtin lol :P even mine now, by new standards needs to be lower.. -___- need some wider wheels soon..
http://www.flickr.com/photos/mikeylaumbphotography/13032708823/http://www.flickr.com/photos/mikeylaumbphotography/13032708823/]DSC_0099[/url, on Flickr
Old Mar 11, 2014 | 03:01 AM
  #546
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
Thanks....lol those pics were taken 28yrs ago in 1986....this is what the car looked like as of last summer
Old Mar 11, 2014 | 08:34 AM
  #547
Car: 87 iroc
Engine: 410 sbc
for some of you being so low, i would worry about ripping the oil pan off. had a friend in high school rip his of 3 times. though he did have hydraulics. and it was a astro van.....oops, i think i just dated myself.
Old Mar 11, 2014 | 11:40 AM
  #548
BlackSoul's Avatar
Engine: LB9
Wow, very few hold on to a car for that long, and it still looks great!!
Old Mar 11, 2014 | 02:33 PM
  #549
Drkhrse89's Avatar
Car: 89 Iroc
Engine: 305TPI
Old Mar 11, 2014 | 04:04 PM
  #550
Engine: 305 to 350
Axle/Gears: 10 Bolt
A lot of wheel gap
