Slammed Third Gens - Post Pics
Car: Too many cars
Re: Slammed Third Gens - Post Pics
@mike22115 what size tires, spacers are you using? Also how far are your jacks turned? Im getting a set of C6's soon, I already have my GC, just need shocks & struts.
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
Fronts are 245/40/18 rears are 285/35/19 and I have 2 inch front adapters and 2 1/4 inch rear. but had to do some massaging of the rear wheel well for clearance, I'd recommend a 2.5 spacer in the rear for extra clearance and my suspension is at its lowest setting in front and the rear I have about a 1/4 inch left to go down on the adjuster
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
mike
whats the height from fender to ground ?
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Engine: 305 to 350
Axle/Gears: 10 Bolt
Ah I was hoping for around 25 all around, but I also have brand new struts so I'm gonna give them some time to wear in and maybe it'll go down a little more up front. I'll keep you posted
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok i most of miss that in the post lol that makes since now they should settle 1in to .5in depends each suspension setup different also it might not settle . what struts/shocks you used ?
Lol, yeah for now their just oem replacement Monroe's. But I will be switching to SOMETHIG better soon, I used the Monroe's because I've ha them siting around for a few months an they were brand new. But soon will be bilistein or better
Engine: 4++,350 & 305 CIs
Here is a couple of "slammed" 3rdgens
I am NOT making light of anyones losses in the pix, I'm just being silly.
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Gorgeous car. I love those wheels too!
lol funny you ask. i actually talked to the person who did the body work/paint before i got it, and he did the body work and everythign and accedently put the decal on backwards on that door...its the way it sould be on the other side. but that was not my doing...the owner before the owner i got it from did that
Car: 1992 Camaro Z28
Engine: 5.7L TPI
Transmission: 5 speed
Axle/Gears: 3.47
Car: 1992 Camaro (Z28 Clone)
Engine: LB9|TPI
Engine: LB9, LB9
My car should be nearly an inch lower in the front very soon, had to rebuild the suspension after hitting a wall at 50mph.
COTM Editor
Engine: LB9, LB9
Yeah, I'm fine, I think the car is mostly fine. I had to replace just about every component in the right front suspension (thank goodness I have a parts car). I'm currently looking for a RF fender and bumper cover. I still have more shows to go to this summer! It'll be better than new in no time.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Dame that sucks at least its repairable everything happens for a reason to tell you to go lower lol
Car: '91 RS / '17 FiST
Engine: Internal cumbustion
Transmission: 1 with a fun pedal and 1 without
Axle/Gears: 4th gen ss
I don't know how you guys lower your cars. I believe my car is still at stock height and it scrapes on everything. We even knocked the curb out at the house so I don't scrape going in and out of the driveway haha.
Engine: 305 to 350
Axle/Gears: 10 Bolt
Haha are you sure it's stock height? Post a pic up. And anyone who say a slammed car is not daily driveable doesn't realize that when you lower the car your driving habits have to change, for example, trying to avoid speed bumps at all costs lol
Sorry for the dark picture.
COTM Editor
Car: 88 firebird convertible
Engine: 305 tbi v8
anyone here riding around on cut springs and 20's??? i wanna drop mine about maybe another inch all around.
i have the ws6 suspension on my bird so it "looks" lower already. idk if that is the case or if its spring sag or whatever..
how much should i cut to get about 1"??
Engine: 305 to 350
Axle/Gears: 10 Bolt
theres no real straight answer as there are different variables and each person is different cut a 1/4 or 1/2 at a time till you get the stance you want is the best advice as if you cut to much you have to get new springs its a hassle but worth it in the end
Car: 92 Z28
Engine: Boosted LSX
Loose the strips on the roof and put some more rubber on those rims. I like it all. Paint the blisters silver too. id say a 9/10 for visuals. Looks good.
Car: 87 IROC,
Engine: 370 LSx With Boost
Transmission: 4L80E
Axle/Gears: S-60 with 3.50s
Pics of my "slammed" turds.
The 91 with 17/18 C5 wheels and i think a 2" drop
The 87 with 18" CCW and custom drop LOL
Engine: 305 to 350
Axle/Gears: 10 Bolt
They sure do they even try to make there imports look like the American version but I was station in Japan and seen classics Chevy to newer American cars even lowriders nothing more funny then seeing a Mexican out Asian kinda got to get use to it but it's all gud
Engine: 305 tbi v8
Engine: 305 to 350
Axle/Gears: 10 Bolt
Here's the latest ..New springs up next cut moogs all around ...the rear to high for me and Sportlines suck lol
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Zachary, those are some AMAZING wheels youve got on that car. I can only imagine they're some kind of BMW wheel? There are nowhere near enough wheels in dark gray. Makes for a really mean looking ride.
Engine: 305 to 350
Axle/Gears: 10 Bolt
lol thanks there only xxr nothing special but thats the look im going for mean low and clean i was going to take some better pics put my trans went out yesterday lol i was just about to put my new muffler "powerstick" on and order some new springs ugh another setback .. think i broke input sprag or forward sprag idk so know im comtemplating going to manual or just rebuild 700r4 its my daily driver so hmmmm makes tough decision
my car is far from done tho im alittle more happy on how it looks...ugh stupid trans
COTM Editor
Engine: 305 to 350
Axle/Gears: 10 Bolt
Thanks Alot
new pics will come going to my trans guy after work today
Car: 1992 Camaro RS
Engine: 305 to 350
Axle/Gears: 10 Bolt
there 521 i used 1.25in front... 1 inch rear when i upgrade brakes to c5 or ls1 i will go to 1 inch in front to do extra track width added
i actually got the xxr 962 17x9.5 with custom center caps wheel face was silver i bought off a member here but UPS lost 3 and i only recieved 1 so i sold it lol those 962 you need at least 1.25 spacer but front wheel center cap wont fit so you have to go custom or go to 1.50 spacer i believe
Anybody else sitting on the bump stops in the rear? Lol I'm on ground control and the rear end it's pretty much on the bump stops, anyway around this or does it matter at all because I COULD just adjust the rear up a little but I love the way the car sits rite now.
