Slammed Third Gens - Post Pics
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Slammed Third Gens - Post Pics
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Beautiful!!!!
Car: 1992 Chevy Camaro
Engine: 350 TBi in the working
Transmission: 700R4 :(
thankyou gentlemen! ive been off the site for almost a year now and my car has been neglected and replaced by my jeep
and after looking at these pics and finding out some good news that i might be acquiring a 454 or three
i think my car will be back on the road soon and better then ever
sooooo many clean cars in here. i hope to get some pics up of mine in better shape and tucking some rims a little tighter this time around
sooooo many clean cars in here. i hope to get some pics up of mine in better shape and tucking some rims a little tighter this time around COTM Editor
Method your car looks like mine! Haha! What size wheels? 19"?
Car: 1991 Camaro RS
Engine: 5.0 V8 305
Transmission: Stock Automatic
Axle/Gears: Stock...For Now
Well, I've been debating between getting bigger gears in the rearend on my 91 RS 5.0 or lowering it. If I do lower it, it seems like it would be impractical because if I remember correctly it sits at 26 1/2 in the back and an inch lower in the front so if I get the 2 inch drop or even a 1 inch it seems like it would be way to low. Unless the current suspension is sagging and it is going to just stay where it sits when I put the new shocks and springs on. Any opinions would be appriciated, thanks.
Car: 1991 Camaro RS
Engine: 5.0 V8 305
By the way I live in central Connecticut, the roads are hilly, bumpy, potholes everywhere, they generally suck so...to low can be bad in my case.
Car: 1982 Firebird
Engine: 2.8 N/A
Transmission: Manual 4 Speed
Im in your boat and am hoping the drop isnt to much when i do my car. It is nearly impossible to get accurate info on how much of a drop will work. Ive seen claims of drops that some say make the car undriveable where as other say the same drop works perfect w/o clearance or travel issues. There are just so many variables like spring stiffness, car weight, drop method, tire size, etc. I live in michigan so the roads suck pretty bad here as well.
Car: '89 RS camaro 305 TBI
Engine: LO3
Axle/Gears: yep, has those too (stock)
If your car sits at 25 1/2" front and 26 1/2" rear it sagged quite a bit. Is that still the stock springs and shocks?
I had the same issue and fitting a stock replacement set of springs and KONI shocks reverted the car back to stock height which is 27 1/2" front and 28 1/2" rear. That´s a full 2" difference.
If you get by fine now, you shouldn´t see any difference fitting a 2" lowered or 1 1/2" lowered set of springs and new shocks. You will most certainly feel the difference though.
im not gonna sit here and hear a bunch of BS from this so please people dont start.... that being said.
i was stationed in Michigan for 2 years and had my camaro on the road and honestly i cut my springs, i know its not the most practical way, but when i was said and done i cut a coil and a half off and rode around Grand Haven, Grand Rapids, area daily and a few trips over towards detroit, the normal driving was fine, a few times id scrap on large bumps or divets, and almost EVERY speed bump or entrance/exit ramp id have to take at a sharp angle. here are a few pics how i sit on 245/60 r16s
Heres a couple before the springs were cut
and heres a few after just to get an idea, i spent abuot a week finding the right spot. i would cut about a 1/4 of a coil on all 4 corners till i found a spot i liked in height and was still comfortable. being back in MD now i plan on taking another half coil off and running a small tire prolly a 55 series.
Getting it on my tow dolly to drag back to MD
Car: 87 IROC
Engine: LB9
Axle/Gears: 3.70 9 bolt
My 87 has factory IROC springs that the previous owner cut 3/4 of a coil front and 1/2 coil back. Add 25 years of gravity and...
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Well given the fact that I wrote "not really slammed" obviously I had the title in mind... take a look though the 6 pages because I am not the only one who posted a lowered ride like mine
relax a little bit man.
relax a little bit man. Thread Starter
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
yeah ive come to terms with this thread being diluted..awesome cars nonetheless
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
There's a "lowered" thread BTW... Supreme Member
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
just a quick question i've read a lot of this thread but didnt really get my answer i've cut springs ive bagged truck im not stranger to suspension but i've heard a lot about a panhard bar and LCA relocation brackets, if i cut a coil off or 3/4 of a coil maybe off could i put my car back together without the use of the preferred aftermarket parts, so basically for free can you slam a Camaro lol
Engine: LB9, LB9
Sure, but your axle won't be centered in the car. And you're instant center will be wayyy off.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
Car: 1984 Camaro Z28 Clone
Engine: Bored .030, vortec sbc350
Transmission: Built T5 WC
Axle/Gears: 1999 Torsen 4:10 Locker
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Engine: 5.7 350 TPI
red trans am is super clean
nice job
from now on,
wheel gap = no post
lets try it
from now on,
wheel gap = no postlets try it
Car: 1987 Trans Am
Engine: 5.0L TPI
That means 90% of the cars posted should be deleted lol. Everyone has a different meaning of the word "slammed " I lowered mine 2" all around. That's is low as I wanted to go. Specially with the roads in Michigan haha!!
Car: '91 TA vert
Engine: turboLSx
Yes, yes it does.
Everyone may have a different definition for slammed but I'd say it'd be pretty universal to say your car is not it. However beautiful it is, it isn't slammed. Not that mine is, either.
Engine: 5.7 350 TPI
Yeah I should've put it in the OP..just want to reiderate that all the cars posted are great!! Just most aren't slammed to the standard of no gap :P
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
The problem with being that low ItsMikey is the very rough ride and you bounce around like an import. Also you can't even clear speed bumps, you scrape the front nose and bang the exhaust.
Engine: 5.7 350 TPI
ride isnt bouncy at all..its rough yeah but thats due to the stiff springs, has nothing to do with being low.
speed bumps can be avoided easy and scraping the front doesnt bother me neither does hitting the exhaust..
speed bumps can be avoided easy and scraping the front doesnt bother me neither does hitting the exhaust.. Member
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
OMG Zachary3 ! Either you're a great photographer or that's one of the sweetest IROC's I've ever seen.. wish it was taken at a better place other than at a gas pump lol but still.. way to go dude! Stone
Car: '83 z/28
Axle/Gears: Stock?
I really shouldn't even be posting this here, my car isn't very good looking. And I am kind of disapointed in how low the Intrax springs are, I wanted lower. I even cut 2.25 coils from the rear.
Here it is, It was a bad day to take pictures, I am no photog, car is ugly and dirty. But here you go.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Not bad tho it looks good go to junk yard and get rears and cut more to see what happens
Car: '83 z/28
Axle/Gears: Stock?
I still have the stock ones.
It handles really well how it sits. I might pop the spring isolators out of the rear, should put me where I want it. And I need spacers.
Engine: 305 to 350
Axle/Gears: 10 Bolt
yea that should drop it atleast another inch.
what size spacer i played around with 1.25 spacers and didint look that good rears stick out a tad bit to much and fronts sit flush to fender what size are your tires putting 255 should fill out the fender abit also maybe go to a 55 series tire idk how the front fitment would be tho
Car: '83 z/28
Axle/Gears: Stock?
I flipped mine, the big lip "fronts" are in the rear, and the small lip "rears" are in the front now.
I have that factory little spacer still in the rear. But I had to get a 3/8" spacer for the front so that the old rears would fit up there. I am thinking close to 2" spacers in the front. I hate how they are sunk in. I havn't measure anything yet though.
I have 245-50-16's on it now. In all honesty. I am not liking the GTA wheels anymore. I kind of want to go with 17's atleast.
Car: '83 z/28
Axle/Gears: Stock?
Ya, I really need to work on my Photog skills haha.
But here is a profile shot, that stupid shadow over the tires makes it look off. And the sky, and my car and...Well here is the pic.
Engine: 305 to 350
Axle/Gears: 10 Bolt
oh ok i got you i forgot the front lip is bigger on the front i always thought it look wierd lol i like the flush look also i was going to put 17x9 all around but ups lost 3 of them so im looking at forgestars 18x9 or 9.5 f 18x10 r that was my original choice ive been looking for wheels for a couple of months so yea its been hard making a decision
Engine: 305 to 350
Axle/Gears: 10 Bolt
photograhphy is easy lol but i always had a artistic side
im not a fan of crosslace or irocs there really played out now only if you leave everything original it looks good
Car: '83 z/28
Axle/Gears: Stock?
Damn, that sucks. is UPS going to make it right?
I am not artsy at all. These shots were spur of the moment. Just a crappy P&S Camera.
And ya, I just want the fronts to sit flush atleast. The rear I like.
Prefer without the silver lip tho...
